Samsung LNT4069FX/XAA no picture with sound
  • ceconomon
    • Oct 2011
    • 67
    Re: Samsung LNT4069FX/XAA no picture with sound
    The P/N of the adjustable regulator is:
    37302WU
    0735
    I'll have to find some scrap resistors to complete the test.
      Just use two 100 Ohms resistors since the regulator needs minimum 10mA load current.
      One resistor between output pin and the adj pin, another resistor between adj pin and Ground, this setup should make the output voltage to be about 2.5V.
        master hoarder
        • May 2008
        • 12175
        #43
        Originally posted by ceconomon
        I cleaned the back of the mainboard with alcohol. I've examined that area throughly with a magnifying glass and I can't determine the source of that mess. It looks like flux to me. Here are the new pictures.
        All of the ferrite beads tested good.
        Looks okay now, although there is quite a bit of heat discoloration from those linear regulators. I hope it's not a BGA issue. I'll wait until you confirm with the others that all of the regulators are good.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Originally posted by momaka
          The last thing I can think of is if some of those caps next to those voltage regulators have gone bad due to the excessive heat. But for that you'll need to have an ESR meter to check them with.
          That might be C104. It might just be easier to replace it and retest.
          --- begin sig file ---
          --- end sig file ---
          • ceconomon
            • Oct 2011
            • 67
            I got the resistors today and wired the test up. The results are below:
            pin1 2.99
            pin2 2.99
            pin3 0 GND
            pin4 2.461
            pin5 1.235
              You only using 3V power supply to feed this LDO? I am surprised it works pretty good since the input and out difference is only about 0.5V, they usually require the input voltage to be ~1.5 to 1.75V above the required output voltage.
              But any how, this regulator is good, use 5V power supply next time for testing.
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                When the LDO is "on board", the input voltage is only 3.415V so I suggested using 2 AA in series (as per post #22).
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  What is the DC voltage across C104? Black probe on negative and red probe on positive.
                  • ceconomon
                    • Oct 2011
                    • 67
                    C104 measures 1.836V
                    • ceconomon
                      • Oct 2011
                      • 67
                      I checked for voltage on every capacitor on this board(negative to ground and positive on each cap). I have voltage on all but two caps. The ones right next to the regulator that I replaced (C188 and C192).
                      Location C188
                      V1011
                      100
                      16J
                      Location C192
                      7e (glad I have a 20x magnifying glass)
                      22
                      16J
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        C104 could be bad. Unless you have an ESR meter and a multimeter than can measure capacitance, I suggest replacing it.
                        • ceconomon
                          • Oct 2011
                          • 67
                          I don't have an ESR meter, so I'll replace it.
                          Is this a 22uf and a 100uf 16V capacitor? I'll order both so my order is more than the shipping.
                          Location - C104
                          V1011
                          100
                          16J
                          looks like 6.6mm x 6.6mm
                          http://www.digikey.com/product-detai...0-1-ND/2533877
                          Location C188
                          7e
                          22
                          16j
                          looks like 5.3mm x 5.3mm
                          http://www.digikey.com/product-detai...8-1-ND/3438962
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            Location - C104
                            V1011
                            100
                            16J
                            Location C188
                            7e
                            22
                            16j
                            Those look correct. Normally, when these caps go bad, they blow the top dramatically.
                            • ceconomon
                              • Oct 2011
                              • 67
                              To bring everyone up to speed on this repair...
                              I tried replacing the cap and there was no change. I was still lacking any voltage on C188 and C192.
                              I was able to pick up a used board on ebay for $26. I would have like to fixed it at the component level, but sometimes it's not worth the battle.
                              Thanks for everyone's help.
                              3 TV's repaired and I'm looking for more.....I've caught the bug.
                                master hoarder
                                • May 2008
                                • 12175
                                #55
                                Well, you may not have fixed the original board, but I'm glad that you got the TV running.
                                Congrats!
                                • stinger381
                                  • Apr 2013
                                  • 42
                                  My Television is doing the exact same thing. Samsung sent a rep out and they put a new power board in the TV. I started getting the grey splotches and then the white screen. The tech told me I had a bad main board so I ordered one from Shop Jimmy, no change. So I thought it might be the T-Conn board and replaced that as well. I still get the solid white screen and sound on the TV. I can tell when the TV goes to commercials that the screen is changing as there is a little blink to it. The power light has a slow steady flash to it and never turns green. Any help would be greatly appreciated. Of course Samsung won't even respond to my requests any more. I don't believe the LCD panel is bad. HELP PLEASE!!!
                                  • ceconomon
                                    • Oct 2011
                                    • 67
                                    I replaced the LCD Controller Logic Board to resolve this issue. You can search for these on Ebay. I see two out there for <= $25 shipped.
                                    LCD Controller Logic Board BN96-06669A, BN41-00944A
                                    • stinger381
                                      • Apr 2013
                                      • 42
                                      OK thanks so much .... I had already replaced the main board and of course the power board. I even repaired the original power board thinking that it might be the cause. I don't have the skills to do all the testing listed in this post but swapping boards is easy enough.
                                      • stinger381
                                        • Apr 2013
                                        • 42
                                        Thanks again.... I have one on the way and I'll let you know if it solves my problem too!
                                        • salongaopm
                                          • Mar 2013
                                          • 13
                                          • usa
                                          #60
                                          Problem is: screen is white and gray with sound. I replaced power supply board, t-con, logic control, main board but still not working. The power/standby led is red and blinking continuously. What could be the problem? I spent too much already trying to fix this TV. Any help will be greatly appreciated. Thanks!
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • JohnML1975
                                            Samsung UA50TU8000W no picture and no sound
                                            by JohnML1975
                                            Hello All
                                            have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                            TV will not turn on
                                            There is no standby light
                                            When I press ON button for remote the red standby light does flash but no picture and no sound
                                            From the back of the TV I can see the red light on the back of the mother board
                                            Holding torch to the screen I cannot see a picture
                                            I removed the back cover
                                            Observing the boards I cannot see any damage
                                            I disconnected the main board from the power supply
                                            the back...
                                            08-30-2025, 09:40 PM
