Magnovox 32MF231D
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: Magnovox 32MF231D
    Originally posted by TechShui
    Yes, I did use a magnifying lens, there are not a lot of numbers that look like zero, so it has to be a zero or an eight, maybe an R, but I don't think so.
    Resistances less than 10 ohms have 'R' to indicate the position of the decimal point (radix point).
    http://en.wikipedia.org/wiki/Resistor#SMD_resistors
    --- begin sig file ---
    --- end sig file ---
    • TechShui
      • Jun 2011
      • 148
      Yes, I know what the R stands for, but it doesn't really look like an R, more like an eight.
      This is the last letter I'm referring to, so 40R and 400 are both 40 ohms, but an eight would mean 4,000 mega ohm.
      EDIT: Took me a dozen tries, but I was finally able to focus the camera in such a way that it gave a clear focused zoom. I think it says 480, that would be 48 Ohms.
        From logical point of view, they do not have 4000 Mega Ohm resistor, it may as well be a open circuits. I did not follow the post lately to know how this resistor is connected to the circuits.
        • TechShui
          • Jun 2011
          • 148
          Let's get back on track here.
          These resistors connect to pin 5 of the 7003 IC.
          480 = 2.77k Ohms
          273 = 3.4k Ohms
          221 = 220 Ohms
          The sch that budm attached on page 3, shows it like this:
          Pin 5 > 3K09 (3005) > 27K (3007) > 220R (3006) > 1000u 16 cap (2006) > 12VS
          What's this mean? The one labeled 480 is actually 3.09K Ohms... ?
          And what about the 27K having a reading of only 3.4K, what could diminish it's resistance while in circuit.
            3K09 (3005): The 3005 is the designator number for this 3k09 resistor, most diagram would have use R3005).
            If you look at the Diagram:
            2xxx is for capacitor
            3xxx is for resistor designator.
            6xxx is for Diode
            7xxx is for Transistor
            But where do you see the 480 in the diagram?
            • selldoor
              Slow Learner
              • 7870
              #66
              I have been lazy and not read the thread but is this information any help:
              http://www.scribd.com/doc/50623833/2...f231d37TPE1-0U
              Again didnt understand all the posts about 40R being the same as 400 etc I thought it would be 40R=40.0 but on smd components the R label is only used up to 10 ohms so that argument seems invalid.
              Furthermore I am not now sure if budm is thinking 480 "label" is on the board or the schematic whereas I think TechShui means the "value" printed on the component.
              The 480 value on the component in my opinion means that it is a 48ohm resistor which does not show at all on the schematic. As we all know that is not unusual as boards and schematics often differ.
              In broksonics pic the component is quite clear tho not readable on screen I suggest you pm him and ask what value is shown on his save any guessing .
                Yes, I am thinking about the 480 for deisgnator in the diagram which I do not see. The board itself does not seem to have any designator for the resistors at all.
                • reckhardt
                  • May 2012
                  TechShui,
                  I am working on the same board (except 6285.3) as you and have some bad news. The 10 ohm resistor you replaced at what looks like 3U22 was not 3U22. 3U22 is actually the 1206 size resistor labeled "100" close to the last "2" in "3U22" on the board.
                  The part you replaced with a 10 ohm resistor is actually 2U16 which should be an 0805 size, 1uF, 16V ceramic capacitor.
                  Also, the resistor that looks like 480 definitely says 488 on my board (see attached). I am bewildered by this as well. It appears to be part 3005, a 3.09k ohm resistor judging by the connections on the board.
                  EDIT: Here about half-way down, it explains a new resistor code. This explains the 48, but the other 8 must be an A for it to work out to 3.09K.
                  • selldoor
                    Slow Learner
                    • 7870
                    #69
                    WOW -Reckhardt, thanks for registering to tell us- that is a revelation - not come across that coding - doesnt seem to feature in WIKIpedia.
                    I think you may have tripped at the last hurdle though I think it is a 48B
                    48 = 309ohms x B (10) = 3090 = 3.09k
                      http://www.marsport.org.uk/smd/res.htm
                      48 = 309 ohms
                      B = 10
                      = 3.09k ohm
                      • reckhardt
                        • May 2012
                        Doh! Yes, 48B would make 3.09K. My mistake.
