26" Sharp LC-26DV22U LCD power problem.
  • Davegerg
    • Aug 2012
    • 62
    Hi, I picked up a Sharp Aquos LC-26DV22U for $20 at a garage sale. Figured I would find some puffed up caps and replace them for $5. No such luck. I hit the power button and the light turns green on the front. No picture, backlight or sound. I do hear some buzzing noise from the large transformer on the p/s board (CEF273A). After reading that pins 1-5 on the white connector (far left) needed 24v and they only had about 8v, I wondered what would happen if I 'introduced' 12v from a wall wart. Well, I touched pin 1 (red wire) with the 12v adapter and now the TV & DVD work fine! The noise from the transformer goes away, too. Could this transformer be going bad or would another component keep it from working properly? Thanks for any suggestions.
    Re: 26" Sharp LC-26DV22U LCD power problem.
    Do you hear a slight ticking or clicking sound from the transformer?
    Do you ever hear a relay click when the power button is pressed?
    • selldoor
      Slow Learner
      • 7870
      Have you tested the small green fuse top of your picture to the left of the yellow barcode label
      • Davegerg
        • Aug 2012
        • 62
        The sound I hear from the transformer is buzzing sound (or maybe a sizzling sound). When I power-on, the relay clicks right away. When power-off, there is a 10 second delay before relay clicks.
        The green fuse tests good (I did a continuity test with my meter).
          OK, try unplugging the power connector where you measure 24V and see if it increases.
          • Davegerg
            • Aug 2012
            • 62
            OK, With green light on, pins 1-5 measure 8.74v whether connector is plugged in or not. After I 'jump start' it, unplugged they measure about 25.3v. Plugged in, voltage drops about 1/4v. Why would 'jumping' it with 12v for about a second make it work? Some facts I didn't state earlier: all the caps are Rubycon and the set was made in March 2007. Thanks!
            • selldoor
              Slow Learner
              • 7870
              Where exactly do you connect the Booster ? 12v+ to pin and what for the ground?
              When it doesnt come on can you locate the startup cap in the primary section maybe
              50v 68uF and see what voltage it has.
              EDIT could be C431 50v 10uF
              • Davegerg
                • Aug 2012
                • 62
                I connect the booster pos. to any of the first 5 pins and the neg. to a mounting screw. Doesn't matter which pin - results are the same. The closest cap I could find is a 100uf/100v and it reads .3v - if I'm measuring it right. I put the pos. lead on one side of the cap and the neg. lead on a mounting screw. Did I do that right?
                • selldoor
                  Slow Learner
                  • 7870
                  No - just measure across the cap what value is c431 did you miss my edit
                  What do they measure after you have boost started
                  • Davegerg
                    • Aug 2012
                    • 62
                    Sorry, I missed it. After I downloaded it then found a rar reader and finally opened it - I realized I already had the schematic printed out! The CEF273A in your doc is a little different than mine. I had downloaded the manual for a LC26SH12U set and it more matches my board. Anyway, I tested the C431 and found the voltage was 19v before my boost and 15.45v after.
                    • selldoor
                      Slow Learner
                      • 7870
                      Can you get a picture of the back of the board - perhaps a poor joint. In fact
                      before you do that, while its in the non start stage, try just pressing gently on the board with a stick or piece of plastic just to flex it here and there- try near the connector and around the transformer.
                      You could also try gentle heat with a hairdryer
                      • Davegerg
                        • Aug 2012
                        • 62
                        Well, I poked and prodded the whole board. I did notice the sound of the buzzing changed on the transformer when I prodded it. No change to voltages though. I touched each joint on the big transformer with a soldering iron with no results. I didn't try the hair dryer but earlier, I had left the TV on for about 2 hrs to play a DVD. Everything was nice and hot, but still no 25v when I tried to turn it back on. Attached are two pics of the back.
                          OK, I look at both power supply diagram, so the switched 24V (PIN1~5) is only putting out about 8V. What do you get at the switched 12V output? The 12V and 24V are generated by the same power transformer, so I expect the 12V output will be really low. So when you attach the external 12V to feed into the 24V line, the backlights and the TV and sounds start working?
                          And right now you have indicated that the TV is still running with and external power supply attached but you are still not getting the 24V for inverter circuits, that is confusing since the backligts inverter circuits need 24V to operate. May be I do not quite understand what you are seeing as far as the voltage readings you are seeing? How big is this 12V power supply? The 24V supply in the TV is about 4~5A.
                          I cannot really see how the TV is running off the 12V feeding into the 24V output terminals right now.
                          • Davegerg
                            • Aug 2012
                            • 62
                            No, I'm not attaching the 12v wall wart permanently. I put a couple of leads on the wall wart and briefly (1 second) touch it to pin 1 on the white 24v connector. This makes that pin (and pins 2,3,4,5) go from 8v to 24v. Then, the TV works fine. It's like I "jump start" it. The only other voltage I've checked it the connector that goes to the DVD. It was about 3v before my "jump start". After, it was 12v.
                            • Davegerg
                              • Aug 2012
                              • 62
                              When I said I wasn't getting 24v, I meant that after I shut the TV off and then turned it back on, I wasn't getting 24v. Every time I shut off the TV, it won't work when I turn it back on - unless, I jump start it with the 12v AC adapter.
                                OK, now I understand, let me see how the circuits work indetails then I may be able to help.
                                So I can use the LC-26SH12U circuits to analyze the problem? The one that I posted?
                                • Davegerg
                                  • Aug 2012
                                  • 62
                                  Yes, I'd say that's the right one. Thanks!
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Did you replace any caps?- looking at c431 on the back the joints dont look too good.
                                    What make of cap is that? There are other odd looking parts perhaps budm will identify where we should be concentrating on
                                    • Davegerg
                                      • Aug 2012
                                      • 62
                                      C431 is the one you had me check earlier. I did replace it (with no effect) and that's why the joint looks bad.
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Replaced it with what make/series - should be low esr - can you check the soldering - probably looks worse in the pic than it is but the joints look pretty close together and the trace looks a little lifted.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
                                        • EazyBone
                                          LG OLED55C9PUA power problem
                                          by EazyBone
                                          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                          The power supply to t con is different story.
                                          This...
                                          06-23-2023, 07:43 AM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
                                        • bscottjohnston
                                          Sharp LC-80UQ17U Power Supply Board problem
                                          by bscottjohnston
                                          I just picked up a Sharp LC-80UQ17U here in Denver on Craig's. The previous owner said he was watching it and "pop" it stopped. Opened it up to find a blown fuse on the high Voltage side of the PS. I bypassed it with a 7.5 Ampere automotive fuse and saw a flash in component NTC7001 (as the fuse popped). I am not going to try to apply any more power to the board until I can locate a schematic. Does anyone have the schematics to RUNTKB217WJQZ?
                                          02-17-2024, 06:03 PM
