Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
Maybe the CCFL was sensitive to the dimming somehow, TV will no longer have dynamic backlight, but I always found that annoying anyway. Check hrs on backlight counter.
From the service menu.
DISPLAY -> 5 -> Vol+ -> Power.
But this is new inverter board (unless it is also bad) which receives the command signal from the main board to dim the backlights, so what ever that pin does it must cause the IC to turn on. How about putting the old board back in and see if the lamps will stay on with the DIM wire not connected.
Hi guys,
I'm late to the party, but just got one of these in the shop and here is what I did.
It seems that when the duty cycle of the backlight control goes too low (around 10%), it causes an error and the inverter board shuts down.
I replaced R007 (was a 10k) with a diode (cathode,bar, facing towards C008). Then I added a 1 meg resistor in parallel with C008).
This stretches the pulse just long enough to keep the duty cycle high enough to not cause an error. The advantage of this "fix" is that the backlight control still works (verses totally disconnecting the dim control).
hello
this is backlight problem
open ur inverter u have SSI091ASN inside
the solution is
SSI091ASN No datasheets available...but probably
Pin 4 is grounded.
Pin 5 is error out.
Pin 6 may be Vcc. ( Check voltage on this pin.)
Pin 7 is VREF. (Probably 1.2V, 2.5V or 5V.) * jest 5,5V
Pin 13 is grounded.
... pin 20 is OLP (Open lamp protect. Should normally be low.)
(PIN 19 ) ill be 0.01V when the backlights go on.
When It'll raise up to 1.96V steady THEN the TV actually stays on and works
Have 24 pins. Top of the chip left to right, 1 - 12 and bottom of the chip, right to left is
the tv will work ok and then u will see the bad lamp u can replace
and test with ur finger the hot of transformers
if one going so hot than other u have to replace this transformer
but i fix the same problem with the way above coz CCFL circut was sensitive
to bad lamp my tv was KLV-32BX35A.
hope success
hello
the solution is
Pin 4 is grounded.
Pin 5 is error out.
Pin 13 is grounded.
hope success
Thankyou, i want to remove proctect Pin and don't replace bad lamp, what's happen of this transformer???
hello
u want to remove proctect Pin
connect pin pin 20 to ground directly
the tv will work and u will see the real reason which made this problem
bad lamp or bad contact to one lamp or bad transformer or something else like bad caps in pf and high voltage
but please pay attention
it is very important
we remove protection to fix the real reason and after that we we connect
it if u remove it and deliver it to your customer the tv will back to u
u will find big problem burning,dead fet ,dead ic .etc and then u will need i/p board
any way i think u have bad lamp inside this is common fault
in sony and sharp
hope this may help
regards
@amro eid - Thank you very much your ardour, all that you share to userful for me, i've understood what's important of that proplem, Don't be fix it without Ovp
You're Egyptian? your English is very good,and my is so bad i can't write here to more what i think by english hihi
I don't understand really, can you help me, exlain to me more. If i remove protect pin 20, and my tv have bad lamp then turn on tv, transformer works, back light works. What is it to kills Fet, IC or burns transformer
hello coofhair
bad transformer sure kills fet and also may kills driver ic
about ccfl lamps u can test it out of tv with inverter of old scanner u have to see
it.s light one by one u will find one or 2 lamp have dark area besides
it.s contact with ht (about 1200v)
and there is many tools exist online to test ccfl lamps and transformers
resolding components besides fet and transformers coz overheating in this area also make sure carefully about
bad caps which it.s value in pf and high voltage as i wrote before it.s connected to transformers
finally
about sony from my experience i guess u have bad lamp
hope this will help
regards
