LG M2262D TV is not turning on
  • stevecmpr
    • 6
    • Uk
    Re: LG M2262D TV is not turning on
    Hi, I have the same tv/monitor exhibiting the same symptoms. I changed the psu for a new one (China approx £18 inc delivery) this made no difference. I will test further now, but think the problem is in the bright/dim/on/off voltages from the motherboard, possibly a firmware glitch?
    My voltages match yours on the psu 'ribbon' connector by the way.
    Anyone got a service manual ?
    • stevecmpr
      • 6
      • Uk
      Quick update. one dead tube out of top 2, one dead tube of of bottom 2.
      • tibimakai
        • Jan 2012
        • 3680
        Thank you for that. I will check them out. Actually, it makes sense, since it looks like it's blinking the brightness.
        • tibimakai
          • Jan 2012
          • 3680
          I have removed the LCD w/PCB, but I don't know how to remove the CCFLs. It's my first monitor panel that I have to take it apart, and I don't know how. I may have cracked one of them, because that noise, just became much louder.
          They definitely blink, but it's hard to say which one.
          One end is much brighter then the other end(top or bottom).
          • stevecmpr
            • 6
            • Uk
            Hi, they are a bit awkward, the screen has to be totally stripped. The tubes are in a metal 'case' which slides/pulls off the screen edges. I came across a company in the USA, Omaha, that supplies 2 pairs of (Lg fitting) ccfl's, pre wired including the tube end insulators and plugs, about $30. Due to the amount of work/time involved I'm changing all 4 tubes.
            • tibimakai
              • Jan 2012
              • 3680
              Thank you, but could you please be more specific about how did you removed the tubes? Where are the wires go in, that side doesn't want to come apart. Or maybe I don't even have to take apart the screen that much? I have snapped out the black plastic frame on three sides, but the wire side I can't un-snap. I may have already broken some tubes inside by trying to take it apart.
              From which company did you purchase the tubes?
              I'm thinking about buying another broken screen monitor and I may end up cheaper that way. I have to sell this one, so it's all about the profit.
              I have opened a bunch of much bigger TVs and I never had issues on how to open them and I have a bunch of left over tubes from bad panels, but this monitor it's the hardest one I have ever done and I don't have any of this small size tubes.
              • tibimakai
                • Jan 2012
                • 3680
                never mind, I have missed two screws under some tape.
                • stevecmpr
                  • 6
                  • Uk
                  #28
                  Hi again, have you managed to access the tubes yet? Bit awkward aren't they, think they were built like that on purpose! The place for the ccfl's is ccflwarehouse.com
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I managed to remove them and ordered two bare tubes, for only one side.
                    The other side seemed OK.
                    I have ordered the tubes from the same place. I have used that place before for other TVs.
                    Not sure how did you get all tubes for $30 though. $9.95 is each.
                    • stevecmpr
                      • 6
                      • Uk
                      #30
                      Hi, these will do: ccflwarehouse.com/ccdubaasfor1.html
                      • tibimakai
                        • Jan 2012
                        • 3680
                        But those are for a 19" monitor only.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Changed the tubes and it's still the same problem. Very dim picture with blinking screen and the inverter transformer still making that sound.
                          It looks like the tubes are not getting enough voltage.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            What could be when the inverter transformer it makes a sparky sound?
                            I have re-soldered all the pins to the transformers and all the little blue capacitors, with no effect.
                            I have tried with Bud's tube tester(spiral bulb with wire soldered to the end) and this tester shows the same thing, dim blinking lamp bulb. So it seems that must be something in the electronics area and not the tube area.
                            Replacement PS+Inverter board is $25.50 shipped from Ebay. Should I get this board, or anybody has any more ideas. It's hard to give up.
                            Before the OZ chip replacement, it did not have an image.
                            • JoeyJoe
                              • Sep 2012
                              • 76
                              #34
                              I have the same Power board for another LG TV / Monitor. Currently still trying to work out the issue.
                              Could you tell me where the 25v and 16v capacitors go? My brother took them all out without noting down the correct locations grr!
                              • tibimakai
                                • Jan 2012
                                • 3680
                                You can look at them on Ebay, just search for AIP-0190A, or just see my first picture.
                                I have just realized that I made a mistake with one of the capacitors in the secondary, I have soldered in the wrong way and it was bulging.
                                I have just replaced it and the TV still doing the same thing.
                                Only one voltage has changed between the main board and PS. The Dim. Before it was 0.75V and now went up to 3.27V, but the screen brightness did not change at all and the noise is still there at the inverter.
                                I could have blown something by reversing that capacitor?
                                Here are the voltages at that connector:
                                15V= 15.2V
                                5.2V= 5.2V
                                OLP= -0.010V-----What O/P means?
                                ON= 3.295
                                DIM= 3.275V(used to be 0.75V)
                                M/S= 2.8xV (the end numbers are vary a bit)----What is M/S mean?
                                - TV off this voltage goes to 4.95V(?!), that is normal?
                                I have also checked a small voltage regulator on the mainboard and the middle pin is 1.74V which I don't think that is normal. Need to look up this part number to see what kind of regulator it is.
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #36
                                  What was the actual measurement on the secondary windings ~1000 may not be good enough if one is 980 and the other is 1020 can you read the part number on the Transformer
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    They both are 956 ohm.
                                    0442 LC TL16.S EEL-22T
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      Thanks - 1.74 is an unlikely voltage - perhaps aiming for 1.8 If there is a supporting
                                      cap it could be that pulling it down as well as the VR being bad.
                                      A daft thought but what happens when you adjust the brightness/contrast.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have checked it again(I have wrote that voltage from memory) and it's 1.784V(input is 3.333V).
                                        The regulator is a EH13A. I can't find any info about it. If it's a 1.8V regulator, then it may be OK.
                                        Brightness doesn't change much. Backlight changes a bit, but not much either.
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #40
                                          EH13A is a 1.8
                                          http://www.datasheetarchive.com/eh13...datasheet.html
                                          • eccerr0r
                                            inverter H tree driver imbalance in an AC inverter
                                            by eccerr0r
                                            My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                            11-16-2025, 12:34 PM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
