LG M2262D TV is not turning on
  • tibimakai
    • Jan 2012
    • 3680
    Re: LG M2262D TV is not turning on
    Here is a video with the problem.
    Panel gutted to be able to see the tubes.
    PS is powered through a resistor from the 5.2V to ON pin.
    https://www.dropbox.com/s/k3s4zj50zn...320_161355.mp4
    • tibimakai
      • Jan 2012
      • 3680
      I have just purchased a new PS from the bay for $25 and now it's working properly, no more blinking.
      • tibimakai
        • Jan 2012
        • 3680
        I have installed the new power supply and the TV works, but it makes a buzzing sound.
        It makes the buzzing sound when there is no signal, or dark images.
        As I increase the backlight setting, the buzzing goes away.
        What this could be?
        • tibimakai
          • Jan 2012
          • 3680
          No ideas?
          The seller offered to send a new board, but I would like to be sure that the PS is at fault and not something else, like tubes, or who knows what else.
          I have just received a CCFL tester and I will double check the tubes to be sure that they are working all four of them properly.
          • supracomp
            • Jun 2013
            • hrvatska
            #45
            Can somebody read value of R111 resistor, near trafo on powerboard. Thank you
            • tibimakai
              • Jan 2012
              • 3680
              I will look at the board when I get home.
              • tibimakai
                • Jan 2012
                • 3680
                The board that I have is the broken one.
                That resistor doesn't have the regular color rings. It's a green resistor with a couple of logos and the only marking that makes sens is 2A. I have measured it out of the circuit and shows 0 OHM. Maybe it's a fusible resistor of a very small value. On the auto scale shows between 0.03-0.05.
                It looks like this:
                http://www.ebay.com/itm/5x-2A-2M-M-R...957#vi-content
                • supracomp
                  • Jun 2013
                  • hrvatska
                  #48
                  Thank you. I put a piece of wire instead it, now it is working.
                    That is 2Amp PICO fuse.
                    • Dumah Brazorf
                      • Jun 2013
                      • 179
                      • Italy
                      #50
                      Fixed one that suddenly shutted off with no sign of life.
                      Replaced the ic strw6252, the picofuse (oddily placed on the hot side) and the schottky rectifier mbr10150 that failed at one of the two sides.
                      • eccerr0r
                        inverter H tree driver imbalance in an AC inverter
                        by eccerr0r
                        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                        11-16-2025, 12:34 PM
                      • x_orange90_x
                        Vizio E55-E1 bad backlights or bad inverter?
                        by x_orange90_x
                        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                        I don't know how exactly to test the inverter itself. Is it...
                        01-29-2025, 09:24 PM
                      • Gentian
                        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                        by Gentian
                        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                        03-06-2023, 07:07 AM
                      • valvashon
                        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                        by valvashon
                        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                        01-04-2024, 01:44 PM
                      • eccerr0r
                        A modified sine wave inverter + a grid tie inverter?
                        by eccerr0r
                        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                        Next thing is trying to charge the batteries using solar power, but that's another issue ...
                        08-31-2023, 09:14 PM
