Rapid flashing screen Vistron LCD TV - PSU or Inverter or?
    Re: Rapid flashing screen Vistron LCD TV - PSU or Inverter or?
    Please the PIX.
      If you used a poor quality primary cap and it failed it would damage the PFC stage (MOSFET, diode and cap at a minimum usually.)
      • davcom1
        • May 2009
        • 23
        Ok, have removed the cap and tested as best I can... connected to DMM at 2000k ohms setting and resistance rises. Then tested voltage across terminals after 30 seconds or so and it read 0.2V
        Photo attached shows top of board where cap was located. No obvious signs of damage here.
        Did notice a tell tale "sizzle" as I de-soldered suggesting I had left flux on the terminals.
        • selldoor
          Slow Learner
          • 7870
          It does look repairable, its around now I wished I'd made my usual request for pictures
          of both sides of the boards early on. What is the part number of the board ?
          Clean up the area with some isopropyl alcohol and take another close up of the damage zone. Just by the mains socket on the board is a black encased fuse - can you check it.
          Dont need another pic - Budm has marked the traces out.
          • davcom1
            • May 2009
            • 23
            budm - tested as per your pic and is reading open circuit. I get a resistance of 8.36 at 20k setting between the vertical upper and lower leg of what I guess is the MOSFET.
            • davcom1
              • May 2009
              • 23
              selldoor - the fuse has not blown at the power input. Do you still want another pic of the damaged area?
              Part no of board is GPAC 211424A rev 2.1
              • selldoor
                Slow Learner
                • 7870
                #27
                No - see edit - Budm has marked out the traces so if it needs wires to mend the traces we can see where they should go. Do Budms resistance check and post result
                • davcom1
                  • May 2009
                  • 23
                  Getting called away for an hour now by the other 'arf as she wants to go shopping... doh!
                  Have quickly done a diode check across the large one close to where the pop happened and it had a reading of 450?
                  • davcom1
                    • May 2009
                    • 23
                    selldoor - sorry, I did check the resistance as per the image from budm and posted it (#25)
                    It read as an open circuit. Am guessing the cap removed makes no difference to this.
                    • davcom1
                      • May 2009
                      • 23
                      Thanks for the advice so far but now I'm at a loss as to what to do next?
                      I tested the other MOSFETs on the board and they all had similar readings. Do I just put it all back together, replace the 5A fuse in the plug and repair the PCB trace and hope for the best?
                      I still have the option of a replacement board if it all goes bang again!
                        You need to use jumper wire to fix that blown trace. Since the MOSFET check open, I still would like you to look at the body of the MOSFET to make sure there is no sign of damage on the body, it could have blown so bad that it went open circuits. For the copper trace to blow and took out 5A fuse, something shorted badly to cause that kind of damage.
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          To save big blow-outs you could rig something like this
                          antiqueradio.org/dimbulb.htm
                          • davcom1
                            • May 2009
                            • 23
                            Thanks budm and selldoor.
                            I hadn't read the dim bulb idea before I put the main capacitor back in place and soldered in a wire to jump the damaged trace.
                            Plugged in and switched on and the TV works again... (!!)
                            Does the jumper wire need to be particularly large in diameter? At present, I've used wire comparible to the other existing wire jumpers as per my image on post #23
                            I also remembered to give the soldered areas a good clean off this time too as I'm pretty sure it was excess flux that did the damage.
                            Regards,
                            David
                              Replace the cap with a decent quality one - it will only fail again like the Samxon.
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Should be ok trace is only thin even if wide. If you can get at it when the tv is on check to see if you can see it overheating - BUT remember dont touch it until the big caps has discharged. Invest in a good name cap as Tom says.
                                • davcom1
                                  • May 2009
                                  • 23
                                  Thanks to everyone for your help and advice with this - much appreciated.
                                  I've now ordered a Rubycon cap to replace the Lelon.
                                  David
                                  • HTR-Informatique
                                    by HTR-Informatique
                                    02-09-2025, 06:51 AM
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • reformatt
                                    by reformatt
                                    07-31-2025, 08:37 PM
                                  • smic717394
                                    by smic717394
                                    07-25-2024, 10:16 AM
                                  • dbuergi
                                    Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                                    by dbuergi
                                    i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                                    Any ideas where to look?...
                                    11-07-2024, 10:57 AM
