Hi All,
Can anyone help me work our what I need to do next.....
I bought this tv and it was turning itself off after a minute or two. I took it apart and noticed that the were a few bad capacitors on the board. I changed all of these capacitors with ones of the same value and then hoping that I had fixed the problem I put it all back together.
Unfortunately the problem was still there. I then decided to disconnect the touch panel on the tv incase that was faulty and causing the TV to turn off but This still didnt help.
When the TV did turn on the screen came on as it should with the No Signal message before it turned itself off.
Now the TV wont turn on at all. The red light just flashes 4 times and then goes to solid red.
I have attached a pic of the board and the board model number.
I am sure with your help I can finally get this up and running
