42PFL3704D/F7 No picture
Re: 42PFL3704D/F7 No picture
I have a philips 42pfl3704d/a7 with no picture, Iknow it has something to do with the inverters. I have checked the voltage at the cn1804 and cn1803 connector and got 50v, isn't that to high(should be +24v )? the screen flashes when you turn on the tv everything else seems to work sound, channel changer and you can see the pic. with a flashlight.Comment
I suspect you may be using the wrong ground for your measurements. If you are really getting 50V DC, a lot of capacitors should have blown tops.--- begin sig file ---
--- end sig file ---Comment
Might also have your multimeter on AC, instead of DC voltage. Im too lazy to consider whether that makes voltages seem higher or lower then normal.Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
Ok now I got 24v was using ac instead of dc setting, I was using the hot ground of the tv, now I suspect the invertor board to be the problem, tried resoldering all the connections on the board no help.Comment
The standard procedure here is to provide clear focused top down view pictures of all your boards following the instructions in my sig file below exactly.
Afterwards, we can suggest other test points.--- begin sig file ---
Can we get CLEAR closed up pictures of the inverter board where the connectors (white connectors with red/black wires) are?Never stop learning
Thanks to all who have posted help on this thread thus far. I t gave me a place to start looking for my offending components. We have a nice bright white screen, sound and can move through the channels. Tried all inputs, and the output is the same. Just a bright white screen.
I know HOW to use a multimeter, just not sure exactly where to test inside the tv.Comment
@dadsfishin, so you do have backlights, you do see glowing screen, if you do, then you need to check the surface mounted fuse and voltages on the T-CON board, its the board that sits at the center top middle of the panel in the back. Post the pictures using attachment function.Never stop learning
Thanks budm for posting the correct check.
@retiredcap, that what I thought you were thinking about, too much solder fume tonight?Never stop learning
Missing, stars Ashley Judd, is like "24".--- begin sig file ---
Oh, I love "24". I will check out 'Missing' to see if it is good.Never stop learning
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
- Loading...
