This guy has an RCA 42PA30RQ
  • Bling23
    • Dec 2012
    • 153
    Re: This guy has an RCA 42PA30RQ
    same test and it didn't even budge..flat line with humming sound
      So both Y-main and X-main would appear defective. Can you repeat testing on Y-main with X-main unplugged?
      • Bling23
        • Dec 2012
        • 153
        the replacement y-main i purchased had a diode that the original y-main did not have but the board part number and rev all matched
        • Bling23
          • Dec 2012
          • 153
          with X-Main disconnected
            So... more or less the same. I would try replacing Y-main first. The one you got appears defective.
            • Bling23
              • Dec 2012
              • 153
              Great $40 down the drain!!!
              • Bling23
                • Dec 2012
                • 153
                There's a light bulb on the PSU near the AC input,,,Do you know what that bulb is meant to be?
                  It is actually a surge arrestor and shouldn't normally light.
                  One thing I did not immediately consider was the possibility of the control board being bad.
                  Can I see a picture of the control board on your TV? I think it's under the main board on this mode.
                  • Bling23
                    • Dec 2012
                    • 153
                    OK..coming right up
                    • Bling23
                      • Dec 2012
                      • 153
                      k
                        OK, can you check along this connector on each of the points I mark.
                        Set scope to 100us/div and centre horizontal (press the "HORIZONTAL POS" knob.)
                        If you see no waveform (more or less straight line), note that.
                        If you see a waveform, please take a picture or screen capture.
                        • Bling23
                          • Dec 2012
                          • 153
                          ok I copy
                            Oh and 2V/div with 1X probe is best scale.
                            • Bling23
                              • Dec 2012
                              • 153
                              NO waveform ....and how did you do the drawing on the photo?
                              • Bling23
                                • Dec 2012
                                • 153
                                oh cancel let me set the @V/Div and change probe X
                                  I used GIMP image editor, it's free software and works great.
                                  • Bling23
                                    • Dec 2012
                                    • 153
                                    Ok Tom..looks like I only get waveform when I power up and then it goes flat
                                      I suspect the control board.
                                      Have you tried this test?
                                      https://www.badcaps.net/forum/showpo...61&postcount=2
                                      • Bling23
                                        • Dec 2012
                                        • 153
                                        no i haven't but i think your right
                                        • Bling23
                                          • Dec 2012
                                          • 153
                                          let me do that test
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
