A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
    Re: A guide to fixing/troubleshooting some common plasma TV problems
    Should be fine, only thing to be aware of is make sure alternate PSU is from 60" set (or used in one) and can drive the big panel (most likely it will be fine.)
    • subarufreek
      • Nov 2013
      • 53
      it is out of a 60" nec px-60xm5a. i only have $40 in the tv so i dont want to be out too much money. So youre pretty sure it will work right?
        I offer no guarantees, but most likely it will work.
        • Merbesfield
          Clueless dude
          • Oct 2013
          • 25
          Originally posted by tom66
          Will be under that board.
          Hi Tom, trying to get back to fixing this TV but just don't see where a board is under another board as you indicated. All the boards on my TV are affixed to the main chassis and the connectors go through the bottom of the and are screwed to this bottom. Removing the screws that hold the individual panel to the chassis does not allow them to be removed. I would have to remove the screws that also hold the connectors, problem is I don't know which board I am to remove and don't want to start pulling parts without some guidance. I realize this is basic, to some, but I have no clue. Removing screws and parts is not a problem, just need to know what I am after. I appreciate the help. I will post some more pics here for you to look at. Again, thanks. I hate to throw this TV away when I think it can be repaired. It's a challenge. Of course my wife thinks I'm nuts.
          Forum will only allow one pic upload per post for some reason so I will have to make multiple posts.
          All pics are described as you are looking at TV from back. First pic is left side.
          Trying to fix my: LG Model no. RU42PZ61
          • Merbesfield
            Clueless dude
            • Oct 2013
            • 25
            Second pic is right side.
            • Merbesfield
              Clueless dude
              • Oct 2013
              • 25
              Third pic is lower left corner. Some small board.
              • Merbesfield
                Clueless dude
                • Oct 2013
                • 25
                Last pic is upper left. Another small board to the left if the large board on the left.
                • Merbesfield
                  Clueless dude
                  • Oct 2013
                  • 25
                  And last pic is the bottom showing the connectors all screwed to the bottom of frame.
                  • Merbesfield
                    Clueless dude
                    • Oct 2013
                    • 25
                    And one more from left side showing that there does not appear to be anything under any of these boards unless it is very thin. Next pic will show hoe board on left is slightly higher than right board so if anything was under there it must be thin.
                    • Merbesfield
                      Clueless dude
                      • Oct 2013
                      • 25
                      If there is anything under this board, how do I get this thing off? The wires are tight, the connectors are all screwed to lower frame? Are we positive here?
                      • Merbesfield
                        Clueless dude
                        • Oct 2013
                        • 25
                        Tom66, begging for some help here. The TV is laying where the Xmas tree needs to go and I really want to get that panel pulled before it has to be moved for fear that it may never see the light of day, haha. But serious. Thanks for the help.
                        • Clinderw
                          • Dec 2013
                          • 6
                          Hi Tom,
                          I have a Samsung PN58A550S1FXZA and a single skinny line has appeared in the bottom right that goes about halfway up the screen. The line is usually green but sometimes is not green or not present based on the background. The green line is most noticeable on blue and red backgrounds. I attached a photo
                          I have confirmed it is present in multiple inputs and have tried unplugging the tv and then plugging it back in.
                          I am a competent DIYer and would love any advice on what could need fixed or is wrong.
                          Thanks in advance,
                          Chris
                            @Clinderw bad plasma panel, unrepairable, sorry.
                            @Merbesfield there's a reason I don't like people posting here, completely missed your post, the control board is under the last photo in that sequence.
                            • crissy85
                              • Dec 2013
                              Hi I have a 42 inch nec plasma and it turns on but the screen doesn't power up. This was an intermittent issue at first but now seems permanent?
                              • subarufreek
                                • Nov 2013
                                • 53
                                hello, i have just replaced the power supply in my pioneer pdp6070pu and now the blue light blinks 13 times. i have looked into this and it says its the main assy or power supply. i know i have to reset it but the manual say to turn the tv guide feature off and nowhere does it tell me how to. any help on this?
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #436
                                  THIS THREAD IS SUPPOSED TO BE A GUIDE -REALLY IT SHOULD BE A STICKY
                                  ANYONE NOT YET GETTING A REPLY SHOULD OPEN THEIR OWN THREAD OR
                                  ATTACH TO A THREAD FOR THE SAME SET. - THANKS
                                  NO ONE ELSE POST HERE - PLEASE
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Agreed. Thread locked for now. I also moved those last few posts on the Vizio P50HDTV10A to their own thread.
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • Hakuu
                                      by Hakuu
                                      Hi There,
                                      More Details
                                      TV Model - LG OLED77G1PUA
                                      07-12-2023, 02:37 PM
                                    • jb_Bak
                                      by jb_Bak
                                      CN6401
                                      Pin 01 NC
                                      Pin 02 NC
                                      Pin 03 "BL_ON": 0V
                                      Pin 04 "N/C"
                                      Pin 05 "STBY 3.3V": 3.5V
                                      Pin 06 "GND": N/C
                                      Pin 07 "AC_OFF"...
                                      09-27-2021, 04:52 PM
