sanyo no back ligth
    Re: sanyo no back ligth
    Can we get a picture of underneath the PSU, around that same area? The green side of the board.
    • ealequi
      • Dec 2012
      • 212
      • usa
      #62
      ok
      • ealequi
        • Dec 2012
        • 212
        • usa
        #63
        • ealequi
          • Dec 2012
          • 212
          • usa
          #64
          is this one good?
            That's great, thanks
              I am wondering about what looks to be a cut in the main copper there...running from C134 to the connector...
              • ealequi
                • Dec 2012
                • 212
                • usa
                #67
                i check it and is good.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #68
                  Can you do a full in focus picture of the bottom of the board.
                  On Pic dco6937, Tcon ,near the connector to the main board there is a White fuse with 2A on it. Can you test it?
                  and if you can get at it when its all connected up can you test the voltage on each side - black lead on ground or connector metal case then probe each side of fuse with the red probe.
                  • ealequi
                    • Dec 2012
                    • 212
                    • usa
                    #69
                    ok, picture first.
                    • ealequi
                      • Dec 2012
                      • 212
                      • usa
                      #70
                      • ealequi
                        • Dec 2012
                        • 212
                        • usa
                        #71
                        is this good?
                        • ealequi
                          • Dec 2012
                          • 212
                          • usa
                          #72
                          check the fuse on the t-con, it is goog. iam going to put everything back together and do the test.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #73
                            Pic is very good one of the best I have seen for some time.
                            If you pan along the white line in the middle to the hole
                            Just below the hole there are 3 resistors and next to them
                            C902 Just below that there is an odd bit of solder?
                            May not be doing any harm but can you check it out.
                            • ealequi
                              • Dec 2012
                              • 212
                              • usa
                              #74
                              ok. i do that now
                              • ealequi
                                • Dec 2012
                                • 212
                                • usa
                                #75
                                was a piece of dust.
                                • ealequi
                                  • Dec 2012
                                  • 212
                                  • usa
                                  #76
                                  on cn2 i am getting gnd,0,5v,0,0,12.5v,12.5v,12.5v,12.5v,0,0,15.v,15.v,3.2v
                                    OK, leave the TV unplugged.
                                    Put the connector on CN2 back in place.
                                    Do not have the connector plug in to the C6.
                                    Get 1K any wattage will do, connect the resistor between PIN1 (5vstby) and pin3 (BL_ON) of CN6.
                                    Plug the TV into the outlet, hit the power switch, the backlights should come on.
                                    • ealequi
                                      • Dec 2012
                                      • 212
                                      • usa
                                      #78
                                      i will try
                                      • ealequi
                                        • Dec 2012
                                        • 212
                                        • usa
                                        #79
                                        is this what you mean?
                                          That looks like a diode, not a resistor?
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
