Toshibia 40rv525u Green Blinking light and questions about Caps!!
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Toshibia 40rv525u Green Blinking light and questions about Caps!!
    Sorry, I haven't gotten back to anyone on here it's been a difficult month, I have had two Family members die. And my regular work has been extremely busy, which I guess i should be thankful for.
    Ok I tested and the PWR was measuring around 4.3v. However, none of the other outputs had any readings.
    Also, I probed the +5v pin before the resistor, and found that it wasn't stable. Without, the resistor its around +5.06v but with the resistor it goes all over the place from +4.16v to +4.80v, does that indicate a problem with the power board?
      Some types of power supply are unstable with no load, this is expected and is not really a problem as most of the time, they have a load. Are you saying when PWR signal is on, the power supply is not starting up?
      • ComputerGeek
        • Oct 2011
        • 262
        Yep as far as I can see. The side of the resistor that is connected to the PWR pin is measuring 4.3v. This would indicate that the problem is with the psu right and not the mainboard. What should i test next?
          Try using the resistor to pull the PWR pin down, some PSUs switch on when this is a low signal.
          • ComputerGeek
            • Oct 2011
            • 262
            Thats what I have been doing right? You said to hook the resistor up between +5v and PWR. Not sure what you mean by "pull the PWR pin down?" Thanks!
              Connect one end to PWR, the other to a spare GND pin.
              • ComputerGeek
                • Oct 2011
                • 262
                Nope nada, nothing nothing reads power except the +5v rail, conected PWR to Ground and all outputs are 0.0v. Thanks!
                  This confirms you have a faulty power supply. What tests have you done so far on this power supply? Also what value resistor were you using?
                  • ComputerGeek
                    • Oct 2011
                    • 262
                    I was using a red violet red that is 2.7k right?
                    I have only done what was suggested in this thread plus a few my my own.
                    Shortened List
                    Test Fuse Good
                    Listed and Checked all Pins for power. Results the only pins which had power were +5v and the PWR and ACD which went from 0v to 2.7v in Snyc with the Front Panel LED.
                    Checked 3 voltage regulators on the main board. Never really got an OK on these. POST# 25
                    Tested Diodes POSTS# 48,49,52.
                    Tried to jump supply using the resistor above from the PWR pin on both GND and +5v pins. Power Supple still did not read voltage.
                    Looking at the layout of this power supply, it's clear that there is no startup cap for the main rails (as the primary of the main transformer has just one winding); the Vcc for the main controller (5V/12V/24V) is developed from the standby supply and as that is working, it's unlikely to be the problem.
                    Umm about this post, since I am not getting anything on 12v or 24v does that indicate something wrong with the Standby part of the power supply?
                    Thanks for all the help so far.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Shortened List
                      Test Fuse Good
                      The voltage readings in post #25 indicate only that the regulators aren't getting power. In Posts #48-52 you did not what range you were using, or what diode was being tested. The picture is too poor to read component identifiers.
                      No voltage from the 12 volt and 24 volt supplies may indicate a problem with the main supply. IF the resistor pulled PSON to ground or to 5V, there is definitely a problem with the main supply.
                      PlainBill
                        Whilst using the 2.7k resistor, can you measure the PWR pin when connected to 5V and GND?
                        It sounds like the AC detect may be faulty but I'm not sure.
                        • ComputerGeek
                          • Oct 2011
                          • 262
                          But wouldn't that only be on the mainboard? The power supply should still start up with the resistor right? Or is this thinking incorect?
                          As for the diode test plain bill I was using the diode test function on the multimeter. And the test was done With the order of pins in the picture, Starting with 1 and the top of the board and ending with three at the bottom of the Diode.
                          Thanks!
                          PS should I try caps now what else can I test?
                            Maybe the resistor is too high of a value. If the voltage is genuinely going close to 5V or 0V, it's most likely the PSU that is at fault.
                            • ComputerGeek
                              • Oct 2011
                              • 262
                              What value should I try? As I said it was around 4.30, but also the the 5v rail became unstable with the values all over the place even as low as 4.1v, with the resistor connected.
                              What other components can I test on the PSU
                                You have to do a bit of guesswork because we don't know the input impedance of the PSU. Do you mean PWR measured 4.3V?
                                • ComputerGeek
                                  • Oct 2011
                                  • 262
                                  Yes, the Side of the Resistor that was connected to the PWR pin measured 4.3v
                                    And when grounded, did it measure nearly zero?
                                    • ComputerGeek
                                      • Oct 2011
                                      • 262
                                      Yes there was no apparent voltage. Meter just read 0.00 - 0.01v
                                        Good. This narrows the problem down to the power supply. I like debugging power supplies; they are far easier than a motherboard and often quite cheap to repair.
                                        From the look of this power supply, it seems that two capacitors are used to double the incoming 115V AC to 230V AC. I can only think they must do this because they can use similar parts that they might use on the 230V AC version. It's rather odd...
                                        This TV does not have a PFC section. I don't think PFC is required in the USA so this is probably why. That means one less thing to debug, which is good.
                                        Check that each of these capacitors has around 160V across it. Careful, this is high voltage, and can give a very nasty shock.
                                        • ComputerGeek
                                          • Oct 2011
                                          • 262
                                          Unless you guys have any other ideas, I think I am going to replace the Caps.
                                          What is suggested as a replacement?
                                          I was only going to replace all the Caps on the board except for the list below, unless you suggest otherwise.
                                          Leaving List
                                          All Film/Mylar Caps
                                          All Ceramic Caps
                                          The Two Main Filter Caps
                                          The two 1500uf 10v YXG Series 105C Rubycon's
                                          Replacing List
                                          All are Nippon Ky Series 105C Capacitors
                                          One 1000uf 25v
                                          Three 1000uf 35v
                                          Two 100uf 25v caps.
                                          One 10uf 50v
                                          One 22uf 50v
                                          One 47uf 25v
                                          Is that OK should I order any of the other ones?
                                          Also, I was just going to combine the 1000uf 25v
                                          and 1000uf 35v Caps and just get a lot of 25 or so of 1000uf 35v Caps is that ok?
                                          What is suggested as a replacement, should I get the same Series and Brand? I would like to try to get them all at Digi-Key.
                                          Thanks!
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • naddaw000
                                            Toshiba 55U7863DG - green light blinking (17MB130S)
                                            by naddaw000
                                            Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                            I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                            12-02-2023, 01:35 PM
