LG 26LG3000 white screen problem
  • manoftheyear
    • Nov 2010
    • 39
    • Europe
    The screen for this is CMO V260B1-L11, problem is bright white screen only, otherwise working ok. T-con is I believe integrated with the lcd driver board (?) that's bonded to the screen itself. Fuse FP1 bad, gives infinite readings, when cable connected to the T-Con/driver board I get no voltage readings, if I disconnect the cable I get the 12v etc... so I guess mainboard is ok. I think this indicates a short on the T-Con? Uses littelfuse 1206 1,5A which I don't have yet.
    Where to start the troubleshooting? There were some ceramic caps thet were next to each other and showed 0 ohm rating in-circuit, but when desoldered couple of those (CP3 and CP4) they measured fine. That's why those ones might look bit different from others.
    Some pictures attached...
    Re: LG 26LG3000 white screen problem
    The fuse can sometimes blow without apparent cause, due to thermal stress.
    If you can get hold of a 2A (or maybe 3A) automotive fuse, you can use that temporarily to test the unit. If the new fuse doesn't blow, you can find a more permanent replacement.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      CP3 and CP4 seem to be on the main 5V rail that feeds the t-con. There are likely other ceramic caps with them in parallel. It takes one to be shorted to make it seem as if they are all shorted.
      My usual approach is to find all parallel caps that show 0 Ohms and remove them until the rail they were on no longer shows shorted (0 Ohms).
      Before removing anything, though, I would like you to check the following items first:
      1) resistance between test point VDD and ground, VDA and ground, VGHP and ground, VGH and ground, and V25V and ground (all with the monitor turned off and unplugged, of course)
      Note: if your multimeter is manual, make sure to use the lowest resistance scale (i.e. 200 Ohms).
      2) resistance across diode DP1 (or is it DP2?) as well as resistance across DP3.
      Post what results you get.
      As tom66 said, the fuse can indeed sometimes blow for no apparent reason, but given the low Ohms reading you got across CP3 and CP4, there's likely a shorted cap somewhere on one of the main power rails of the t-con.
        I agree with momaka method of removing them until the shorts is gone, these MLCC failed short, does not take much to crack these MLCC. I repaired a T-CON board that has 6 MLCC in parallel, and guess what happen, it's the sixth one that I removed was the shorted one!
        Be real careful if you are going the put the good one back in place, put it back one at a time and check to make sure there is no shorts before installing the next one.
        @momaka, can you tell me what all these VDD, VDA, VGHP, VGH stand for? I see them printed on the T-CON all the time but never figure out what they are and what the typical values should be, thanks.
        • retiredcaps
          • Apr 2010
          • 9271
          A very similar case today of shorted ceramic caps
          https://www.badcaps.net/forum/showthread.php?t=22269
          --- begin sig file ---
          --- end sig file ---
          • manoftheyear
            • Nov 2010
            • 39
            • Europe
            1) All those test points gave infinite readings? Did I do everything right here?
            2) DP1 (or DP2? strange marking) measured 140 ohm and infinite in opposite direction DP3 gave 470 ohm and 178 in opposite direction. Tested in-circuit. DP3 possibly bad? Other ceramic caps that show near zero reading are the CP30 and CP31 that are next to DP3. Also CP5 and CP6 give near zero ohm reading.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              They *usually* do give some resistance, but it probably also depends a lot on the multimeter. When you tried to measure those points, did your multimeter flash some numbers on the screen for a second (as if the caps were getting charged)?
              In any case, as long as they are not shorted or show low-Ohm readings, we can ignore them for now.
              DP1 and DP3 seem fine. You can also try measuring them with the diode function of your multimeter but you'll probably get similar results - if you do, then they are fine.
              All of those are probably in parallel, then. Looks like the 5V rail going to the t-con is shorted. A bit unusual, but anything is possible with ceramic caps.
              I would suggest to remove those shorted caps one by one and see if any are shorted. Also, after removing each cap, check the resistance of the spot the cap was in. If the spot still shows 0 Ohms, then the short is still there.
              Also, can you check the resistance of CP35 (or CP36 - either one is fine since they are in parallel) as well as CP7 (or CP8). CP7 and CP8 seem to be on the main boosted rail (more on that below).
              Well, every t-con has at least 5 major voltage rails. Those usually are:
              1) The main power rail. Usually 5V. It comes from the power supply or the logic board and supplies power to everything on the whole t-con board. It's always protected with a fuse - FP1 for the case of this monitor. It doesn't have a standard name, so some t-cons label it as V5V, +5V, and possibly even VDA, VDD and various other names.
              2) The main boosted power rail. Usually 9V to 20V (most often around 10-15V). Very easy to find it on the t-con since it's always near a large diode and a round inductor (diode DP1/DP2 and inductor LP2/LP4/LP5/LP6 for this monitor - yeah weird naming there ).
              I'm not sure which exact components on the t-con use it, but I know it is used for generating the 2 secondary boosted voltage rails for the transistors in the TFT screen. This rail also goes by different names, depending on who made the t-con. Usual names I have seen are AVDD, VDD, and VBOOST. For the monitor in this thread, I think VDA is the test point for this rail, although I'm not quite sure.
              3) 4) The secondary boosted voltage rails. These are derived from 2) above. They are used for driving the transistors in the TFT ON or OFF - i.e. to drive each pixel.
              One is positive and further boosted above 2) (the main boosted rail), so voltages from 15 to 35V are normal for this rail. Goes by the names of VGH, VGG, VPOS and VOFF (or VON?).
              The other one is actually negative. Typical voltages are from -5 to -10V. Goes by the names of VGL, VEE, VNEG, and VON (or VOFF?).
