Samsung LE37A556P1F Flashing red light
  • Jasgriff
    • Feb 2012
    • 578
    Hi All,
    Can anyone help me work our what I need to do next.....
    I bought this tv and it was turning itself off after a minute or two. I took it apart and noticed that the were a few bad capacitors on the board. I changed all of these capacitors with ones of the same value and then hoping that I had fixed the problem I put it all back together.
    Unfortunately the problem was still there. I then decided to disconnect the touch panel on the tv incase that was faulty and causing the TV to turn off but This still didnt help.
    When the TV did turn on the screen came on as it should with the No Signal message before it turned itself off.
    Now the TV wont turn on at all. The red light just flashes 4 times and then goes to solid red.
    I have attached a pic of the board and the board model number.
    I am sure with your help I can finally get this up and running
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
  • TechAMP
    • Dec 2011
    • 9
    Re: Samsung LE37A556P1F Flashing red light
    Hello people. My Samsung LE37M86BD TV has got black screen. The power supply provides all the voltages needed to, but it will not turn on, even though the "Power Button" you can see that it is on! There comes a glimpse of the backlight for a few milliseconds and then disappears.
    Is there anyone who knows about this?
    Thank you in advance.
    • TechAMP
      • Dec 2011
      • 9
      Re: Samsung LE37M86BD wont turn the screen!
      • retiredcaps
        • Apr 2010
        • 9271
        1) Did you replace all the capacitors or just the obviously bad ones?
        2) What brand and series did you use for replacements? For example, Panasonic is the brand and FM is the series.
        3) See my standard answer regarding replacing capacitors at
        https://www.badcaps.net/forum/showpo...84&postcount=3
        4) Do you have a multimeter and are you familiar with measuring DC voltages?
        5) If you have a multimeter, please post a picture of it.
        6) We will need clear focused pictures to suggest test points. The ones you posted are way too grainy to make out any detail. We will also need a picture of the main board.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          We need clear top down focused pictures of both sides of all your boards uploaded to this forum in order to suggest test points. Follow the instructions in my sig file below exactly.
          • TechAMP
            • Dec 2011
            • 9
            Thanks for the response! Her is som stuff to look at:
            • Jasgriff
              • Feb 2012
              • 578
              All of the capacitors were replaced except for the massive one.
              5 x 35v 1000uf 105c (SD CD263)
              1 x 10v 3300uf 105c (KY)
              1 x 10v 2200uf 105c (FR 1390F)
              2 x 25v 1000uf 105c (SD CD263)
              I have to hold my hands up they are the first I could get my hands on so I can imagine they might not be favoured brands.
              I will have a read up on this now.
              Yes, i have some knowlege measuring DC Voltages.
              Yes I recently purchased a UNI-T 132A. I have attached a picture of it below.
              Sorry for the poor picture I didnt have my camera to hand. I have attached a picture of the exact same board that I found on on the net which also has the capacitors values written on them. I will have to attach the bottom on a second post as this wont attach in this one.
              Thanks again for your help...
              • Jasgriff
                • Feb 2012
                • 578
                Here is a picture of the underside of the board.
                The mainboard is an MT8226_EMMA BN41-00974B I will work on trying to get an image of this for you.
                • TechAMP
                  • Dec 2011
                  • 9
                  • Jasgriff
                    • Feb 2012
                    • 578
                    Right I have had another play with this TV to try and give you as much info as possible.
                    If you look at connector 1 on the attached Pic The pins are labelled and tested as follows.
                    NC - N/A
                    ADIM? - Untested
                    BL - Untested
                    NC - N/A
                    GND - Tested OK
                    GND - Tested OK
                    GND - Tested OK
                    GND - Tested OK
                    GND - Tested OK
                    24V - Tested OK
                    24V - Tested OK
                    24V - Tested OK
                    24V - Tested OK
                    24V - Tested OK
                    Connector 2 Left to right
                    BLU - Untested
                    Adim - Untested
                    PWM - Untested
                    GND - Tested OK
                    +5v - Tested OK
                    I also tried.....
                    Connector 1 Connected
                    Connector 2 connected
                    connector 3 connected
                    Screen remains blank and the red standby light flashes a few times then goes off. when I press buttons on the remote the stanbylight flases as I would imagine it would during normal operation. If I press the poer button on the remote control the standby light changes to solid red again as I would imagine it does during normal operation.
                    Connector 2 Disconnected
                    Connector 3 Connected
                    The backlight come on and the TV behaves exactly as mentioned in the scenario above.
                    Connector 2 Connected
                    Connector 3 Disconnected
                    Nothing at all.
                    Not really sure where to go next?
                    • Jasgriff
                      • Feb 2012
                      • 578
                      Ok just tried something else.
                      I am guessing that PWM on connector 2 on the power supply need a must be the a trigger that the mainboard sends to the PSU to tell it to turn everything on.
                      I tested this by connecting up connector 1 and connector 2 the on the mainboard I found the pin that would supply the power supply with a logic signal and tested it with a multimeter. It seems to be giving out +3.1v.
                      Should this voltage be higher to tell the power supply to turn on?
                        Do you have sound when the TV is turned on?
                        Have you got all the inverter power cables properly secured; including the cable that is sometimes present going from T-con to power supply?
                        • Jasgriff
                          • Feb 2012
                          • 578
                          No sound through any combination of cables that I have tried.
