Sharp LC-40LE810UN question
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-40LE810UN question
    No voltages are present, except some milivolts on the LB connector either.
      Yeah, so the problem is likely with the main power supply; check these locations.
      RED - Test resistance (power off)
      GREEN - Check voltage across (power on)
      1. should be around 10V to 15V
      2. should be around 115V AC (use AC scale)
      If red is OPEN, then the FET is probably short.
      If GREEN 1 is low, then the startup cap, charge resistor or a diode on the secondary is short.
      If GREEN 2 is low, then AC is not getting to the right part for some reason.
        It looks like PD-11 (BU5V) may be the STBY5V.
        Need to see the back side of the board to make more sense.
        • tibimakai
          • Jan 2012
          • 3680
          That is another possibility.
          I will take some photos and measure tom's voltages in the afternoon.
          Bud could you please express your opinion about that 37" Samsung with the T-con problem? Not sure to complain about the board or just let go this TV.
          • tibimakai
            • Jan 2012
            • 3680
            OK, here are the measurements:
            Red resistor is OK=19.4K
            Green #1= 5.5V
            Green #2= ~62.6V
            I have made some pictures too:
              What is that Green #2, I do not see the connections on the bottom side of the board. And how did you access to measure the voltage on it?
              The 19K resistor is for the Snubber circuits.
              Can I get pictures of the area in red? I see some traces have corrosion (dark stain).
              • tibimakai
                • Jan 2012
                • 3680
                I have disconnected the two LED connectors and held it vertically.
                I will put up some more pictures later on from that area.
                There is some corrosion, the tuner for example it's rusted completely.
                I'm going to pick up another LG now.
                Here it is the Green#2:
                  But that is GAS discharge tube, that black thing looks like a black rubber bumper. If that is the two points you have measure 62.5VAC, that cannot not be right since that part is in parallel with one of the common mode choke (very low DC resistance, and low reactive reactance) winding, the voltage will be less than 1VAC. You can also see that they did not install another GT on the top section of the choke either.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    They actually look and feel like rubber layers on top of each other.
                    I will take those measurements in the morning.
                      I think that is just a rubber bumper, I do not believe they stuff the GTxxx in those two locations on the board. The main thing is the AC reading of 60 something VAC at those two pads, it cannot be that high at all.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I have to measure between the two pins or from main caps negative and pin?
                          What is the marking on the resistor? I was expecting it to be a fusible resistor, but it could be a snubber too.
                            Those spark gaps are one of the devices that make the crackling sounds when you plug something in due to the inductor voltage building up rapidly (intermittent contact.)
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Actually that traf has to be measured vertically and that way shows at both in/out 117VAC.
                              That resistor is 20Kohm/2WAT.
                              Just sold two TVs in an hour=$600 total, yeeaahhhh!!
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I wrote down the ICs markings, and I have found two of them, but not the other three.
                                The one that I have found is: DDA002C and 1608B.
                                There are other three ICs which I haven't found yet anything, these are:
                                DDA003A, 36S3LJ/G1006, 5209/50YS005
                                For the 1608B here is the datasheet:
                                http://www.datasheetarchive.com/IC+1...datasheet.html
                                For the DDA002C I have found some pictures:
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Any more ideas?
                                    Voltage across green #1 is too low, check the IC near to it, and see if you can get part #.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      3BS3LJ/G1006
                                      https://cdn.badcaps-static.com/pdfs/...168ebf91ad.pdf
                                        Page 5: "The VCC pin is the positive supply of the IC. The operating range is between 10.5V and 26V."
                                        Check for shorted diodes on the output. Does the supply click or tick at all, approximately a few times a second?
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          It's completely dead. I will measure those voltages in the morning, here is 12:00AM.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
