Viore power issues!
  • YOUNGGUNS
    • Mar 2012
    • 8
    • AMERICA!
    Viore power issues!
    i have a 42 inch viore tv. when its plugged in and i press the power button it dont even try clicking on i opened the back of it to look at the caps and they all look to be in good shape but i could be wrong seeing as im a noob. I'll post pictures ASAP. But if its not the caps then what other problems could i faceing?
  • YOUNGGUNS
    • Mar 2012
    • 8
    • AMERICA!
    Re: Viore power issues!
    Anybody?
      Lets us see the good clear pictures of the whole chassis as how the boards are connected together, then the pictures of the boards top and bottom sides first.
      Good pictures of the coonectors are also needed so we can tell you which pin to test for the voltages or shorts circuits.
      Mkae sure they are good, clear pictures since we are trying to do long distant troubleshooting here.
      • selldoor
        Slow Learner
        • 7870
        Full model number of the tv and any board identification numbers including version will be useful
        Some history of the set would be useful - owned for 2 years or found in a field makes a big difference. Have you seen it working? Also do you have a multimeter and soldering iron and can you use them.
        • YOUNGGUNS
          • Mar 2012
          • 8
          • AMERICA!
          I got it from a friend who got it from a guys house gave it away because it wouldn't turn on one day.
          Model# pdp42v18ha
          board# jht0608-003291
          • selldoor
            Slow Learner
            • 7870
            Pictures are not big enough - they need to be as near as you can get to 2mb jpgs no bigger than 2000x2000
            This is an exmple of what we need https://www.badcaps.net/forum/attach...1&d=1290283049
            Content as per BUDMs post above
            SERVICE MANUAL http://www.servicetron.com/uploads/2...pdp42v18ha.zip
            • YOUNGGUNS
              • Mar 2012
              • 8
              • AMERICA!
              I have a soldering iron but no meter i think the boards fryed because in the picture with my finger im pointing at 2 objects that have the solder touching and under the board theres a black mark on the back of tv screen.
                From the back of the TV, is the board on the left or the right of the screen?
                One board is the Y-sustain and the other is a Z-sustain.
                Both will usually have fuses on them, are any blown?
                You are going to need a multimeter to debug this... you can pick one up for $4 from most good DIY stores.
                • YOUNGGUNS
                  • Mar 2012
                  • 8
                  • AMERICA!
                  is this big enough just click on the pics
                  the one with the finger is pointing at a bad solder job where its soldered there are two completly different components touching and theirs others on there touching in the same fashion as well with little "fryed" black marks around them the picture with the metal is the back of the screen theres a black mark that came from the pic where my fingers pointing.
                  • YOUNGGUNS
                    • Mar 2012
                    • 8
                    • AMERICA!
                    So thanks kind sirs i figure my problem is that the power board is fried and i was wondering if the power board is fried then is it possible that the other boards dont work? Please give me a response asap im on a tight time schedule and my family is depending on me to bring home the bacon any help is much appreciated!
                    • Paul678
                      • Nov 2011
                      • 402
                      Friend, at the absolute minimum, you need a digital
                      multimeter to fix these TVs, as Tom has pointed out.
                      You need to measure the voltages coming off the main
                      power supply. You cannot just tell by looking at them
                      if they are working properly.
                        A little burn mark on the bottom of the board is not necessarily your problem. It could have been, e.g. a "dust bunny" connecting between Vs and GND. You should post pictures of the top side of your PSU where all the components are.
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • zlr8r
                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                          by zlr8r
                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                          Ill try and give as much info as I can.
                          Dell Inspiron 17 (7786) Laptop
                          Service Tag: 5J0NHT2
                          Bios: 1.9.0
                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                          Then it started getting weirder!
                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                          12-12-2023, 09:31 PM
                        • sli4
                          Original NES power issues
                          by sli4
                          I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                          I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                          Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                          On the big blue connector I get...
                          11-28-2024, 12:52 PM
                        • Mgiffune
                          by Mgiffune
                          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                          I ordered a supposedly β€˜new' Tcon board this time, and
                          06-09-2024, 10:28 AM
                          09-06-2024, 05:59 AM
