Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    13.87, 84, 92, 99............ Those are the readings of all 4
      On the 20k ohm range? Any decimal points to report? Most of those transformers look off (all are more than 3% out from each other) but the real bad one is probably the "13.87" one.
      • YEROC37
        • Sep 2012
        • 119
        Ok readings went as follows 13.87 , 84 , 92 , 99 readings seem really close
        • YEROC37
          • Sep 2012
          • 119
          Ok I understand what your saying now,
            Can you show a picture of the meter in the setting you are using just so we can be sure it is OK. When probes are not touching do you see a "1"?
            • YEROC37
              • Sep 2012
              • 119
              On 20k ohm 13.87 13.84 13.92 13.99
              • YEROC37
                • Sep 2012
                • 119
                yes when probes aren't touching I do see a one, sending picture now
                • YEROC37
                  • Sep 2012
                  • 119
                  This is amazing help your giving me, I just would like to extend my thanks regardless of fixing or not,,,Wow I'm very greatful
                    I am happy to help. Any TV saved from landfill is a victory.
                    All your transformers are fine they are well within spec. Next check, see picture. Use 200V DC range. I have no idea what it should be, other than around 50V, from what I heard of this chassis, but it is really unconventional.
                    I am suspecting you may have a broken CCFL tube inside the screen, but to find out you will need to take it apart - literally pull the LCD off - and it's not an easy operation and one that is easy to mess up.
                    • YEROC37
                      • Sep 2012
                      • 119
                      186 volts tom66,
                      • YEROC37
                        • Sep 2012
                        • 119
                        I don't understand why it would be broken unless it fell right? So in taking this off, is this a repairable job at a low cost?
                          We have seen bulbs on this forum which have cracked without obviously being dropped - at least according to the owners. I don't know how or why it happens, but it seems to be happening. Perhaps some internal pressure of small crack introduced at the factory damages them.
                          What is the voltage rating on that nearby big capacitor? 186V is very high. Far higher than I expected. Again this chassis is alien to me though so I am not sure what it should be.
                          • YEROC37
                            • Sep 2012
                            • 119
                            470uf/100V that is the rating on the Cap itself
                              It shoudn't be 186V then if the cap is only 100V rated. Maybe that test point is incorrect. I am checking the SM now.
                              • YEROC37
                                • Sep 2012
                                • 119
                                Ok on one side the left side it reads 186 on the right side it reads 56, from description points from above picture...
                                • YEROC37
                                  • Sep 2012
                                  • 119
                                  It's definitely 186 volts though...
                                  • YEROC37
                                    • Sep 2012
                                    • 119
                                    Point closest to Cap reads 186V....furthest side reads 56
                                      It may be that I told you to test the wrong side. 56V seems much more reasonable I recall someone else here had around 50V.
                                      I have looked at the schematic and they use a very dodgy feedback scheme which looks like it doesn't have a specified voltage.
                                      There should be a pin marked BACKLIGHT-SW on the connector "CN201". Can you see it?
                                      • YEROC37
                                        • Sep 2012
                                        • 119
                                        I see pin CN201 not marked backlight sw, but it is next to the flat ribbon plug
                                        • YEROC37
                                          • Sep 2012
                                          • 119
                                          On my printed paper schematic it does list it as that, I'm with you now
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • hcinne
                                            Dell G15 ryzen edition black screen 2 amber 1 white
                                            by hcinne
                                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                            07-23-2024, 07:56 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
