This guy has an RCA 42PA30RQ
    Re: This guy has an RCA 42PA30RQ
    not sure if I did this right with the bitmap but lets see
      Nope I guess not
        It worked, no thumbnail but it loads on my laptop. Something is definitely wrong. Can you repeat with the Y-buffer unplugged?
          oh I did get it right..I can see it on on my ipad
            oh that was with the y-buffer ribbons disconnected..let me hook them back up
              I mean for the whole buffer board to be removed, not just the connectors.
                ok
                  y-buffer disconnected
                    More or less the same. So Y-main or control board is failed. Can you repeat the test on the X-main side?
                      i replaced the Y-Main yesterday and my x-main has a humming sound coming from it. I checked for shorted components and found q4001 was shorted. its a RJP30E2 0712 part number. i had some new RJP30E2'S i had ordered for the old y-main board, so i replaced the shorted on on the x-main but that didn't do anything to fix the problem. so i ordered a replacement x-main.
                        this is the waveform when probing the VE testpoint on the y-main
                          Interesting -- definitely something appear shorted. However, I meant to test the X output. This is what goes to the orange ribbon on the righthand side.
                            Ok but i think i have a bad fet on that board..the Q4001 AND Q4007
                              my X-Main is dead,,it hums and no reading on the VE test point
                                Can I atleast see the output? Right now I think that both X and Y are bad.
                                  ok
                                    where do you want me to hook up probes on the x-main..on the VE testpoint?
                                      On C4020, the leg closest to the black connector.
                                        this is how i have it set up
                                          Looks good to me. Your X-main is slightly different to my spare one -- mine does not have that diode -- but it's similar enough.
