Finlux 32FLD760P with Vestel 17PW20.v1
    Re: Finlux 32FLD760P with Vestel 17PW20.v1
    OK, since Vcc is OK, do you see D823? What is on the negative end of the diode? (with black probe on the chassis.)
    • Serkai
      • 75
      • Sweden
      #82
      0v, checked both sides of it to be sure. That side of the board is completely dead right now, I really wonder why...
        OK, across PL111, the red connector, what resistance do you measure?
        (Power disconnected.)
        • Serkai
          • 75
          • Sweden
          #84
          With DMM set to 200k it measures 27.1 and rising (slowly, slowly), I'm not really sure if I'm doing it right. Resistance on the red connector in my picture, with the power cord unplugged from the wall? Btw it says PL811 on the board, if that makes any difference? Found no PL111 anywhere.
            PL811 is what I mean, sorry.
            Mkay, not shorted.
            I wish I knew where to look now but I am thoroughly lost.
            Did you install the grounding strap connecting frame to PSU?
            • Serkai
              • 75
              • Sweden
              #86
              Yup, indeed I did.
              You know, I'm thorougly lost too. All I did was change caps to new ones, tested and not working, and it didn't help to change back. I just don't get it, how can half the board have no connection to power whatsoever from just that?
                ESD damage can cause that but that's rare with PSUs.
                • Serkai
                  • 75
                  • Sweden
                  #88
                  Hmm, ESD... But wouldn't that be noticeable somehow, somewhere? I make sure to ground myself before I play with the soldering iron, and I unplug everything nice and neat.
                  I don't get how 2 caps could do this, as I'm pretty sure it's not ESD but you can never be certain I guess.
                  Just an idea, what about the big thing with yellow tape on it? I'm guessing that part is made to shove electricity around, what if it's broken?
                    Which big yellow thing?
                    ESD can manifest itself in many ways.
                    • Serkai
                      • 75
                      • Sweden
                      #90
                      I'm not sure what they're called, transformers?
                      Do you remember in the beginning when I said the psu makes a beeping/buzzing sound when plugged into the wall. As of now it's completely silent. The sound came from somewhere around the big main cap or top right on the picture. I'm thinking something there is dead now that it doesn't make any sound anymore.
                      It's like the red line I drew is a moat and no power anywhere whatsoever gets across it to the bottom half, doesn't matter where I try, it's stopped. Whatever's supposed to send the signal to let power through it's gone.
                        Yeah, if there's no standby power it won't do the power-on self-test where it fires up the PSU, so you wouldn't hear any noise.
                        I think you mean transformers... they're pretty reliable coils of wire. Very rare for them to fail, and especially not instantly.
                        Your best bet I think is to browse free/cheap ads and pick up a similar Vestel-based TV (you can check parts sites to see what boards are used) with e.g. a smashed screen for the boards. Unless you're sure you cannot get the PSU. You will have to track down the cause of the current failure and that of the original failure, and I don't know if that's practical without a scope and swapping lots of parts.
                        • Serkai
                          • 75
                          • Sweden
                          #92
                          Yeah, I'm leaning towards getting a new PSU, it's just the whole giving up part is pretty hard. I just don't understand how it went from working, but unstable, to completely dead from changing those caps.
                          Sucks big time haha.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #93
                            I thought the big transformer looked a bit burnt - but they do get hot.
                            How about checking/resoldering the joints on it.
                            Also are those type of caps polarised or can you put them in any way around.
                            Post apicture of the underside?
                            • Serkai
                              • 75
                              • Sweden
                              #94
                              I have done some checking and resoldering on most big joints, I can't really tell if it's burn or not, it's just dark coloured but not charred or anything.
                              The caps are polarised, minus to the right in the picture, or closest to the side of the board. It's even marked plus and minus under them on the board.
                              I'll see if I can get a picture of the underside! Not the best camera but, it might work. Can't find any backside pics on google. If you can take on of your board I can mark if anything looks funky, just in case.
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                #95
                                sorry i have no info on your model,-tom i know your a busy man on here,but any advice on my model (onei)
                                  If I don't post I don't have anything to add...
                                  • Serkai
                                    • 75
                                    • Sweden
                                    #97
                                    The camera on my cell is too bad to get anything clear, sorry. I did however notice that I might have touched a small black rectangular thing on the backside when soldering the caps on, it's barely visible but it wouldn't surprise me.
                                    I'm not really sure what those things are or what they do, but it's on the same line that should give standby and it doesn't!
                                    Edit. Touched it with my soldering iron that is. I wouldn't be surprised if that's the damn fault, so small but so dependant...
                                      What's the refdes? E.g. for that chip you read off, "IC802".
                                      • Serkai
                                        • 75
                                        • Sweden
                                        #99
                                        EUREKA! It's alive!
                                        It WAS bad soldering on my part, I hadn't noticed a tiny strip connecting the 100u/50v cap on the backside to another spot, so it was unconnected.
                                        I managed to get it all back together now and the power works, the tv comes on and I'm currently watching a movie to make sure.
                                        I'm not sure what the refdes was but atleast now I know it's not that problem. Perhaps, doubtfully, the main problem is gone now? I'm using the new panasonic caps instead of the old ones.
                                        Edit. Gosh, I sure did feel stupid there for missing that. Atleast now I know not to give up on it just yet. And well, it's the learning process I suppose, good thing I have my magnifying glass
                                          Haha, nice. Check the PFC cap voltage. If it comes up to 390V you may have fixed the problem.
                                          • piernov
                                            Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                                            by piernov
                                            Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                                            I suspect corrupt firmware but I haven't been able to find anything for this TV.
                                            TV model: Finlux 65-FUC-8060
                                            Mainboard: Vestel 17MB130S 23473048
                                            Panel: VES650QNTS-2D-U11
                                            At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                                            06-01-2024, 12:57 PM
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
                                          • tmhobadcap
                                            Pioneer VSX-522-K remote control not working???
                                            by tmhobadcap
                                            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                            12-24-2020, 01:44 AM
