Toshibia 40rv525u Green Blinking light and questions about Caps!!
+ More Options
Posts
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Toshibia 40rv525u Green Blinking light and questions about Caps!!
    OK, I'll listen and leave the caps on. Thanks!
    • ComputerGeek
      • Oct 2011
      • 262
      OK I have a problem,
      I have two spots that have become bridged on the board. Pin1 to the Small SmD Cap? next to it. And Pins 4 and 5 Together.
      Now For Pin 1 as I don't see any traces around it I believe that a trace ran to the cap under the white material? Also on the Data sheet this pin is tied to "Gnd via a Cap" or something like that. So does my assertion seem right?
      https://cdn.badcaps-static.com/pdfs/...d758189067.pdf
      And for Pin 4, I see no traces leaving from it on any side so I am asumming that it is tied to pin 5 under the White separator that is no longer there. Also on the data sheet is says "Tie the pin to pin 4 if burst-mode is not used." which would seem to indicate that they can be tied together.
      Does all this seems right? Sorry I tried to get the best pictures possible, but it is rather difficult because my camera does not do macro well.
      Thanks!
        Bridges are normal when removing and replacing... Do you have solder wick? This can be used to remove bridges.
        • ComputerGeek
          • Oct 2011
          • 262
          That just it I tried to remove the bridges with the wick, and the solder gets very thin but does not disappear. The bridges actually happened when I was cleaning the board with the desoldering wick.
          I think that those pins that I mentioned above are connected under the white pin isolator that was there and got scraped off when I was using the desoldering wick.
          ^^^ Does my logic in the post above check with the data sheet or not? It seems like the solder bridge is on copper that's why I can't remove it.
            The green colour of the boards is known as soldermask or solder resist. The soldermask is what stops the pads from shorting to each other and it is what allows the PCB to have those individually metal plated areas.
            It's generally difficult to remove the solder mask by accident as it's a strong layer. Very high temperatures and sharp objects can break it. Try adding a little solder to the pads. Seems counter-intuitive but it can help remove the existing solder.
            If you still can't remove it, get an good sharp knife and cut the pad and track. It's okay to do this as long as you are careful.
            • ComputerGeek
              • Oct 2011
              • 262
              Hmm, I already tried more solder. It won't come off.
              I had someone else look at it and it seems like both of these pads/components are supposed to be connected. I don't really know how to read datasheets, But would it make sense for pin 4 and 5 to be connected according to the datasheet? Also doesn't pin 1 have to be connected for this chip to function?
                You may be right about the intentional connection:
                Originally posted by L6599 datasheet referring to pin 5
                Tie the pin to RFmin (pin 4) if burst-mode is not used.
                Burst mode is an energy saving mode which might be used if the TV used the same chip for both standby and main power, but it doesn't. So it would make sense that they would disable the feature.
                It doesn't look like there are any other traces going away from it, so most likely the connection is intentional.
                • ComputerGeek
                  • Oct 2011
                  • 262
                  Ok and pin one needs to be used for it to function correct? Because I don't see any traces leading away from pin 1 other than possibly to the smd cap.
                    Yes. It handles the soft start of the power supply.
                      I am late on this thread and would like to know where it is at this point with the new IC installed. It sounds like the PS_ON is OK, Standby 5 volt is OK, but no 5v main, 12v, or 24Coming out from the main switching section.
                      Can I please get the clear picture in the red area, I believe the SMPS IC may not getting the VCC feeding it if I am correct.
                        I just looked at the spec of the IC, so please also get the pictures for this section also so I can see where pin 12 is connected to, thanks.
                          budm, ComputerGeek found that the IC had a 5.5 ohm short between Vcc and ground. And no short between the pads with the IC removed. That is why he is replacing it at the moment.
                            Thanks TOM66, it is just a very long thread and it is hard to keep up as to where he is at at this point.
                            • ComputerGeek
                              • Oct 2011
                              • 262
                              ^^^ Indeed it is a long thread! Anyway,
                              "Houston we have a Problem!"
                              Well I have Good and Bad news.
                              First the Good the Power supply is working, I replaced the IC and three of the 1000uf Caps I ordered them because they still seemed like they might be bulged, I know It is hard to tell with just a Photo. Anyway, I replaced those components and Installed the board back in to the Tv.
                              Bad News the Tv only stayed on for about a minute then the screen started flickering and there was a popping noise coming from the speakers, I immediately cut the power to the TV. However, during the one minute I was able to access the menus fine. Waited a few minutes and tried it again, this time I plugged a PS2 in and video and sound worked, but after about 30 seconds the screen went black and the was a pop in the speakers simultaneously. Also, note here that the Tv still stays on both the Logo and the Power light on. In Addition, after the pop and the screen shuts off there is no video or sound. (I Think this may be a clue.) So even thought the Logo is lit there is No Sound, There is sound before the Pop.
                              Finally, the condition has worsened to turn on, make the pop and the flicker for one second and then black, the power button can be used to turn the Tv off and on, however the second time the Tv is powered up with the power button there will be no flash or pop. However, if you unplug the TV from the wall and let the boards drain, then plug it back in the pop and the flicker happen again.
                              I am totally unsure, but this is just a thought I had. If the inverter had the problem would this take the sound and the picture out, or just the picture? Would It be more likely that the Power Supply is providing unstable voltages or the Main board has a problem?
                              Thanks for all the Help!
                                What caps did you use and why did you replace caps that were perfectly fine?
                                  The 12vdc and the 24vdc are generated by the circuits that you just had replaced the IC, 12VDC is used for the sound section, the 24 is used for the backlights inverter circuits. You should hook up a 12v lamp to the 12v output and see if it goes out (the 24 should also goes away since it is from the same transformer)
                                  • ComputerGeek
                                    • Oct 2011
                                    • 262
                                    tom66 I used these, I don't know, they seemed like they were slightly bloated in person.
                                    http://search.digikey.com/scripts/Dk...81-ND&x=9&y=14
                                    budm are you saying that I should measure the 12v and 24v outputs with my DMM?
                                      Yes, set DMM to DC volt mode, I like using lamp along with the meter so I can easily see if it is on steady or not.
                                        Okay, just as long as you didn't use RadioShack specials . They look suitable. Check your solder joints under these caps.
                                        • ComputerGeek
                                          • Oct 2011
                                          • 262
                                          OK I got to take the covers back off I'll post results back after I get home tonight.
                                          Solder joints were already checked under a Magnifier, they were fine.
                                          And I know better than to use CellShack Specials if your getting more than one Component its more cost effective to go with, Digikey. If they even have what your looking for!
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
