Philips 42PFL7403D Doesnt turn on
  • pacmyc
    • Aug 2012
    • 41
    • Sweden
    #41
    Re: Philips 42PFL7403D Doesnt turn on
    Originally posted by budm
    I would try removing the RC line pin3 (there are only 3 signals, keypad (pin7), RC (REMOTE IR receiver, and light sensor pin1, not sure about pin 9 for the TACT SWITCH).
    But if I remove the RC pin I cant turn on the TV (with remote control),
    well I can check of course if the PSU seems to start up.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #42
      @Budm - What about that transistor at 7FA2 if that is shorted might it cause this problem
      Pic on Post38
      • pacmyc
        • Aug 2012
        • 41
        • Sweden
        #43
        Pic on Post38
        I have replaced the whole LED panel control board, so I think
        we can exclude any faulty components on that one..
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          Its not on the Led panel control board its in the last picture.
          • pacmyc
            • Aug 2012
            • 41
            • Sweden
            #45
            Ok sorry.
            It's a BC847B .
            I should probably desolder it when testing, or what do you say?
            I will test it tomorrow.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #46
              Ok sorry.
              It's a BC847B .
              Sorry, I dont know - that is why I was asking Budm if it might be relevant.
                There are 3 transistors, two are for driving the LEDs, if they are shorted, then the LED will just stay on, they do not send any signals back to the CPU, the other transistor is for auto brightness control of some sort that adjust the backlights brightness depends on room light so I do not believe that will cause the TV not to function. You should be able to disconnect the Remote signal line and use the keypads to turn the TV without using the remote.
                • pacmyc
                  • Aug 2012
                  • 41
                  • Sweden
                  #48
                  OK.
                  No, I cant turn the TV on with the keys on the keyboard, only with RC.
                  (When TV has started they seem to work anyway, but if holding a button for more than 1 sec the TV turns off).
                  If key on keyboard is pressed it shuts down the PSU and TV wount start.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    @ Budm - not sure we are talking about the same transistor - I mean the one under the 4 pin connector on the main board.
                    @Pacmyc Are the 9 wires on a flat cable and inserted into the plug in order. Dont want to get them mixed up! if not you will need to label them. The wires and the metal connector can usually be pulled out of the plug- perhaps needs a tag moving with a very small screwdriver or similar. Remove a wire at a time and see what effect it has. Think you suggested that yourself earlier. Do we know what the 4 wire connector does I have assumed it plugs into the socket in this picture?
                    • pacmyc
                      • Aug 2012
                      • 41
                      • Sweden
                      #50
                      Yes it can be pulled out, but not while the connector is connected in the socket. I will try to cut the cables, and I'll be careful to label the cables.
                      No, that 4-pin socket on the motherboard is not connected to anything.
                      The other 4-pin socket on the LED Panel Control is connected to the Keyboard.
                      <Keyboard> ---(4-pin cable)---> <LED Panel Control> ---(9-pin cable)---> <Motherboard>
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #51
                        Not sure what you mean? I meant unplug the ninepin cable then take the
                        individual metal socket on the ends of the wire out of the plastic socket.
                        If its not too hard it will be easier than cutting and re joining
                        Dont ask me why, I thought the keyboard and panel were the same!
                        Out of interest would the keypad 4 wire cable reach the connector on the main board - odd it has the same number?
                        • pacmyc
                          • Aug 2012
                          • 41
                          • Sweden
                          #52
                          I did as suggested. It's pin 5 (3V3 stdby) on the 1M20 connector that needs to get disconnected in order to turn on the PSU.
                          With pin 5 disconnected I connect to mains.
                          PSU starts fine, white led flashes. TV starts.
                          Remote control doesnt work without pin 5 but keyboard do work.
                          I can reconnect pin 5 after the TV has started, and then RC works.
                          If keyboard button is hold for about 1 sec or more the PSU directly turns off.
                          Also important to know, the 3V3 voltage output on PSU is pending 3.1-3.2 V when the cable on 1M20 is connected (incl pin 3), but goes to stable 3.4V when it's disconnected.
                          Yes, I saw that the 4-pin socket on the mainboard has the same label. Probably it's used on other TV sets. I tested connecting my keyboard to this socket instead of the one on LED panel control board, but didn't notice any difference.
