Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
DeLonghi AC Remote only accepts 3V
  • cstout
    • Jan 2024
    • 24
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics for it, but the board reads:
    Goldcorolla
    COR472R V1.1
    2014-11-25
    SMD chip: HB8514F F1HP11.1 (photo attached, I can't find anything on this either)
    I've done the following so far:
    • replaced the E1 capacitor as it did not read the proper value (16V, 42uF)
    • verified the Y1 crystal is reading properly - it is
    • removed and tested all SMD resistors and capacitors
    • replaced all 0 ohm resistors with jumper wire
    There were two 0805 white smds, with no resistance, no capacitance, and no continuity - so my best guess is that these are blown smd fuses. Really not sure though, but there are no markings on any side of it that I can see under the microscope. They were located at C2 and C3.
    J2 was empty from the start.
    The remote works when 3V is applied but does not at any lower voltage. I'm not sure what to check next.
  • cstout
    • Jan 2024
    • 24
    If C2 and C3 were in fact fuses, would it be worthwhile to use magnet wire on these pads and test? I'm hesitant simply because the remote works normally at 3V and I'd assume a blown fuse should stop normal function. It's all very odd to me.
    • Mc_Millian
      Toshiba 50lf711u20 fire tv remote not pairing
      by Mc_Millian
      I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
      The Tv model number is: 50lf711u20 Rev B.
      I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
      I've tried 3 different remotes which should be fully compatible with this TV.
      Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
      The power button, along with the volume,back,select, and directional...
      04-07-2022, 12:15 PM
    • edugimeno
      HiSense 55A7500F won't obbey to remote after power on
      by edugimeno
      Hi! I have this TV set that does the following:
      1) I press the red power button on the remote
      2) The TV turns on normally
      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
      Then after it's off, it would again accept the TURN ON from the remote and same again
      BUT:
      -The remote does show the correct IR beam while observed thru a phone camera
      -The TV works fine while using the MiRemote...
      03-14-2023, 11:22 AM
    • rustinjust
      Please help, where can I get a remote for my subwoofer?
      by rustinjust
      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
      Is there...
      10-28-2023, 03:43 AM
    • tmhobadcap
      Pioneer VSX-522-K remote control not working???
      by tmhobadcap
      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
      12-24-2020, 01:44 AM
    • jesterace
      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
      by jesterace
      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
      Tried installing latest firmware but no change.
      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
      10-26-2022, 02:20 AM
