sanyo no back ligth
    replied
    Re: sanyo no back ligth
    Same issue with the same model as the original OP? If it is it may be better to start a new thread as this one is getting long. Make sure to upload good clear pictures of your boards.
  • tionne4u
    replied
    was this ever resolved? the same issue has bought me here as well, I have the same model and same issue TV powers on and you can hear sound but no backlit. I also see the picture with a flashlight.....Thanks everyone.
  • jazpa
    replied
    [yes i can
  • selldoor
    replied
    Can you also see a dark picture as in post 1
    Have you done all the tests mentioned in this long thread.
    Can you take better photos than the original poster
  • jazpa
    replied
    Yes i have a sanyo dp42849 and i have this problem i have sound and everything no black light check my voltage from that and i have voltage but when i check my fuse r322 i dont have 3v but i can chek it with the beep on and it beeps also i check c821 when its off it drops from 170vdc on down instead of when i turn it on it should jump to 380-390 vdc but it onlys goes to 170
  • MisterD
    replied
    If you don't want it, ship the TV to me, I'll take it and keep it for myself and finish the repairs. Thanks.
  • bohaboha
    replied
    out of to topic i have to do it Thank you to all of you budm,tom66,seldoor and MisterD you are just fantastic and happy new year i hope he will be back after all that effort once again thank you
  • MisterD
    replied
    What a time to quit after bud has done all the hard work helping you out.
  • ealequi
    replied
    i was cheking the reading in this tv and now the tv turn off every 5 second. It is time to said like an familiar boxer said NO MAS!! You guys are champions. I'LL BE BACK!
  • ealequi
    replied
    ok iam ready
  • ealequi
    replied
    ok give me a minute
    replied
    All those solder pads for the SMD Zener, transistors, resistors are on the bottom side of the board, you cannot access them from the top side of the board.
  • ealequi
    replied
    ok, is the testing on the green part of the board or on the top part?
  • ealequi
    replied
    ok give me a minute
    replied
    OK take the DC voltage reading next. With TV plugged in and power switch activated.
  • ealequi
    replied
    ok this is what i got zd601 =.6, pin 16 on IC 301 with ground on c821 = beep but not reading, Q602=.6, Q303=.6 on e, 1.7 on b, R603 and R320 beep but not reading. Nothing, not even beep on C809,C808,R805,R806,R807
    replied
    Unplug the TV from the outlet to check when checking the resistance.
    And by the way, what are the IC P/N I request so we will know what operating voltage on pin 16 should be (now I assume that the line I trace from the pictures is correct)
  • MisterD
    replied
    Please read post 168, turn on TV to check voltages, turn off TV to check resistance.
  • ealequi
    replied
    Originally posted by MisterD
    Okay, Did you hook the negative probe of your volt meter to the negative lead of the Capacitor C821 on the power supply board? it must be hooked here for the ground connection otherwise it will not give you any voltages, and please leave it there for checking these voltages bud has asked for? these are DC Voltages not resistance.
    yes i did
    replied
    Board should have no power applied when testing diodes or resistances.
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-06-2024, 08:10 PM
    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
