Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
  • piernov
    • Jan 2016
    • 4439
    • France
    Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
    I suspect corrupt firmware but I haven't been able to find anything for this TV.
    TV model: Finlux 65-FUC-8060
    Mainboard: Vestel 17MB130S 23473048
    Panel: VES650QNTS-2D-U11
    At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
  • Diah
    • Feb 2013
    • 6499
    MBOOT FIRMWARE ISSUE
    • Bazilwrc164
      Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
      by Bazilwrc164
      I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
      The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
      I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
      If anyone can provide:
      • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
      • Or a compatible EEPROM dump
      07-23-2025, 12:15 PM
    • massimomax
      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
      by massimomax
      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
      spero che qualcuno può averlo per riprogrammare eprom. grazie
      Post in English !!!
      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
      02-28-2025, 07:27 AM
    • anlu
      Vestel Firmware - Toshiba 32W133DN
      by anlu
      Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
      Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
      02-04-2023, 12:59 AM
    • PNI E.
      firmware hitachi 50hk6000 mainboard 17mb130s
      by PNI E.
      hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
      02-14-2025, 02:06 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
