sanyo DP32648 tv will not turn on
  • cashkennedy
    • Aug 2011
    • 668
    Re: sanyo DP32648 tv will not turn on
    If its a tiny smt capacitor (around 3mm x 1mm x 1mm box) then you should set your iron to ~ 300 degrees C, and use a tiny bevel, or a pencil tip, contact the solder joints directly while you at the same time pull the part up with tweezers softly. Jump back and forth between each side till you get it to seperate.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    • CR Designs
      • Dec 2012
      • 430
      Cashkennedy did you see post 95 ?
      • cashkennedy
        • Aug 2011
        • 668
        Oh yeah sorry, forgot to reply to that. No i do not have the base, I have the inverter, speakers, wires, a broken psu. I sold the TCON , and the lvds cable to someone else, and used the good psu to fix my own set.
        • CR Designs
          • Dec 2012
          • 430
          cashkennedy,
          Thanks for all the help on this TV, You have been great.i guess just wait for the main board to show and hope it works. Should we check anything else?We did not check this see picture circled component
          • CR Designs
            • Dec 2012
            • 430
            Originally posted by CR Designs
            cashkennedy,
            listed wrong picture here's the right one
            • cashkennedy
              • Aug 2011
              • 668
              Im not sure what that part does, but if you tell me the part number (im at work so not infront of my dp32648) we can try to find a data sheet and figure out if theres an easy way to test it. I do know that 5v runs to maybe pin 3? i was probing around with contuinity and it was one of the few places where 5v power ran.
                It is an audio amplifier, probably class AB. Less efficient that class D, but lower cost.
                • CR Designs
                  • Dec 2012
                  • 430
                  here's the part number: A42205 8RN4
                  • CR Designs
                    • Dec 2012
                    • 430
                    gave you wrong part number here it is again LA42205 8RN4
                    • cashkennedy
                      • Aug 2011
                      • 668
                      As tom said, its a audio amplifier. id assume the large white resistor there is also for that purpose. Most likely its not what is shorting the board, but either way idk how to test an audio amplifier.
                      https://www.badcaps.net/forum/showpo...2&postcount=44 the part you mention in this post could be the failed part, we never tested it, and i honestly dont know a good way to test it. Pin 1 looks to be the input and Pin 2 or 3 is the output? I could test mine later and tell you what voltages it should have , but that wouldnt prove that the problem is there. Perhaps tom knows how to test that part, should have a diode reading most likely?
                      • CR Designs
                        • Dec 2012
                        • 430
                        Let me know after you test yours
                        • cashkennedy
                          • Aug 2011
                          • 668
                          I dont have a multimeter at home that has diode tests, which would probably be the more important test to run on some of these parts...
                          But i tested that part and have 24v on pin 1, 12v on pin 2, 0v on the tab and the 3rd pin, and ~ 1.5v on both pins 4 and 5.
                          Pin 2 is 200 ohms from the 5v rail, and pin 1 is >700 ohms, there must be a cap in the way because the resitance rose as i tested it.
                          Based on my tests above, and the data sheet on this part, im very confused why they would put a part to convert 24v to 12v, when they already had a 12v rail going to the mainboard >.> , it does allow a soft start though vs instant on with the power supply...
                          • CR Designs
                            • Dec 2012
                            • 430
                            Pin 2 is 200 ohms from the 5v rail, and pin 1 is >700 ohms, there must be a cap in the way because the resistance rose as i tested it.
                            Tested part, I got on pin 1 0.02,on pin 2 0.41, on pin 3 0.00
                            on pin 4 0.05 on pin 5 0.00 and on tab 0.00. How would you test resistance
                            • CR Designs
                              • Dec 2012
                              • 430
                              How Would you do diode test? I put my DDM on diode red on pins and black on tab the numbers just rose ever stopping
                              • cashkennedy
                                • Aug 2011
                                • 668
                                Most Multimeters over 10 dollars have a Diode test, it looks like --|>-- on the dial on the meter ( http://en.wikipedia.org/wiki/Fileiode_symbol.svg ), usually you connect the red probe to the same plug as for voltage readings.
                                It tells you the voltage drop over a diode. A diode is a simple electronic component that allows energy to go in only 1 direction. All chips / regulators / ic's are made of of transistors and diodes for the most part. Because they only allow energy in 1 direction, you have to test each pair of pins twice, once with red probe on the first pin, and once with red on the 2nd pin. If parts that should only allow power in 1 direction are failed / shorted they allow energy in both directions / or dont allow energy to pass through at all.
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  Did you ever get the new main board in? Any luck fixing the set?
                                  • CR Designs
                                    • Dec 2012
                                    • 430
                                    Got the board today. The post office lost it for a week. Put the board in and the tv fired right up !! Been on for about 4 hours now working good. cashkennedy thank you for all your help. Also to the others that chimed in.Still would like to know what was bad on the other board.
                                    • ericc54321
                                      #118
                                      I am having a similar problem. My power supply board has no 5v, 12v, or 24v at the white plug coming out of the board. I bought a board on ebay and now I have 5v and nothing else. I just wanted to confirm that if I jump pson and 5v that I should have voltage at 12v and 24v at the plug because when I jump them together I don't get voltage out of 12v or 24v. I just wonder if the new board is bad also.
                                      • CR Designs
                                        • Dec 2012
                                        • 430
                                        yes when I jumped the 5v to power on I got 12v and 24v. I had to replace main board on mind to get it to work
                                        • ericc54321
                                          #120
                                          Thanks. I guess I bought a bad board.
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
