Viewsonic VS16217 strange problem - white flickering screen on power up
  • domu
    • May 2014
    • TH
    As per subject, on power up display shows no image, but white
    flickering screen. Strangely, it only happen after power was lost
    when it was on. After power returns - white screen only, but if
    disconnect power for 12-24 hrs, and connect then again monitor
    works normally.
    Any clues how to go about it would be greatly appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8344
    Re: Viewsonic VS16217 strange problem - white flickering screen on power up
    Take a hair dryer and heat the board up to 40-50C and then turn it on. See what happens…
    • domu
      • May 2014
      • TH
      Interesting! Surely will try.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • bembeno
        HP 15-e98se No power and The charging indicator LED is dim and flickering in white
        by bembeno
        HP 15-e98se No power and The charging indicator LED is dim and flickering in white when i checked pl9,pl10 i found 2.8 volt when i checked pq35 i found that Drain = 19 v source = 2.8 and the gate = 2.6...
        10-12-2025, 09:18 AM
      • Ado02
        Lenovo Thinkpad X1 Gen 10 - Flickering Screen
        by Ado02
        We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
        The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
        12-16-2024, 02:33 PM
      • grimacelord
        HP 15-EH1070wm - Black Screen With Power LED.
        by grimacelord
        I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
        First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
        01-28-2023, 10:50 AM
      • joaquinmjuan
        Canon TS8350 Screen Freezes on Power On
        by joaquinmjuan
        Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
        05-07-2025, 12:26 AM
