Have I been sold a faulty T-con
  • blib
    • Feb 2012
    • 56
    Hi guys. I would appreciate your advise on this one.
    The TV is a LG42LH3000 with the left hand 50% of the screen being black. The fault is intermittent and tapping the Tcon board or surrounding area will clear the fault for a while.I have just replaced the Tcon which came from Ebay.I still have the same fault.Have I been sold a dud as I thought only the Tcon can cause this.
    Re: Have I been sold a faulty T-con
    Left hand screen black or just dark, with a visible picture? Sharp cut off between sides or gradual? Sounds more like panel, sadly...
    • JimmysTGP
      • May 2012
      • 45
      • US
      Yes, if you have replace the T-con and results the same then Panel was the problem originally. Sometimes I have been able to manipulate by Jamming something behind the TCP ribbon cable thats causing the Bad connection. However its not Permanent fix.
      • blib
        • Feb 2012
        • 56
        Yes Tom sharp cut off between sides. Left hand side completely dark.I have a feeling could be bad soldering on the tcon.Maybe its a common fault.I have just tried to reflow the ics on the board.Working at the moment.Fingers crossed.
        • Mt.Man
          • 53
          Try reseating the ribbon cables from the panel to the Tcon.
          • blib
            • Feb 2012
            • 56
            Yes have done that and cleaned with contact cleaner.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              also,try blasting some freeze spray on the panel ribbons if fault dissapears you at least know the panel is faulty,strange though that tapping the t con makes it better,as that wouldnt cause any movement on the panel ribbons, lvds yes,it must take quite a whack on the t con to make the fault dissapear
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • blib
                • Feb 2012
                • 56
                It did not take much of a tap,mainly on the big ic in the middle of the board.I think the replacement board has the same issue.Will keep you posted.
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  hmm sounds like a dry ic then ,that would be a good fix,did you use hot air and flux?
                  • blib
                    • Feb 2012
                    • 56
                    Yes.Hope the repair does not bounce
                    • selldoor
                      Slow Learner
                      • 7870
                      @Multimeter -Bit off topic but how does that work?
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        the freeze will crush up the bond between the ribbons and its contacts
                        • selldoor
                          Slow Learner
                          • 7870
                          Ok - thanks - would heating have a similar effect?
                          • netgearnetgear
                            TCL 43S423 TCON OR PANEL FAULTY???
                            by netgearnetgear
                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                            08-20-2025, 06:04 PM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                          • Daren87
                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                            by Daren87
                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                            08-13-2023, 03:25 PM