              5) The supply rail for the TFT driver IC. Typically 3.3V, 2.5V, or 1.8V depending on what the IC requires (sometimes there's actually two of these rails). Derived directly from the main (5V) rail via a linear regulator. In the case of this monitor, this rail is generated by UP5. Seems like test points V33V and VDD correspond to this rail. Hence like the other rails above, this one doesn't have a standard name either.
              • retiredcaps
                • Apr 2010
                • 9271
                Bookmarked!
                • manoftheyear
                  • Nov 2010
                  • 39
                  • Europe
                  momaka, the test points you wanted me to test did show resistance, pretty high ones. All the ceramic caps you mentioned tested fine out of circuit. With ohm meter and the capacitance seemed to be 10 or 11 uF in all of them. CP35 and CP36 measured about 100 ohms in-circuit while the CP7 and CP8 were about 80 ohms in-circuit, but as said out of the circuit all were fine.
                  What wasn't a mainboard problem I believe now is, I slipped a probe while measuring the voltages from the connector to t-con, shorted accidentally two pins on that. Now the 12v VCC voltage is only 5,5V. A voltage regulator U7910 that is BA17809FP-E2 is getting the same low 5,5v voltage. If anyone has a good guess or can trace on what might gone wrong I'll be more than glad to hear. Uploaded service manual if it's of any help.
                    So are you getting 5V at the T-CON fuse instead of 12V like it was before?
                    • manoftheyear
                      • Nov 2010
                      • 39
                      • Europe
                      I used to be getting 12V from the mainboard connector that goes to T-con, if the cable was connected between those boards I did not even get the 12V, it went to 0V. Now the 12V I used to get dropped to 5,5v after the accidental shorting. Or what do you mean?
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        So all of those caps that showed shorted before in circuit (in your first post) are not shorted in circuit anymore?
                        • manoftheyear
                          • Nov 2010
                          • 39
                          • Europe
                          They still are, or at least show the same reading in-circuit as in the beginning. Nothing has changed. But when desoldered all the caps that are mentioned in this thread they all test ok with DMM using ohm and capacitance settings. Maybe there's some more caps with near zero reading in there? Will have to check again. Any more suggestions in the meantime?
                          I'll have to get the 12V rail (this is the t-con main rail?) repaired too as it's 5,5V at the moment. It's 5,5V for both the T-Con and the audio part of this TV while it should be 12V. Could the P-channel mosfet "AO4449 -7A/-30V" cause this if faulty? Anyone? I would suspect that as of now.
                            If that P-FET is burned, then yes, its resistance may be too high and it could cause the problem.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              More than likely. It's probably just one that's bringing the whole bunch down. I think you'll just have to check all of the ceramic caps on the t-con. Best approach here is to check the large ones first, then the smaller ones. Also, when you find shorted caps, don't remove them. First find all shorted caps and mark them, then start removing one by one. Those that you checked already you can leave.
                              If that MOSFET blew, it was probably as a result of the shorted caps, not the other way around. I've had to repair a 17" Dell monitor like that because the t-con fuse didn't blow. At least you are fortunate to know what the MOSFET is. Mine was some small SOT-23 device and I just couldn't read the part numbers (it was half-blown). Wired the t-con so that it was permanently ON by installing a jumper from Drain to Source on the blown MOSFET pads. Not the most proper fix, but it worked.
                              Even if that MOSFET you mention is blown, first try to find the shorted cap. When I fix a t-con board, I usually power it with an external power supply first to see how much current it's drawing and to have more control (i.e. I can turn it ON and OFF whenever I like without having to fiddle with the monitor controls and ON/OFF button). This also saves time by not having to put back the monitor together.
                              If you are sure your t-con uses 12V, then you can feed it a regulated 12V power supply. 1-2A should be enough. If it draws more than 1A, remove power quickly and check if any components on the t-con are getting very hot. And of course, DO NOT wire 12V to the t-con without a fuse or some other way to limit the current. Hooking up a very powerful 12V power supply without a fuse on the t-con can burn traces on it.
                                That is why I asked if the voltage on the T-CON fuse was 12V or 5V? That fuse is the main fuse for the T-CON. You may have blown the switched transistor on the main board that supply the votage to the T-CON. Voltage to the T-CON is turn off when TV is off or in standby mode.
                                • manoftheyear
                                  • Nov 2010
                                  • 39
                                  • Europe
                                  A little update on this one and some light at the end of tunnel: I went through the caps again as adviced and now found the shorted cap, it was CP29 next to the IC TPS65161. It can be seen in pic 6 in the first post that I made. After removing this there's no shorts! Now I would need to know with what kind of cap should I replace it?
                                    Can you post of a picture of the surrounding components? We can make a guess.
                                    • manoftheyear
                                      • Nov 2010
                                      • 39
                                      • Europe
                                      There are pictures in the first post? Don't have a camera right now here with me.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Going by the typical application in the datasheet of the TPS65161, it should be 1uF.
                                        A working TV? How boring!
                                        • ahmarzo
                                          Asus la-7322p white screen problem
                                          by ahmarzo
                                          My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
                                          07-15-2022, 07:52 AM
                                        • domu
                                          Viewsonic VS16217 strange problem - white flickering screen on power up
                                          by domu
                                          As per subject, on power up display shows no image, but white
                                          flickering screen. Strangely, it only happen after power was lost
                                          when it was on. After power returns - white screen only, but if
                                          disconnect power for 12-24 hrs, and connect then again monitor
                                          works normally.
                                          Any clues how to go about it would be greatly appreciated.
                                          07-18-2023, 04:57 AM
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