                          Just tried taking the connectors off and reconnecting them nice and secure but there is still no sound.
                          • py3m4n
                            • Jul 2011
                            • 99
                            • Scotland
                            My response is to Jasgriff. Why has TechAMP ambushed Jasgriffs thread, lol.
                            Sounds like you might have a corrupted eeprom on the mainboard. Was it caps on the power supply that you replaced? I know with the LE40R88BD series that this is quite common (seen it myself) where after replacing the capacitors on the power supply the eeprom is corrupted on the mainboard the first time you boot the T.V. All that said, I am not sure if this will apply to your model but it can't do any harm to look into it.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              1) Hookup a DVD source playing a movie. Plug it into the TV. In dark room, can you see the DVD playing without the backlight on? Try shining a flashlight on it. Is there sound?
                              2) Circled in red are some ICs. What is the part number?
                              3) The pics are good, but resolution is a bit small on the inverter board. I circled what I think are SMD fuses. A fuse should be marked as something like F100 on the pcb.
                              A single blown fuse could be causing the backlight not to come on. Check them with your multimeter. A good fuse should measure less than 1.0 ohms.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                24V - Tested OK
                                24V - Tested OK
                                24V - Tested OK
                                24V - Tested OK
                                24V - Tested OK
                                We prefer the actual readings. I have no idea of your background and/or level of knowledge so "OK" means nothing.
                                If you wrote instead
                                24V - measured 24.01V
                                then, I would agree the voltage is OK.
                                PS. We want pictures of your board, not some stock photo. A stock photo does not show hot spots, glue turned conductive, burnt resistors, etc.
                                  Connector 1 these signals go to the Inverter board
                                  The ADIM, BL signals are passed through from Connector 2 which connected to the main board.
                                  NC - N/A
                                  ADIM? - Untested: Backlights dimming voltage (0=min, 5v = max brightness)
                                  BL - Untested: Backlights on
                                  NC - N/A
                                  GND - Tested OK
                                  GND - Tested OK
                                  GND - Tested OK
                                  GND - Tested OK
                                  GND - Tested OK
                                  24V - Tested OK
                                  24V - Tested OK
                                  24V - Tested OK
                                  24V - Tested OK
                                  24V - Tested OK
                                  BLU - Untested: Backlights ON signal from the main board (3.3~5v = ON)
                                  Adim - Untested: This pin gets the 0~5vdc Dimming control signal from Main board
                                  PWM - Untested: This pin is not used, it is the Pulse Width Modulation signal (another method of Dimming the backlights) from the main board for Dimming control, is not used on this set.
                                  GND - Tested OK
                                  +5v - Tested OK: 5Vdc to the main board
                                  So you need to have the BL 3.3~5VDC on this pin for the Inverter to come on, you already have the 24vdc, you just do not have the ON signal per your post.
                                  • Jasgriff
                                    • Feb 2012
                                    • 578
                                    Hi Py3m4n,
                                    I changed all of the capacitors on the cold side of the board and it came on a couple of times for a few seconds then straight off sometimes you could hear a high pitched noise or scream coming from the mainboard by the sound of it.
                                    When I get back from work I will start to check the mainboard I will also take some good pics of it so that you can point me in the right direction of what to check.
                                    Ta for your help.
                                    • Jasgriff
                                      • Feb 2012
                                      • 578
                                      Sorry,
                                      24V - 24.3v
                                      24V - 24.3v
                                      24V - 24.3v
                                      24V - 24.3v
                                      24V - 24.3v
                                      I will sort out some better pictures when I return home from work. I used those stock photos just to see if there was anything thing that could be tested whilst I had the day off twiddling my thumbs
                                      Cheers for your help.
                                      • Jasgriff
                                        • Feb 2012
                                        • 578
                                        NC - N/A
                                        NC - N/A
                                        GND - Tested OK
                                        GND - Tested OK
                                        GND - Tested OK
                                        GND - Tested OK
                                        GND - Tested OK
                                        24V - Tested OK
                                        24V - Tested OK
                                        24V - Tested OK
                                        24V - Tested OK
                                        24V - Tested OK
                                        GND - Tested OK
                                        While testing connector 1 with connector 2 and 3 plugged into the mainboard I get the following...
                                        Adim = 0v
                                        BL = 0.1v
                                        This is in the on state where if connector 1 was hooked up it would give me a completely blank picture.
                                        With connector 1 and 3 connected I tested connector 2 on the mainboard.
                                        BLU = 0.1v
                                        Admin = 0v
                                        PWM = 3.2v
                                        Ta for the help with the pins this will help when I am do a little more testing tonight.
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                          09-07-2024, 05:50 AM
                                        • Phil289
                                          Samsung UE46EH5000 - Flashing red light but not turning on
                                          by Phil289
                                          Hi
                                          I aquired a Samsung UE46EH5000 from a lady that said it was turning on and off so she just purchased a new one.
                                          On plugging into the mains and turning on i get a solid red light.
                                          On using the on/off button or remote i just get a flashing red light in a pattern of flash/flash gap flash/flash gap flash/flash etc.
                                          Opened it up and disconnected the main board from the power board by removing the connecting ribbon cable with the hope of getting either a 'no backlight' or a 'working backlight' but got neither,i just got a blinking backlight that turned on and off randomly...
                                          07-25-2022, 01:46 PM
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
