Bad Power Supply
  • BlackJack18
    • Sep 2011
    • 5
    Bad Power Supply
    I am looking for a repair kit for a Magnavox LCD TV with a few bad Capacitors. The model number is 47mf437b/37. The green power lite comes on and that is all.
    This TV has Capxon Capacitors, I found 3 on the power suply board that are bulged and two diodes that are discolored around the board. I also found 1 bad capacitor on the main componet board. The power supply board is 715T2454-2. I would consider buying a new power supply.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Bad Power Supply
    You need to make your own kit.
    That's a better plan anyway because same make/model screens can have completely different boards in them.
    Also kits generally either have more than you need or not enough.
    Not all bad caps bloat so a visual inspection isn't enough.
    Replace all the Chinese craps with good Jap caps of appropriate grade.
    Mann-Made Global Warming.
    - Dr Seuss
    • RJARRRPCGP
      • Jul 2004
      • 6304
      And likely the LCD TV has horrible ventilation!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • mariushm
        • May 2011
        • 3799
        If you don't know what capacitors to use to replace the existing ones, try to make some snapshots of the boards and write down (and post here) everything written on the capacitors and we'll try to recommend some good parts for you.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          For the caps list: Make, -SERIES-, uF, Volts, -DIAMETER-
          There are a bunch of people here that can match grades for you.
          - Dr Seuss
          • MTS2011
            • Oct 2011
            What are the capacitor values?
            • billansor
              • 85
              Hi
              This schematic can be found here;
              While it says it is a 37 inch... it is also for a 47 inch.
              There will be a list of parts.. Also parts location on the board.. Parts will be numbered in 4 digits.
              At the end of the pdf file, there will be a revision page..... Some of the 37 and 47 inch tv's had revisions.
              The tv's power supply does burn up around the zener diodes... The ones I have had to replace are 9.1 volt and am using 1 watt instead of the half watt that is called for.
              Do supply some pictures and along with what I have, should be able to get you going again.
              Bill
              • BlackJack18
                • Sep 2011
                • 5
                thanks for the info, fixed by replacing caps and two diodes on power supply
                • tvmirage
                  • Apr 2012
                  Hi everyone! I am new to this particular forum and need some help...Can anyone provide the schematic for this model?
                  I replaced a few bad caps with the Q901 (STW18NK80Z) and 2 diodes about 3-4 weeks ago. The set came back with the following parts blown:
                  • Q901 blown (STW18NK80Z) blown
                  • IC904 blown (8pin IC , TEA1507P)
                  • R963 blown
                  • D914 blown (surfacemount diode)
                  I need the schematic to know the exact value to use for the diode and resistor. Isuspect the Q901 that was replaced the first time may have been faulty and caused it to damage the other parts as well...
                  Can anyone help?? Thanks in advance!
                  Angelo M. || Service Manager || Television Mirage
                  • jetadm123
                    • 2169
                    • R963 blown
                    my email is: televisionmirage@hotmail.com
                    Did you bother to read this thread? See post #7.
                    • tvmirage
                      • Apr 2012
                      yes, of course I read the thread...the link does not work any longer and the zener mentioned in the post is not specific if its the same as the one I am in need of...
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        The link does work - what on earth possessed you to post your email address- you will get spammed from worldwide. If you are quick it might let you edit it out.
                        • tvmirage
                          • Apr 2012
                          lol, good point, i was able to edit my post, can you try and edit yours, it has a quote posted!
                          I tried again to download...the initial link says the file was moved so I searched for it in the link from that page, it worked! thanks my friend! I will post results when completed!
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Its not my post - try and PM JETADM123 - click on his name and follow from there
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                I have seen something which suggests D914 has the same value as D915 and
                                R963 has the same value as R964
                                Are D914 and D915 on the bottom of the board if so that could be correct.
                                BUT if R963 is on the top of the board I cant see R964 ??
                                However there maybe several different boards / revisions
                                Can you do Pics of where the items are/were and close ups of D915 and R964
                                • tvmirage
                                  • Apr 2012
                                  Hey everyone, I was able to troubleshoot with the info I got from everyone and the link to the schematic, I was able to order the correct components for it...great help! Appreciate all the support from this forum, I will post once the board is up and running again, thanks!