                        • TechShui
                          • Jun 2011
                          • 148
                          Thanks for reminding me about it, I discovered a similar post last month, I shared it in this same thread, post 28.
                          broksonic suggested I test the crystal IC with a frequency tester (or DMM with that feature). I can see those little grey caps on the output traces for the 1H00 IC. Those caps are indeed smaller than fly shit, I think I'll need a special tip to desolder them... hmm.
                          But I don't have a capacitance meter either. I guess I will have to get all these tools in order to confirm my suspicions.
                          Originally posted by reckhardt
                          TechShui,
                          Thanks for noticing that, I guess I will cannabalize 2u16 from my rev 3 board to replace that component.
                          • broksonic
                            • Apr 2012
                            • 25
                            • usa
                            #73
                            Sorry for being gone so long. Work called me OTR for awhile and when i got back computer was fried. Had a storm come through and must have got it.
                            I ended up getting a different scaler board. Just installed it today and tv back up and working although havent pluged it into DTV receiver yet but screen comes up and menu does too.
                            Going to be a few days before i close it up ( need a new card for my other Direct tv receiver) is there anything you want checked while its open with a working scaler board in it?
                            Forgot to mention that there are 6 or 7 other scalers that supposedly work with this tv. If you want a list of the ones i found let me know. Dont have the list in front of me or i would post them now.
                            • TechShui
                              • Jun 2011
                              • 148
                              Hi broksonic,
                              It looks like I'm too late to take you up on that offer, by now you've probably put the TV back together?
                              That's OK, I think history has shown us that the most common failure is the crystal IC (1h00) and/or the tiny gray caps.
                              But please save me your old dead scaler board, I will have some money in my paypal acct next week, and will send you some money if you're willing to ship it to me? You can use the same box the new one came in, just cover it with a new shipping label.
                              Yours did not have a hole in the smps 12VS chip... so maybe it will be an easier fix, or I can salvage the components to fix mine.
                              • broksonic
                                • Apr 2012
                                • 25
                                • usa
                                #75
                                TechShui, yes i still have the board. PM me a offer (which im sure i will take).
                                Also had a request for the ALT part numbers for that scaler board so here they are.. ( i havent tried any of these as an alternate, so understand using at your own risk)
                                313815886271
                                313815864951
                                313815866861
                                313815866881
                                313815868521
                                313815868281
                                313815868211
                                313815868221
                                313815866721 (which was my original)
                                Currently only see one at a fair price on E-bay
                                http://www.ebay.com/itm/Philips-32mf...item3cc73e1932
                                • Elecfronicsssss
                                  DA0NJJMBAG0 charging light blinks
                                  by Elecfronicsssss
                                  Laptop motherboard DA0NJJMBAG0
                                  PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                  CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                  GUIDE ME WITH THE PROBLEM..
                                  SUMMARY-
                                  1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                  2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                  05-12-2025, 02:32 AM
                                • icareservicezone
                                  Synology DS918+ blue light blink
                                  by icareservicezone
                                  Synology DS918+
                                  Model name : GDI41L2
                                  p/N: 08-06GDI4116
                                  Version: V1.6
                                  Problem : blue light blink...
                                  05-24-2025, 11:53 PM
                                • mecha1166
                                  XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                  by mecha1166
                                  I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                  07-01-2024, 05:47 PM
                                • djordje
                                  Philips 55 oled 804/12 red light blink
                                  by djordje
                                  Hello all,
                                  I have Philips Oled 55 (804/12) with black screen and red light blink.
                                  I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                  Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                  When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                  My questions is what should i do next...
                                  01-03-2025, 04:00 PM
                                • roxboy1984
                                  Lenovo ideapad 3 no power, orange light blinks once when charger inserted
                                  by roxboy1984
                                  Hi guys,
                                  I wonder if anyone has encountered this. I have a Lenovo ideapad 3 that shows no signs of life except when the charger is first inserted the orange charge light comes on for a brief second and then goes off. There is no other sign of life and no fans or lights come on.
                                  if I check the voltage going to the battery it spikes when I insert the charger and then hoes back down.
                                  i tried injecting 2V but nothing gets hot. Any ideas? Im still a noob.
                                  Yesterday, 06:00 AM
