technosonic lcd3201s
+ More Options
Posts
  • senndogg
    • Dec 2011
    • 383
    • Albania
    this is my first effort to repair a lcd tv. i have managed to repair several pc displays, everything thank to you.
    this tv has the known "2sec to black" issue. i have read the FAQs and i know the basics but since im new to TVs i would need some advice, tips and tricks.
    this tv has been opened before because it had caught fire due to external factors. (a candle fired the antenna cable which burned the 75ohm connector). but the 2sec to black came months later.
    you can see the pics and first thing, the CCFL and inverter test is a bit "difficult" to do, cos i think ill have to dismantle all the tv structure, process which i want to postpone as much as i can. (as i am not used dealing with huge panels)
    first thing in my hand is the power board. steady 24V and 12V. when power button is pressed a 3,3V is shown at the pin "LCD ON". even when i unplug the inverter connector, 3,3V is there when i press the power button. should i go further and dismantle to go to the inverter board and CCFLs or it can be power board related?
    some pics of what can i actually capture.
    Re: technosonic lcd3201s
    You would need a picture of the inverter boards. There are usually one or two, on each side of the TV. The part # on some of the boards looks a lot like Darfon, and those inverters have very high failure rates (and are easy to repair.)
    • senndogg
      • Dec 2011
      • 383
      • Albania
      god saved this tv for not breaking anything.... i cautinously (but blindly) took all pieces apart. now i have access to everything.
      this is the inverter board, all inverters show 2.15 kOhms except the seventh which shows 2.55 kOhms. after some minutes im gonna plug everything and see how many CCFLs do light.
      another question, what is this 2pin connector which goes to the inverter board? some kind of sensor?
      anyway, im gonna let you know.
        The Connector with the black and white wires are the lamp return wires.
        Please also look and see if the lamp assembly has any ballast caps in it also and see if they are bad. Example:
        http://s807.photobucket.com/albums/y...nt%20FLX-3210/
        • senndogg
          • Dec 2011
          • 383
          • Albania
          at the moment no more 2sec to black, but as you can see one CCFL which is fed by the seventh inverter doesnt lit.
          next step?
            Swap the connectors for the seventh and eighth tubes around and see if the tube lights. If the tube lights and now the eighth tube doesn't then the inverter is at fault and most likely it's that transformer.
            The 2.55k definitely sounds like a faulty transformer but that test will confirm it.
            It looks like you've got a Chi-Mei inverter but it has Darfon parts on it - I recognise those transformers.
            Be -extremely- careful with the LCD as it is very easy to damage.
            • senndogg
              • Dec 2011
              • 383
              • Albania
              thanx tom. i followed my logic and just did it.
              the tube lights when connected to other another inverter and the couple of CCFLs connected to the "faulty" seventh inverter, lights only one of two.
              solved: inverter no 7 faulty!
              where can i get that?
                What's the part number on it? 4xxx or 6xxx?
                • senndogg
                  • Dec 2011
                  • 383
                  • Albania
                  4xxx. googled but showed nothing
                  could only buy the entire board.
                    Rest of part #?
                    • selldoor
                      Slow Learner
                      • 7870
                      Its a 4003L isnt it
                      http://www.ebay.co.uk/itm/4003L-CCFL...item460194fce0
                        You tell me! What is the full part number?
                        • senndogg
                          • Dec 2011
                          • 383
                          • Albania
                          yes! photo in the link is incorrect, it is exactly like this http://www.ebay.com/itm/4003L-Invert...ht_1526wt_1396
                          • senndogg
                            • Dec 2011
                            • 383
                            • Albania
                            4003L 614078 (GP). but it says works for all 4003L models.
                              I think you have found the problem, these DARFON Inveter board most of the time had bad transformers in them.
                              http://lcdparts.net/TransformerDetai...ProductID=2731
                              Very cheaply made.
                              • selldoor
                                Slow Learner
                                • 7870
                                My belief is that only the first 5 digits are relevant, the rest being manufacturers information dates batch codes etc.
                                The whole number is however quite clear in Senndoggs pictures. I am sorry if the pic in the ebay link confused anyone - I didnt even look at it. I expect he has used the same picture for all his Darfons as he has a large range.
                                • senndogg
                                  • Dec 2011
                                  • 383
                                  • Albania
                                  thank you!
                                  • senndogg
                                    • Dec 2011
                                    • 383
                                    • Albania
                                    Very cheaply made.
                                    thank you too!
                                    is there any possibility to repair an inverter?
                                      thank you too!
                                      The repair involves replacing the transformer which costs £10. I have done it twice before on Darfon boards. All you need is a soldering iron, some solder and a bit of patience. I generally stick the iron under each pin and lightly pull them up until the old transformer is removed. Then, I replace the transformer and solder opposite corners down, then the remaining pins. Take care to replace the transformer such that it is the same way as it was before, there's usually a dot on it indicating alignment.
                                      • senndogg
                                        • Dec 2011
                                        • 383
                                        • Albania
                                        thank you tom. i have the inverter in my hand right now. i was asking in fact if i could repair the defective inverter, but as i see its not possible.\
                                        cheers.
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
