Toshiba 55U7863DG - green light blinking (17MB130S)
  • naddaw000
    • Dec 2023
    • Poland
    Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
    I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask for your advice and check if there any specific requirements on these boards compatibility ?
    I was trying to run the firmware upgrade, prepared the USB stick with the required files (4) and pressed the ‘OK' button following the instruction, but there was no reaction - there is a chance that the files which I've found are not the right ones.
    Please find the photo of the label attached below, including the serial number, as I heard it might make a difference.
    All information are more than welcome and I would like to thanks for your help in advance!
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Hi.
    try this : https://disk.yandex.com/d/Ph1asXfLgNUOGA
    https://www.badcaps.net
    • naddaw000
      naddaw000 commented
      Editing a comment
      Thanks, I have tried with the files provided by you, but unfortunately same result - no reaction, tv doesn't start the upgrade process. If I understood correctly it should start blinking quickly, but it doesn't happen
  • jxrepman
    Asus X453MA won't turn on and green led light blinking
    by jxrepman
    Hi there,
    I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
    I have checked the charger and it is giving 19+ V
    I have disconnected the battery and pressed power button for 30 seconds.
    I tried another RAM stick.
    Tried disconnecting the keyboard and touchpad.
    Tried disconnecting the HDD and the wifi adapter.
    The problem persists.
    Hope you could help me out on this one. Thank you.
    12-14-2024, 06:40 AM
  • Fergal22
    TOSHIBA 40L3453DB red-green blinking light
    by Fergal22
    Hi, just need a bit of advice please
    I have a Toshiba 40L3453DB tv with the blinking red/green light and the light grey screen but no picture or sound
    there are no swollen caps as far as i can see
    I have searched the forum and found this thread for the smaller size tv
    https://www.badcaps.net/forum/showthread.php?t=58640
    which recommends redoing the firmware, so i have searched and the only firmware i can find is this one
    h**ps://repairalltv.com/toshiba-40l3453db-software-17mb95-download/
    the 17MB95 board is the same as mine but the...
    02-14-2021, 03:32 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:33 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    01-26-2025, 08:18 AM
  • lcdcaps1
    820-2610-A Sys onewire help, no green light. Please help from the gurus
    by lcdcaps1
    Hi
    I have an 820-2610-A motherboard that has no green light.
    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
    The sys onewire circuit on this model and others is more involved
    I was hoping if anyone knows about this and how it works, can reply and let me know
    I know this is an old model but I am sure there are people who still works on these or knows about them
    I get 1.1v on the C7771 capacitor and will replace...
    11-06-2023, 01:28 PM
