VIZIO M320SR inverted logo?
  • Steelhack
    • May 2012
    • 24
    So I just picked up a VIZIO M320SR.....when you first plug in unit...the bezel logo then blinks for about 1 minute.....then stops. Then when I push the power button the tv comes on and the VIZIO logo appears but its upside down.
    The set is unresponsive after that. If you leave it alone...it will repeat the process on its own.
    HACK
  • Steelhack
    • May 2012
    • 24
    Re: VIZIO M320SR inverted logo?
    • drpj23
      • May 2012
      • 528
      Hmmmm this is quite interesting. Well we do know the backlight works and the tv can produce an image (although yes upside down, it can still produce a uniform image). This to me sounds like a software related issue. I don't know if this could be the case but this tv may have a boot up registry which could be corrupt and the upside down logo is like an exception error. (I really have not a clue but maybe bouncing ideas will help someone else make a better understanding)
      But shoot, take the back off and see if there are any noticeable signs of failure.
      • drpj23
        • May 2012
        • 528
        Actually, check to see if this still has a warranty before opening. Vizio will honor a 1 year warranty on their equip usually. If there is no manufacture date, then it is in the serial number, you will have to talk to vizio support to figure it out.
        But I really want to know what the cause of this is though :P
        • Steelhack
          • May 2012
          • 24
          I bought this used..out of warranty..thinking it just a cap issue. I took off back and checked all caps with my capanalyzer 88a...all look ok....swapped out one that was a maybe...but same result. I have searched the web for a few days...not even one "inverted vizio logo" ....some had a logo freeze...said eprom issue....some had inverted picture blamed tcon....but can't find a clue on this.
          hack
          • awyatt2
            • Feb 2012
            • 407
            • america
            my guess would be a corrupt software update or either the eprom has somehow gotten corrupted. probally a cntrl board issue. just a guess never seen it before
            • Steelhack
              • May 2012
              • 24
              Anyone have a "how to" on resetting the eeprom for this set?
              HACK
              • flamike
                rookie
                • Jan 2012
                • 25
                I seen something similar to that on coppells tv repair blog site,they showed changing the chip out of old card into new one,something to the effect of same card having different chips
                • drpj23
                  • May 2012
                  • 528
                  Well you can try holding the power button down for 30-45 secs and see if that does anything. But otherwise I would take a pic of the main and check voltage regulators (the best you can). EEPROM chips for this set would be difficult to get but as another post had said, you could try resoldering it.
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    I'm amazed at that TV. It seems to be a high end Vizio. Thats just felt weird saying that. There really isnt any good vizio's. It's like a high end failure too.
                    I just seen a mainboard on ebay for $124, that is if the problem is there. I wouldnt spend that much on fixing it. Christmas sales are right around the corner.
                    • Steelhack
                      • May 2012
                      • 24
                      I picked it up broken in hopes of repair and resell....at this point just hoping to get it working...worst case I keep it =)
                      • ecking767
                        • Oct 2009
                        • 492
                        I have seen this problem on many Vizio LCD TVs,
                        You most likely you have a corrupt eeprom and copying this eeprom with a programmer is very difficult. I believe your eeprom part number is H27UAG8T2MTR which also hold those internet apps. I have search the web for H27UAG8T2MTR and I can't find any datasheet. My programmer don't have the H27UAG8T2MTR listed so I can't read or program it. Its seen to be a new chip.
                        your solution for now is a replacement main board
                        ecking767
                        • Steelhack
                          • May 2012
                          • 24
                          Thanks ecking....I was leaning that way...figure one last step is to check on shorting the eeprom to resest..... I see this talked about with samsungs...anyone ever do it for a Vizio?
                          HACK
                          • Steelhack
                            • May 2012
                            • 24
                            anyone know where I can still find a M320SR main board? #715G4835-M01-000-005k
                            HACK
                            • topfli8979
                              • Oct 2012
                              • 311
                              Ebay is your best bet, I needed one for my vizio e470va. Had to wait about 3 months to find one affordable, finally one popped up for $40, picked it up, problem fixed. Also make sure you get the exact version of your same board, Vizio uses this board for 32,37,42,47 lcd tv's. But they all have different firmware, NOT ALL OF THEM ARE COMPATIBLE WITH EACH OTHER, I learned the hard way.
                              • Steelhack
                                • May 2012
                                • 24
                                Yeah...been looking....saw a few when I was trying to just fix...now that I have decided to swap it out...I can't find any.
                                HACK
                                • Steelhack
                                  • May 2012
                                  • 24
                                  HACK
                                  Somewhat of a bump...just to see if anyone knows where I can get parts for this dawg! I can't find anything but the stupid remote on EBAY, SHOPJIMMY, encompassparts, vizparts...
                                  Vizio M320SR
                                  Part # CBPFTXBCB5K10001
                                  Board # 715G4835-M01-000-005K
                                  • kajubi
                                    From Uganda
                                    • Sep 2013
                                    • 5
                                    • Uganda
                                    You have to enter the service mode and change the model version this is due to the corrupt eeprom data
                                    • Bob1394
                                      Vizio M65-C1 | Logo appears for 10 seconds then off
                                      by Bob1394
                                      I have used the search, and am stumped.
                                      My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                      I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                      https://www.badcaps.net/forum/showthread.php?t=81088
                                      https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                      Observations
                                      1) [Interaction] Power turned on via TV button (or remote)...
                                      02-08-2023, 01:03 PM
                                    • Super360
                                      Vizio E701i-A3 Vizio logo flashing then turns off
                                      by Super360
                                      Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                      07-25-2024, 07:06 PM
                                    • x_orange90_x
                                      Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                      by x_orange90_x
                                      I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                      12-28-2023, 06:26 AM
                                    • JaquesPratt
                                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                      by JaquesPratt
                                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                      07-16-2024, 01:04 AM
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
