Asus la-7322p white screen problem
  • ahmarzo
    • Mar 2015
    • 173
    • india
    My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen
  • mon2
    • Dec 2019
    • 14672
    Re: Asus la-7322p white screen problem
    What is the voltage on pin # 28 (DISPOFF#) of the LVDS connector ?
    Voltage on pins # 1-2-3 (B+) of the LVDS connector ?
    Boardview file is attached if required.
    Q: Does the external HDMI display work with this logic board ?
    • ahmarzo
      • Mar 2015
      • 173
      • india
      Pin 1-2-3 has 18v and dispoff has 3v. Yes display comes from external vga port properly
      • vpower
        Asus VivoBook 15 model F512D white screen
        by vpower
        I have this laptop showing white screen as soon as I push the power button, it is booting the operating system because I can hear the windows 11 intro sound. If I connect an external LCD with HDMI cable there is no image. Is it possible to hardware disable the AMD gpu in any way? Or any hint?
        Thanks in advance
        09-23-2024, 12:50 PM
      • domu
        Viewsonic VS16217 strange problem - white flickering screen on power up
        by domu
        As per subject, on power up display shows no image, but white
        flickering screen. Strangely, it only happen after power was lost
        when it was on. After power returns - white screen only, but if
        disconnect power for 12-24 hrs, and connect then again monitor
        works normally.
        Any clues how to go about it would be greatly appreciated.
        07-18-2023, 04:57 AM
      • mmccomputer
        problem with replacing lcd screen
        by mmccomputer
        I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
        otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
        If anyone has any information on the subject...
        12-15-2024, 03:44 PM
      • jimjoe123
        LCD TV Green/Pink screen problem
        by jimjoe123
        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
        Then each time...
        02-23-2020, 01:29 AM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
