Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    Just to add this in playing around with these certain things before doing your test above, I turned tv on and seen a faint light grey box just within the perimeter of the TV it stayed for about 20 seconds the TV blinked and now it's back to the white screen
      Hmm. Maybe an OSD or menu or something? If the addressing voltages are wrong, it could cause a faint picture, I suppose...
      • YEROC37
        • Sep 2012
        • 119
        I don't visibly see a c201 c202, I see a CN201 but it is the flat flex we tested earlier, I am checking for Q201
          They are on the inverter board I believe. They may not necessarily be there, there could simply be a space for them.
          • YEROC37
            • Sep 2012
            • 119
            found Q201, but on power supply side,,,,I see C203, 205 etc.. but not C201 or 202..going to look again
            • YEROC37
              • Sep 2012
              • 119
              Measured Voltage at Q201 it is double again at 50.7v, I am going to get my neighbors volt meter to double check, but both my meters can't be wrong lol...all the voltage spots through out the house, appliances, batteries, cable boxes are all correctly reading
                Very odd, how are you measuring voltage, can you show a pic of your meter with it in the normal measurement setting, also try repeating the measurement on the 500, 600 or 1000V range.
                • YEROC37
                  • Sep 2012
                  • 119
                  I'm using the 300 and 200 readings on right side of my meter
                    Well by all means that should work although it wouldn't surprise me if the 300V and 200V are somehow sharing components (part of a voltage divider ladder - it's complicated...) But you get the same results with a different meter?
                    • YEROC37
                      • Sep 2012
                      • 119
                      I do get same result, not finding C201-202.....
                        Hmm. Anything on the bottom of the inverter? They might be there... in which case, an alternate probing location would need to be established.
                        • YEROC37
                          • Sep 2012
                          • 119
                          I'm checking now, went over entire board, Thanks tom
                          • YEROC37
                            • Sep 2012
                            • 119
                            tom not able to find C201 or C202........???
                            • YEROC37
                              • Sep 2012
                              • 119
                              not on bottom of inverter
                                OK, different approach.
                                There's a connector CN1001 on the inverter. Near the high voltage mains side.
                                It should have on each of the pins (from the top, relative to chassis):
                                0V
                                15.8V
                                15.8V
                                0V (VGH)
                                0V
                                3.4V
                                3.4V
                                -6.2V
                                0V
                                0V (VCOM)
                                0V
                                Apparently VGH and VCOM for the LCD are both 0V. I don't believe this, as usually VGH is something like 12-15V, and VCOM is 25V for an LCD screen. So I wouldn't be surprised to see different voltages there. But if there's anything obviously missing, then that could be the cause of the white picture (all pixels letting light through - typically the "no power" state for many LCDs.)
                                • YEROC37
                                  • Sep 2012
                                  • 119
                                  ok on first five they read
                                  0v
                                  14v
                                  0v
                                  6.2v
                                  0v
                                  0v
                                  I stopped there because it seems off from yours
                                  • YEROC37
                                    • Sep 2012
                                    • 119
                                    I also believe there is about 15pins
                                      That may be CN1003... CN1001 is another connector, it goes to the LCD.
                                      • YEROC37
                                        • Sep 2012
                                        • 119
                                        The CN1003 is the one that is smaller and toward bottom where the lcd is, the CN1001 has a flat flex that goes from power board to inverter board
                                        • YEROC37
                                          • Sep 2012
                                          • 119
                                          In which case the CN1003 is not producing any power what so ever...
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • hcinne
                                            Dell G15 ryzen edition black screen 2 amber 1 white
                                            by hcinne
                                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                            07-23-2024, 07:56 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
