HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
  • esqmooo
    • Jul 2024
    • 5
    • DRC
    Hello everyone.
    This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
    Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
    Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
    I tried long pressing on the power button, after several seconds it would go off then when the button is released the power button light would flash for half a second but the charging light would still on - this light goes directly on when power source is connected - even the battery!.
    Before completely going dead, sometimes when trying to force it to power on, only the fan would spin fast without anything on the screen or keyboard light.
    I opened it, connected the charger and I could feel one coil (I guess it is one - 1R0 2127) would get a bit hot. (not happening anymore)
    I have basic knowledge on electronics but I can learn fast.
    I have a multimeter. a soldering iron...
    Anyone can help troubleshoot this issue? I can work anymore since this is my main machine.
    Please feel free to ask for more info and I'll provide them.
    Best regards
  • mon2
    • 14669
    Which charger IC is on board? Hunt for this part and share the top side markings. It may be the popular BQ charger chips by Texas Instruments. Square in shape with black body. Post pics.
    • learnmore
      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
      by learnmore
      Hello Community!
      CASE DETAILS
      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
      Tried inserting firmware on USB and left it in for a few hours, but no change
      03-03-2024, 09:49 AM
    • esqmooo
      HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
      by esqmooo
      I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
      03-07-2025, 05:55 AM
    • Patan
      Dead LA-H323P (no light) - HP 15-DW
      by Patan
      Need help here...
      I'm new on the forum and I'm not professional in electronics so i ask sorry in advance for eventual errors...
      As title says, i have a LA-H323P dead.
      Now, little background.
      The computer was working fine, just seems that the cable of screen was dying because it had the classic color problem, sometimes green, sometimes violet, sometimes perfect, but anyway working.
      When i opened it the battery was so fat that was seriously near to explode.​
      So i removed the battery... and turned on the notebook... that was, again, working perfectly fine....
      04-28-2024, 03:31 AM
    • lap-top123
      Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
      by lap-top123
      HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
      Hp Elitebook 850 G8
      ProdID 52W98EC#ABD
      SN# 5CG1458XQ7
      Mac-address #1: 84:14:4D:2C:4B:5B
      UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
      Mainboard : 6050A3216701-MB-A01(A1)
      08-20-2025, 07:28 AM
    • CraigR
      Hp Spectra x360 Power light flashing, component id
      by CraigR
      Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
      05-07-2025, 11:06 AM