                          • pacmyc
                            • Aug 2012
                            • 41
                            • Sweden
                            #53
                            Pic on Post38
                            I measured the voltage on this transistor.
                            When TV is shutdown (and PSU is not working) I have a stable
                            0.65 V on pin B of the transistor (measured to ground on TV-chassis)
                            Nothing on E and C.
                            When PSU starts working the voltage on B is pending between 0.30 - 0.60 V.
                            Still nothing on E and C.
                            When mains are disconnected i get about 880 ohms from B -> C and B -> E. Nothing else.
                            • pacmyc
                              • Aug 2012
                              • 41
                              • Sweden
                              #54
                              I ran the TV with the 3V3 stdby line to led panel control disconnected (without reconnecting it after the TV has started).. Something must have happened because I now I cant start the TV at all.
                              The background light lits up for a second and then TV goes dead. It feels like the PSU cant supply enough current, or that there is a protection state kicking in. Maybe this well help further trouble shooting..
                              • pacmyc
                                • Aug 2012
                                • 41
                                • Sweden
                                #55
                                *bump* No more ideas what to try?
                                So TV goes to trash then
                                • STB
                                  • Oct 2012
                                  Hi!
                                  Replace capacitor 2170 (100uF) with a 1000uF elko. On my TV set the voltage drop when pressing the power button of +3V3-STANDBY reduces to 200mV which seems to be sufficient. My TV set works well since this mod.
                                  Regards,
                                  STB
                                  • pacmyc
                                    • Aug 2012
                                    • 41
                                    • Sweden
                                    #57
                                    Originally posted by STB
                                    Hi!
                                    Regards,
                                    STB
                                    Something strange about this capacitor.
                                    According to service manual "philips_chassis_q529.1e_la_sm.pdf" it first claims that this cap is a 100 uF 25 V (in the drawing). But, in the Spare Parts List the same service manual says 470 uF 6.3 V. Which one should it be? On the board it is a 470 uF 6.3 V.
                                    If you still think that I should replace it, what voltage should it be?
                                    • STB
                                      • Oct 2012
                                      In my TV was a 470uF 6V3 elko, i think it is worth trying 1000uF. The voltage rating should be at least 6,3V.
                                      Check with the multimeter the voltage drop reduces significantly.
                                      Regards,
                                      STB
                                      • pacmyc
                                        • Aug 2012
                                        • 41
                                        • Sweden
                                        #59
                                        Regards,
                                        STB
                                        OK. The only 1000 uF I've got is a 35 V.
                                        Is it allright to replace with this one?
                                        • Mr Bill
                                          • Nov 2011
                                          • 648
                                          It should be ok to test but i would order the correct one if it works.
                                          • osman68i
                                            Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
                                            by osman68i
                                            I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
                                            u2 is shorted. I can only read MX1 . cable goes to display panel....
                                            Yesterday, 01:55 AM
                                          • JorKsX
                                            Philips 47pfl6008s wont turn on
                                            by JorKsX
                                            Hello. Got my hands on Philips 47pfl6008s/12.
                                            Problem is that it does not turn on. Last owner said the problem came slowly.
                                            One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                                            And then it went into hours of unplugging and replugging until it turned on.
                                            When I plug AC into tv, it does not respond to "turn on" button or anything else.
                                            After 10-15minutes the TV starts blinking red LED twice.
                                            So it blinks twice, then waits 3 seconds, then again twice...
                                            02-13-2022, 03:36 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • ovrax
                                            Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                            by ovrax
                                            First of all, please excuse me as I'm quite new to this field.
                                            I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                            I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                            The Ambilight works perfectly and stays on.
                                            No sounds.
                                            Thanks in advance.
                                            08-25-2024, 04:33 AM
                                          • Henke
                                            Philips 55POS9002/12 shorted mains
                                            by Henke
                                            Hi.
                                            I have a Philips tv where the two main fuses are blown. I found a bad cap. I removed it, and now it seems to work. But i have to replace the cap. I do not have the exact same one at home. What's the purpose for it and what values can i use instead?
                                            Its placed across the Drain and Source on a N/Channel MOS
                                            The blown one is 101K, 1KV (check picture). I have 221K, 1KV at home, can i use that?...
                                            08-06-2024, 03:51 AM
