This guy has an RCA 42PA30RQ
  • Bling23
    • Dec 2012
    • 153
    Re: This guy has an RCA 42PA30RQ
    If the Ve voltage is low or missing disconnect the power supply cable from the X board. If the Ve voltage rises the X board is probably shorted. If the voltage stays low the SMPS board needs to be replaced. If the Vs voltage is low or missing it can be caused by a defective X or Y board. Check both boards for short circuits before replacing the SMPS board. If the Vs voltage is too high an effect called diffusion may occur. Diffusion is when the initialize voltage is too high. Excessive voltage causes unwanted pixel firing creating intermittent sub-pixel flashes. Power on-off cycling can be caused by a shorted component on the Logic board loading down the standby 5V.
    • Bling23
      • Dec 2012
      • 153
      That text is from the manual I downloaded. However my TV doesn't state what the VE voltage should be. It only has Va and Vs and Vsc
      • Bling23
        • Dec 2012
        • 153
        Tom do you know to use ESR meter to locate a short to ground on the curcuit trace?
          Ve is around 70~130V.
          • Bling23
            • Dec 2012
            • 153
            Ok mine is at 64
              Hmm, 64V may be OK, seems a little low, but you should still get a picture.
              • Bling23
                • Dec 2012
                • 153
                That's with the X-Main disconnected
                • Bling23
                  • Dec 2012
                  • 153
                  I Ve is missing with X-main connected
                  • Bling23
                    • Dec 2012
                    • 153
                    Disconnected X-main for re test and Ve volts are 62.5v
                    • Bling23
                      • Dec 2012
                      • 153
                      Re checked Ve at the Y-main again and it's down to 59v...dismay that's pretty low voltage
                      • Bling23
                        • Dec 2012
                        • 153
                        I'd say not dismay
                          There is possibly a Ve short then.
                          • Bling23
                            • Dec 2012
                            • 153
                            Hmm where would you think that Ve short is coming from, PSU or other board?
                              X-main.
                              • Bling23
                                • Dec 2012
                                • 153
                                Duh!!! I lost my train of thought for a second...ok I'm going to take a break from this Tv until my replacement X-main arrives. I hope that takes care of the problem. It should be here on the 15th. In the mean time ill be doing more learning and research on how to fix electronics such as LCD and plasma TV's
                                • Bling23
                                  • Dec 2012
                                  • 153
                                  I LOVE WORKING ON THIS STUFF!!!!!! Troubleshooting is fun
                                  • Bling23
                                    • Dec 2012
                                    • 153
                                    I just discovered something interesting.. When I connected the ribbon cable that goes from the logic board to the Y-main, My Va and Vs and Ve drop just after power up. When I disconnect the ribbon cable and power up the TV, My Vs Va are stable
                                      This seems to indicate something on the Y-main is forcing the control board to shut the TV off.
                                      • Bling23
                                        • Dec 2012
                                        • 153
                                        Could be the control board is bad. I do recall the tv had no problem powering up prior to me removing the original Y -Main. Ever since I reinstalled the Y-Main I ran into this mess with the Tv not turning on
                                        • Bling23
                                          • Dec 2012
                                          • 153
                                          I meant could it be the control board is bad
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Mgiffune
                                            by Mgiffune
                                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                            I ordered a supposedly β€˜new' Tcon board this time, and
                                            06-09-2024, 10:28 AM
                                            03-31-2024, 02:12 PM
