Finlux 32FLD760P with Vestel 17PW20.v1
    Re: Finlux 32FLD760P with Vestel 17PW20.v1
    C801, sorry.
    But the voltage across C881 should be OK! It's now 13V, instead of 5V... and the controller can run with this. So do you see 390V across main cap?
    • Serkai
      • 75
      • Sweden
      #142
      It reads 19.2v across when on, 18.2v when standby.
        Now it is good. What happened to change that? Any glitches on screen now? 390V across big cap?
        • Serkai
          • 75
          • Sweden
          #144
          I haven't seen any glitches on the tv, and the big cap when on reads 333v still.
          The only difference now is that I don't have the back cover on, so it gets more aircirculation. It works best when I have a tablefan pointed at it.
          With the back cover on it gets hot, you can feel it at the top. So I'm guessing something doesn't like the heat, and the only things I know that's plugged to heatsinks are the MOSFETs, but I'm unsure.
          If in worst case it's unsolvable, I'm thinking of atleast modding the back to put in a big fan and make some circulation to keep it cool, atleast until I can afford a new PSU.
          But I still want to see if I can fix this one, but it's up to you tom
            Well, it is odd, to say the least. Maybe the PFC IC itself is faulty.
            The PFC IC should be "FAN7529" according to my notes, is this correct (you will need to remove PSU and check bottom for IC802.)
            • Serkai
              • 75
              • Sweden
              #146
              What would the PFC IC look like? I can't find any FAN7529 on the front, but I'll unplug it and check the back too.
              Would help alot if I knew what I was looking for though
                It's on the bottom.
                Kinda looks like this
                http://www.modtronix.com/images/so8.jpg
                • Serkai
                  • 75
                  • Sweden
                  #148
                  PFC IC confirmed to be FAN7529 on the bottom of the board, looks fine to the naked eye, soldering seems solid too.
                    "It reads 19.2v across when on, 18.2v when standby." That is what I expect it to be on C801 (33uf 50V) as I suggested in post 124, now it has lots of regulation head room. I would replace that cap and see if the TV will function correctly every time.
                    So the PFC FAN7529 is not the same as shown in my diagram?
                    • Serkai
                      • 75
                      • Sweden
                      #150
                      The cap C801 has already been replaced with brand new Panasonic caps, 33uF 50V ones.
                      I'm not really that good at reading diagrams, so I can't answer you on that, but I have noticed that almost every pdf file I find about this board is slightly different with the numbers and names. Not sure why.
                        If that is the case, then I would check all the soldering works just to be sure. And now you also know what you suppose to have at VFMain.
                        • Serkai
                          • 75
                          • Sweden
                          #152
                          I've checked quite a lot of the soldering joints underneath the board, I couldn't find anything but to be sure I reheated a lot of the joints to make sure there's no cold soldering, in my case it hasn't helped. I'm just not sure where to check anymore. I feel something might be funky with the MOSFET in the middle of the board, but I don't know.
                          • Serkai
                            • 75
                            • Sweden
                            #153
                            Hey tom, in this post you made, did you mean the C801 or the C881?
                            In my answer when I said 19.2v when on and 18.2v when standby I was referring to C801, the small cap at the bottom right on the board.
                            Just making sure we didn't miss each other there
                            • Serkai
                              • 75
                              • Sweden
                              #154
                              New problem now, I think something's dead.
                              Put the tv back together again, and lo and behold, it died after 5 minutes of a movie.
                              Problem this time is, it doesn't come on, the LED works, but it sounds like something's wrong with the 12v line. This is getting annoying, there's always something new popping up.
                              I really understand now why you buy new PSU's instead Tom, but hell, if I buy a new psu and it's the same vestel, it would probably just die again wouldn't it?
                                Yes but it at least would last 2 or 3 more years and you would have a chance to save up to buy a new TV, or fix an older, better built one. These damn PSUs have been the bane of my life. I have never successfully fixed one, despite at least 5 attempts.
                                Check 12V, and 24V voltages.
                                • Serkai
                                  • 75
                                  • Sweden
                                  #156
                                  I'll get around to checking, I'm a little busy at the moment but I'll keep you updated.
                                  The more the PSU doesn't want to work, the more I want to magicaly fix it haha, I do like the challenge but it's annoying to put on the cover only to have it fail immediately again, this is over the tenth time I've done that now! Grrr.
                                  • ron77
                                    • Dec 2012
                                    • 63
                                    • united kingdom
                                    #157
                                    Ron77
                                    Only recently spotted this post.This PSU has been around for some time now.Many updates of course.Have repaired many of them over the last 6 years.
                                    In this set it does appear to be Ic 802, Fan 7529, that is the problem.When repairing these Psu's I do the usual voltage checks, standby, etc.Then I remove PSU plus all plugs cnnected to it from the chassis. Connect mains only to it, no other plugs. The psu is in on state as P on voltage is 0volts.
                                    At the moment I am running a 17pw20-v2 on bench, a working one.Voltage across c819 is 392volts. Voltage supplied by D831 is 14volts varying only slightly.
                                    Now I have connected a 17pw20-1 that has similar symptoms to yours. Across c819 reads 340 volts.All the output voltages, 24v,12v, 5v, 3.3v are OK.
                                    Low voltage across c819 check circuit around Ic802. Could go on and on about this psu,but I won't. Knowing this psu reasonably well, think advice given earlier, buy a replacement panel, is good advice.As I have 15 of these panels, 5 working 10 not I was in a good position to research this one.
                                    • Serkai
                                      • 75
                                      • Sweden
                                      #158
                                      I'll have to check the voltages again tomorrow, I'm sure something new has failed because now it doesn't start at all again, maybe my bad soldering I guess.
                                      We'll see tomorrow, but thanks for the input. I now know somewhat what to keep an eye on for problems, but I doubt I can fix it. If not then I'll just have to wait and order a new PSU when I can afford one
                                      • ron77
                                        • Dec 2012
                                        • 63
                                        • united kingdom
                                        #159
                                        Ron77
                                        Hello Serkai.
                                        The point I was trying to make yesterday,was you have to get the voltage across c819 reading about 390v.If the reading is 333v the psu is faulty.I work on those psu's out of the tv.When I get that voltage reading 390v, is when I put the psu back in the tv, and not before, no point.I have repaired about 250 of these psu's.Would never start one without having every spare,that is, spare panels.
                                        By the way, I am half scandinavian. Grandfather Swedish, grandmother, Norwegian.
                                          The key point is the DC voltage on C801, if it is too low, there will not be enough voltage for the PFC IC to operate to get that 380VDC.
                                          • piernov
                                            Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                                            by piernov
                                            Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                                            I suspect corrupt firmware but I haven't been able to find anything for this TV.
                                            TV model: Finlux 65-FUC-8060
                                            Mainboard: Vestel 17MB130S 23473048
                                            Panel: VES650QNTS-2D-U11
                                            At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                                            06-01-2024, 12:57 PM
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
