Philips 42PFL7403D Doesnt turn on
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Philips 42PFL7403D Doesnt turn on
    GREAT!!! couple of possibilities Plug or Connector or Cable
    Take apart and check closely with a magnifying glass. Are pins on the board
    loose/bent can they be soldered/straightened.
    The hollow pins on the plug can sometimes be extracted then you can resolder to the wire.
    If there is a break in the wire is it going to be long enough if you shorten it
    or else you will have to join some more wire on to it, solder on the hollow pins and refit into the plug
    • pacmyc
      • Aug 2012
      • 41
      • Sweden
      No they are not loose or bent. The cable is also fine.
      However, there seems to be a short on the board between pin 2 and 9.
      I the schematics pin 2 is ground, and pin 9 goes nowhere except for FFAA (which I think is a test-point). Am I correct?
      Update: but on the SSB side pin9 seems to be some kind of TACT_SWITCH_INT, that could cause the standby to halt..:S
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Can you do a pic of the back of the board and can you mark the next joint pin 2 and 9 go to on each picture
        What happens if you unplug the button cable and use the remote only?
        • pacmyc
          • Aug 2012
          • 41
          • Sweden
          I can't see where the pin 2 and 9 goes because it's a multiple layer board.
          With the keyboard cable disconnected it behaves exactly the same.
          • pacmyc
            • Aug 2012
            • 41
            • Sweden
            I have ordered a new LED panel control. I will let you know if it fixes the problem with the TV or not.
            • pacmyc
              • Aug 2012
              • 41
              • Sweden
              #26
              Got the new LED panel control today. Still the TV works exactly the same :S
              It has problems turning on. If removing the 8-pin cable from the led panel control and connecting (to half), I can hear the PSU starts working, and then white LED starts flashing. In a few seconds TV is on.
              If I now turn off the TV I cant turn it back on without doind the same procedure again.
              Im starting to get tired of this TV now, asking you for your last ideas before throwing this set into the trash..
              • pacmyc
                • Aug 2012
                • 41
                • Sweden
                #27
                I was wrong, the cable is connected 100%. It seems like some signal on this conector needs to go low to start the rest of the TV.
                  Is this the manula you are using/ I want to make sure I am reading the same one.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #29
                    Yes he has exactly the same link in post1
                    "http://elektrotanya.com/philips_chassis_q529.1e_la_sm.pdf/download.html"
                      OK, I will download and study it tonight.
                        OK, I looked at the service manual, it does not seem to match what you have. In your pictures of the LED panel board, it has two connectors, but the diagram shows 3 connectors. Does the connector on the left go to the Keypad? What happen if you disconnect that and use the remote to turn on instead (the 9-pin connector is in place and connected to the main board?
                        Do you have the chassis number of this TV?
                        • pacmyc
                          • Aug 2012
                          • 41
                          • Sweden
                          #32
                          Yes the third connector (1P09) is just prepared on the board, it doesn't have the plastic holder but the solderpoints are there.
                          Could the actual chassis be Q591E? (When looking at what software version is installed in SAM-menu). Or is that just the software version?
                          There is no different behaviour of the TV with or without the 4-pin keyboard cable connected. However, if trying to start the TV with the keyboard buttons it will just kill the red front led and TV will not start.
                          Also, when TV has started I can use the keys on the keyboard, BUT! if i keep a key on it pressed for more than 1 second the TV shuts down.. Strange
                          • pacmyc
                            • Aug 2012
                            • 41
                            • Sweden
                            #33
                              The chassis number is on the same tag as the model tag on the back of the TV.
                              From what I can see in the diagram, their only 3 signals that are generated by the LED panel that get sent o the processor: 1 signal is the key pad (I was thinking that the Power key was stuck on, so when you insert the connector in lsowing it turns on the TV but then you cannot turn it off due to stuck key, that is why I suggested you to disconnect the key pad). 2nd signal is the IR Remote signal (RC) from the IR module. 3rd is the light detetor (for auto brightness?). Since you can insert the connector (9-pin) slowly into the LED panel board to make the TV comes on, then it has to be one of the 3 that is giving you the problem, keypad is not one of them. IR signal will be the next one to try.
                              • pacmyc
                                • Aug 2012
                                • 41
                                • Sweden
                                #35
                                Sorry, now I found the chassi number on the tag, it is Q529 1E LA
                                OK. No stuck key, and also the keys do work when the TV is on. But if a button pressed for more than 1 second it shuts down the TV.
                                Its not the IR signal or the light detector because I have replaced the LED panel control board with a brand new one.
                                I wrote that I could slowly connect the 9-pin cable back to get the TV to turn on, is wrong. Sorry, I thought so at that point but later I found out that I can connect it fully with the same result. The important thing is that the cable is fully disconnected and then fitted back. (At that point I thought it was due to a bad contact in the connector)
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #36
                                  Can you do a picture of the area of the board near the socket (9pin)
                                  Front & Back say 4 to 6 inches
                                    "The important thing is that the cable is fully disconnected and then fitted back" and that will make the TV come on? it sounds like the processor is looking for a pulse from one the three input lines.
                                    • pacmyc
                                      • Aug 2012
                                      • 41
                                      • Sweden
                                      #38
                                      Here you go
                                      • pacmyc
                                        • Aug 2012
                                        • 41
                                        • Sweden
                                        #39
                                        Maybe I should start cutting the wires on this 9-pin cable, and see when after which of the connectors the PSU will turn on?
                                        Would this info be helpful?
                                          I would try removing the RC line pin3 (there are only 3 signals, keypad (pin7), RC (REMOTE IR receiver, and light sensor pin1, not sure about pin 9 for the TACT SWITCH).
                                          • osman68i
                                            Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
                                            by osman68i
                                            I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
                                            u2 is shorted. I can only read MX1 . cable goes to display panel....
                                            Yesterday, 01:55 AM
                                          • JorKsX
                                            Philips 47pfl6008s wont turn on
                                            by JorKsX
                                            Hello. Got my hands on Philips 47pfl6008s/12.
                                            Problem is that it does not turn on. Last owner said the problem came slowly.
                                            One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                                            And then it went into hours of unplugging and replugging until it turned on.
                                            When I plug AC into tv, it does not respond to "turn on" button or anything else.
                                            After 10-15minutes the TV starts blinking red LED twice.
                                            So it blinks twice, then waits 3 seconds, then again twice...
                                            02-13-2022, 03:36 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • ovrax
                                            Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                            by ovrax
                                            First of all, please excuse me as I'm quite new to this field.
                                            I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                            I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                            The Ambilight works perfectly and stays on.
                                            No sounds.
                                            Thanks in advance.
                                            08-25-2024, 04:33 AM
                                          • Henke
                                            Philips 55POS9002/12 shorted mains
                                            by Henke
                                            Hi.
                                            I have a Philips tv where the two main fuses are blown. I found a bad cap. I removed it, and now it seems to work. But i have to replace the cap. I do not have the exact same one at home. What's the purpose for it and what values can i use instead?
                                            Its placed across the Drain and Source on a N/Channel MOS
                                            The blown one is 101K, 1KV (check picture). I have 221K, 1KV at home, can i use that?...
                                            08-06-2024, 03:51 AM
