Synology DS918+ blue light blink
  • icareservicezone
    • May 2025
    • 13
    • Bangladesh
    Synology DS918+
    Model name : GDI41L2
    p/N: 08-06GDI4116
    Version: V1.6
    Problem : blue light blink
  • kity92
    Edifier x3 Earbuds Blue Light Problem (Charging Problem)
    by kity92
    I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
    Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
    01-13-2022, 01:49 PM
  • Tomylee
    Nintendo 2DS XL – Orange light, no blue light, signs of overheating
    by Tomylee
    Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
    Here's what I've observed:
    All ribbon cables are properly connected
    Battery is present and in good condition
    No reaction even with screens disconnected
    There's a visible burn mark / overheating sign on the metal shield, right above the CPU
    I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
    06-26-2025, 02:33 PM
  • pixelcap
    Pioneer Kuro Pro 111FD 8 red blink error
    by pixelcap
    Pioneer Kuro Pro 111FD 8 blink red LED.
    I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
    So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
    based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
    10-06-2024, 11:26 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • blind2reply
    proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
    by blind2reply
    proscan 40ld45q
    Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
    After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
    No sound, no picture (used flashlight test).
    No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
    Digital voltmeter;...
    06-06-2021, 01:16 PM
