Asus x512dk rev 2.1 power on problem
+ More Options
Posts
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG) monitoring the trigger voltage in pin 3 of PU8803 while pressing the power button it measures 0V. PU8803 is the one the produces the 3VA ECO or 3VA EC to power the (U1901) IT8225E-128, There is no effect when pressing the power button. power button pin has 3.3v then goes to 0V when the button is pressed. I'm excited in tracing the circuit using the board view. it leads me to this mosfet Q2202 (UM6K1N) which is connected to the power switch button pin 2 and pin 3 PS_ON_D which is connected to the enable trigger of pin 3 of PU8803.
    My question is what should I measure in the PS_ON_D when I press the power button?
    is it steady 3volts to enable PU8803?
    should I replace the Q2202 or should I trace it further?
    thanks for your patience..
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    I found the culprit resistor PR8825 is not present connecting PS_ON and PS_ON_R installing a 10K resistor creates the VSUS_PWRGD signal that enables all the Power IC,
    including the 1.8v (PU8401) and 0.9 volts (PU8301). Only the PU8701 is not enable though VSUS_PWRGD is present. Gonna check tomorrow if both enable signal pin 6 and 20 are present.?
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      PWM CONTROLLER RT8249CGQW PU8701 is not turning on because of a shorted mosfet PQ8703. The problem is when I replaced it, the new mosfet shorts again.. what seems to be the problem with that. checking the coil connected to the mosfet doesn't have any short to ground..any Idea guys.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If you got display after bios flash, there is unlikely to be any shorted component on the motherboard.
        If the power button is on the keyboard,that may be the culprit. Try turning on without keyboard by shorting the power switch pin on kbd connector.
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          Thanks for the reply. I already turned on the unit by shorting the pin 25 of the keyboard connector.. only the 5v and 3v coil voltage is not present. There is no short in the 3.3v rail but I measure 1 ohm resistance from coil to ground. I remove the soldered joint that connect the 3.3v rail to the 3.3v coil to isolate the 3.3v supply to the circuit. The 3.3v power supply is rated at about 10 to 30A , I think the problem is in the 3.3v supply. Removed the shorted mosfet PQ8703 and replaced it with new again.. power it up.. then the mosfet PQ8702 shorts but not he PQ8703.. Investigating if this mosfet really shorts or just in the on state. Create a mosfet circuit to reset the mosfet by supplying the mosfet with negative and positive feedback on its gate to turn it off with No avail the mosfets is shorted. All pins are shorted. Any Idea what causes this?
          • themosttogain
            HP Envy 13-BA1565na with intermittent power button
            by themosttogain
            Hope someone can give me some suggestions on this because i'm at my wits end with it...
            I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
            Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
            07-12-2024, 03:03 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • TimeRabbit07
            Asus FX517ZC charges but power button does nothing
            by TimeRabbit07
            Hi all!
            I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
            Here are its various numbers and identifiers:
            Model short: FX517Z
            Model long: FX517ZC-HN114W
            SN: NANRCX01S57842E
            CN: 3SDB 12M
            MFD: 2022-10
            Motherboard model: DA0NJLMBAE0 REV E
            Symptoms:
            The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
            History so far:
            The...
            09-04-2024, 05:48 PM
          • reessi
            Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
            by reessi
            With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
            No corrosion any where!
            Tried a replacement power button off ebay and the same.
            Very occasionally it will work with the power button connected!
            Same results with or without the battery.
            Can it be a fault with the Audio board or the mainboard?
            The touch Id assembly connects through the Audio board first then to the Mainboard.
            Flex...
            06-26-2024, 03:31 PM
          • Gjackson
            Air-conditioning unit power supply failing to power up
            by Gjackson
            Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
            01-08-2022, 09:24 AM
