Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
  • dbuergi
    • Jul 2024
    • 131
    • Deutschland
    i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
    Any ideas where to look?
  • reformatt
    • Feb 2020
    • 1497
    From experience with liquid damage on Apple boards, you need to examine every passive component with dull grey end caps, as the pad underneath is often corroded (or the connection is bad). Often get boards come back with intermittent issues unless you do that. If the damage is extensive like you say, I write them off as the repair will bounce back to you. I just remove and replace from a donor en masse but I don't waste too much time on them.
    First thing for me would be to replace the LCD connector and backlight IC (U7701). The feedback pin is often corroded (pin 5).
    • dbuergi
      • Jul 2024
      • 131
      • Deutschland
      Thank you for your support. I will have a closer look again at the weekend. I'm only doing this stuff as a hobby and to learn something but the starting position with this board was really bad. All water indicators deep red but since the Macbook is booting i have some hope to find the fault. I also have two donors for parts if needed.
      I added some pictures of the first look at the board.
      • Ugur87
        MacBook Air M4 A3240 Brand New Water Damage no Image
        by Ugur87
        I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
        08-28-2025, 01:09 PM
      • TimSinger
        MacBook Pro M4 16" A3403 on the table with water damage
        by TimSinger
        Hi guys,
        I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
        I attached a photo of the missing cap. It's on the bottom side of the logicbard.
        I am very thankful for your replys.
        Thanks in advanced and best regards from Hamburg Germany...
        07-13-2025, 11:12 AM
      • mon2
        A1466 Macbook Air (Liquid damage repair)
        by mon2
        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
        Macbook AIR Model A1466 Diagnostic 09-01-2021
        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
        Problems & Resolutions
        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
        09-01-2021, 09:31 AM
      • Grandoni Manuel
        MacBook a2289 water damage
        by Grandoni Manuel
        Hello to all ! I follow you but this is first time write !!
        your forum is the best !!
        so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
        now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
        q8400
        q8401
        D8410
        and the resistor R8431
        if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
        on...
        04-03-2025, 06:45 PM
      • s_henya
        Macbook Air A3114 5V 0.0A after water damage
        by s_henya
        Hi Mac experts :-)
        Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
        This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
        Took out the board and it suffered some water damage, see attached pics.
        All cleaned with IPA but due to long time with corrosion something already got shorted...
        any advice on the below:?
        1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
        I tried injecting 0.5v on one of the caps...
        08-25-2025, 01:09 PM
