Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    Yes I do, on side of inverter
      OK, can you show me a picture of approx. where they are. On the top side?
      • YEROC37
        • Sep 2012
        • 119
        Here they are, pictures are kinda blurry sorry...but they are right next to the flat flex insert..
          OK that's good, can you test voltage at the R1035 lead furthest from the transistor. This is a more direct way of probing the backlight command signal. Again chassis as ground.
          • YEROC37
            • Sep 2012
            • 119
            With TV on Standby or On?
              Both states if possible.
              • YEROC37
                • Sep 2012
                • 119
                .3 v on both 1035 and 1036
                • YEROC37
                  • Sep 2012
                  • 119
                  On standby it reads 0
                  • YEROC37
                    • Sep 2012
                    • 119
                    Now there is No reading on inside post on resistor, only on outside
                      Are you testing the lead furthest from Q1005 (the transistor)?
                      • YEROC37
                        • Sep 2012
                        • 119
                        Yes, I tested both sides of the leads and coming up with .3volts on both 1035 and 1036
                          I just realised I'm a complete idiot - very sorry - I have been telling you to test the wrong component all this time!! I just took another look at the schematic and saw my silly mistake. Sorry about that.
                          Instead it needs to be R1802, which controls the transistor Q1803. Please take a photo of the area around this component. I suppose testing both leads on it will be fine, in both standby and running conditions.
                          • YEROC37
                            • Sep 2012
                            • 119
                            Ok First two pictures show me pointing to side that has no voltage rating, but on other side of that contact lead reads .3v, the other picture shows the Q1005 with the probe pointing to it
                              Please see my post above; I'm an idiot and have been telling you to test the wrong thing!
                              • YEROC37
                                • Sep 2012
                                • 119
                                It's ok tom, I'm learning from you and I can express enough the thanks toward this educational knowledge your providing, I am very patient thanks
                                • YEROC37
                                  • Sep 2012
                                  • 119
                                  32.5v on R1803 and .9v on Q1803 but on opposite side of each post reads 0volts
                                    32.5V sounds far too high; do perhaps mean 3.25V?
                                    That looks like the backlight is definitely being told to turn on though, but for some reason it's failing.
                                    • YEROC37
                                      • Sep 2012
                                      • 119
                                      Yes 32.5v I'm sure..
                                        Very, very unusual! Either way, it appears to be functioning well (0.9V at base of that transistor means it is being turned on), and the inverter is at fault. Next step - there should be a cap - C1800, 100uF 25V - which should have ~15.7V across it when that signal is high, and 0V in standby. Can you locate this cap?
                                        • YEROC37
                                          • Sep 2012
                                          • 119
                                          When I tap screen lightly it blinks, but white screen is there still and sound is perfect,
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • hcinne
                                            Dell G15 ryzen edition black screen 2 amber 1 white
                                            by hcinne
                                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                            07-23-2024, 07:56 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
