This TV was given to me and the guy said it went out during a thunderstorm, so I'm assuming lightning or power surge. He said he replaced the power supply board himself and that didn't fix it so he didn't want to mess with it. I have checked dc output voltages on the power supply in marked locations on pin connectors, has 3.3v standby and 12v present. I could not find anything marked PSON anywhere, it does have a small multi-wire connector going from the IR Board to the main board and the 3.3v is present there as well. I didn't see any small fuses on the Mainboard, at this point I think the problem is on the Mainboard, not sure if the board can be diagnosed and repaired or if I may end up having to buy a replacement board. I would appreciate any help and guidance I can get. I attached some pictures. Thanks in advance
Philips 47" LCD TV.. Dead..Model # 47PFL3704D/F7
Re: Philips 47" LCD TV.. Dead..Model # 47PFL3704D/F7
Philips will sometime use 'STBY' instead of PS_ON.
Can you take close up pictures of the two white connectors on the top right of the power board? You may be correct that the Main board is damaged. Try disconnecting the T-CON board connector to see if the TV will start.
The surge may have come through the antenna connector which can easily wipe out the main board and T-CON board.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
OK, the STBY is the PS_ON pin, you should see it goes or goes down when you hit the power switch since Philips may use reverse logic for turning on the power supply.
Most TV will use anything more than 3VDC = ON, Philips some time will use > 3VDC as off and 0V for ON. But no matter what you should see the voltage at this pin changes when you turn the TV ON/OFF.
What is the chassis number of this TV Model?Last edited by budm; 11-15-2012, 12:47 AM.Never stop learning
Okay, on the connector in the left picture above, at the bottom 1st pin is labeled 3V3 STBY and the 2nd pin is just labeled STBY, the 3V3 STBY has 3.3 volts no matter what, hitting the power switch or using the remote power does nothing, no change in voltage. The other pin 2nd pin up labeled STBY does Not have any voltage at all, power switch does not affect it.
DID NOT SEE CHASSIS # but SERIAL # starts with YA2B100Last edited by MisterD; 11-15-2012, 11:03 AM.Comment
Does anyone know what this is? it is very small and also almost looks clear on top with a round yellow ball or dot inside. It is located on the Mainboard of this Philips TV, it checks open both directions on 400 ohm scale.Attached Filesif you find these attachements useful please consider making a small donation to the site
I removed and inspected the Main board, didn't see any fuses or anything obvious,this looks like another one where I will have to purchase a new/used Main board as a process of elimination, not getting much help, Since the Power Supply board was already replaced I assume it is good...looks like I'll have to remove the complete chassis from where it mounts just to get to the TCON board if it's bad. Any advise would be greatly appreciated.Comment
" the 3V3 STBY has 3.3 volts no matter what, hitting the power switch or using the remote power does nothing, no change in voltage." 3.3V standby is OK, but the main board is not sending out any turn on signal. So main board is bad some where.
What you can do to see if the backlights inverter is working or not, you can remove that connector (3.3v, stby) from the power supply board and use 1k resistor to jump between the 3.3V pin and the STBY pin next to it, and another 1k resistor between 3.3v and the BL_ON pin on the other connector, the backlights then should come on, that way you will not get a surprise that you also have bad backlights.Never stop learning
Didn't have any 1k resistors to try, you are saying to disconnect the connector on the main board side so it leaves a way to slide the resistor leads into the connectors on the power supply and to jump as you have indicated, I tried that with some 500 ohm resistors when jumping the 3.3V pin and the STBY pin next to it, I still had the 3.3v but when I used another 500 ohm resistor between 3.3v and the BL_ON pin on the other connector the 3.3 dropped to 1.8 and no backlights, I did notice when I had the connector from ps to main bd. unplugged that the other STBY pin next to the 3.3v pin had 2.5 v but would drop to zero volts when the connector was back on the main board.
does that mean when applying approx 3.3 volts the BL_ON on pin on the power supply bd. that it should make the backlights come on by switching on the 24 volts to them?Last edited by MisterD; 11-15-2012, 11:20 PM.Comment
It drops to zero because the switching transistor on the main board is stuck low, that is why you have to remove the cables (2) between the main and the power supply. I am surprised that the 3.3V standby drops down to 1.8V with 1k and 500 ohms load. That 3.3V power supply should be able to drive slightly less than 500 Ohms load with no problem and stay at 3.3VNever stop learning
Is it possible to just jump the 3V3 standby that has the 3.3 volts present to the other pin next to it on the same connector that is labeled standby to see what will happen. in other words is there a way to force the tv to power on or start up the power supply, but not knowing if there are any shorted components on the main or TCON Board?Comment
Usually it won't work because the microcontroller is stuck in some other mode waiting for some other condition, and this isn't being satisfied. Can be worth a shot though, sometimes it can kick other things into action...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I'm not where I can get to the TV right now, will be tomorrow sometime, I just want to isolate the problem, I can see a black mark on the chassis after removing the PS Board, the guy I got the tv from replaced the ps board himself after a thunderstorm, I'm wondering if the main board was damaged also. trying to figure out if I should go ahead and order a mainboard and get it on the way.Comment
"The other pin 2nd pin up labeled STBY does Not have any voltage at all, power switch does not affect it." The main board is not working for sure.Never stop learning
Is that STBY voltage next to the 3.3v supplied from the main board or supplied from the power supply, or does it come from the power supply then go to the main board and then in turn the main board turns it on via the power switch?Comment
The pull up resistor can be on the power supply board or on the main board, the signal will be kept at 0V when TV is in standby mode, transistor is on, when TV is turn on, the processor will turn the transistor off which will make the Collector pin of the transistor to go up toward the VCC which will turn on the power supply. That is why I ask you to put the 1K between the 3.3v and the STBY pin, this will turn on the 12v POWER SUPPLY section. So, do you get 12v output when the resistor is installed, disregard the other resistor for now.Never stop learning
I get 12.3 volts at the power supply anyway without installing a resistor on 3 pins of one connector and 2 pins on the other connectors shown on post # 3.
Also If I remember correctly while measuring some voltages on the power supply board I got either 18 or 24v on the cathode of the 2nd black diode marked 31DG going left to right from the word cold at the top of the PS Board.Last edited by MisterD; 11-16-2012, 08:12 PM.Comment
Hmm, it sounds like this TV has 3.3V and 12v standby power supply.
So do you have the chassis number of this TV? I need to look for service manual for it.Never stop learning
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by tuner2000ihello everyone,
I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by spantorHello partners.
Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell... - Loading...
