Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    Sorry TV was off..my fault
    0
    14
    0
    0
    6.6
    6.6
    0
    43.5
    34.2
    34.2
    0
    • YEROC37
      • Sep 2012
      • 119
      That reading was on the CN1003
        Well, if we assume your meter is somehow reading 2x over range (I've no idea how... there is no way all of these voltages are this much out!) But let's just assume...
        You are getting:
        0V
        17.1V
        17.1V
        21.7V
        0V
        3.3V
        3.3V
        0V (VGL)
        0V
        7V (VCOM)
        0V
        So, VGL should be -6.5V, but you are getting 0V. In fact, VGL is used to make pixels dark. This might explain why you are only getting white .
        Finally - something that actually appears faulty... gives something to look at.
        This voltage is generated entirely on the PSU. However, a short on the LCD module could cause it to fail.
        Try disconnecting CN1003 and re-measuring the -6.5V. If it appears... that's probably where the search stops. There's a short, but I'm not sure what you can do about it because the LCD module doesn't have a separate t-con, so it isn't repairable. If it doesn't come up (or stays quite low... maybe only climbing to a few volts) then it is probably the PSU at fault.
        • YEROC37
          • Sep 2012
          • 119
          Pulled from connector No voltage
          • YEROC37
            • Sep 2012
            • 119
            What are the boards called at bottom of LCD..(LCD boards?) Just asking,
            • YEROC37
              • Sep 2012
              • 119
              TOMMMM guess what I found out what's wrong with my voltage meter, it was set wrong..doing test over...I just seen the negative voltage though on that VGL
                What were you doing wrong? Set on AC?
                • YEROC37
                  • Sep 2012
                  • 119
                  Everything reads correctly now...all pins
                  • YEROC37
                    • Sep 2012
                    • 119
                    YES...My fault
                      So this puts the fault on the HDMI board or the LCD itself.
                      Do you have sound on HDMI inputs, or just analog/TV inputs?
                      I am reasonably certain the HDMI board is OK, and it is probably the LCD panel in some way. It may be possible to get to the long thin boards at the top of the screen but in my experience they don't usually have much on them. It's worth a shot, I guess.
                      • YEROC37
                        • Sep 2012
                        • 119
                        checking sound now,,,,,,,,,I know I have sound on AV/TV inputs...I don't use HDMI on this TV...going to check now
                        • YEROC37
                          • Sep 2012
                          • 119
                          Ok, weird but think I have to get back to menu selection for correct sound..but sound isn't working now..but screen is darker now...I can get to lcd boards, they do not seem that hard to get to....Let me know as I am your student
                            Can you get a picture of those boards? Schematics for those aren't provided. I'm just hoping there's a fuse on one of them.
                            • YEROC37
                              • Sep 2012
                              • 119
                              Pictures coming in a few ....Thanks again..Your pretty awesome to be teaching me this
                              • YEROC37
                                • Sep 2012
                                • 119
                                Here are some pics
                                • YEROC37
                                  • Sep 2012
                                  • 119
                                  Here is another
                                    As I suspected, there isn't much on those boards. A few test points though. VDDD, VDDG, etc. Can you test them? Red probe on test point, meter on DC, black on chassis, TV displaying white screen.
                                    • YEROC37
                                      • Sep 2012
                                      • 119
                                      vddd 3V
                                      vdda 15.6v
                                      vgh 21v
                                      vgl -6.2v
                                      • YEROC37
                                        • Sep 2012
                                        • 119
                                        Not seeing VDDG
                                          VDDG is 0V?
                                          Can you check from VDDG to chassis for ohms, with TV off. May read 0V. Maybe it's the ground, I cannot be certain.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • hcinne
                                            Dell G15 ryzen edition black screen 2 amber 1 white
                                            by hcinne
                                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                            07-23-2024, 07:56 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
