When set is turned on, only the Vizio logo pictures shows, I cannot select any inputs by front panel controls and remote control. I have 5.5vdc, 12vdc and 24vdc coming from power supply. I suspect bad caps in main board I cannot find any service tips on this model. Any help will be much appreciated. Thanks.
Vizio E-320VL Turns on stuck with Vizio logo picture
Re: Vizio E-320VL Turns on stuck with Vizio logo picture
Many Vizio (and other brands) have problems with the LDO regulators on the main board. Pictures are a big help. Attach them using 'Manage Attachments' - below the text entry area.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Thanks Bill for your help. At the moment I do not have a good digital camera to take pics of the board. I do suspect, as you suggest, being a faulty component on the board. May be one of our members can provide you with the picture.Comment
First, we can see the actual board, and spot defects the owner has not noticed. In one extreme example, I spent several hours helping someone with a 'two seconds to black' problem on a monitor before he finally supplied pictures of HIS power supply. And I realized at that point that he had many bulging caps on the power supply - a common cause of the problem.
Second, most manufacturers make modifications to their boards during a production run, some may use several different boards.
The third reason - I use it as a filter. If someone is unwilling to provide pictures, I see no reason to help them.
Lack of a camera is not a big deal; try borrowing one. My personal camera is an Olympus D-580 4 Megapixel camera with zoom. In the proper hands it can provide excellent pictures; even in my hands it does an adequate job. They are available (used) on eBay for under $15, including shipping. And there are other, better cameras available for similar prices.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
When set is turned on, only the Vizio logo pictures shows, I cannot select any inputs by front panel controls and remote control. I have 5.5vdc, 12vdc and 24vdc coming from power supply. I suspect bad caps in main board I cannot find any service tips on this model. Any help will be much appreciated. Thanks.Comment
Hi Village Electronics, old pro, thanks for the picture, but my main board looks different than yours. Your help is much appreciated. It is very hard to find a service manual for this set. I will be posting some pictures of my boards.Comment
Plain Bill. I did measure the dc voltages coming from the power supply to main board. All ok, 5v, 12v, and 24 volts. I hope we can find a schematic for this one. Some componets values: U103: M281G9084, U608: 17809(9 volts regulator) checked ok, input 12.12vdc, output 9.08vdc(set on), U704: M377 117-18, U706: LD 33 C941. Thanks for the help.Comment
Take a look at the picture Village Electronics attached (ignore the troubleshooting guide, that's a bonus). Note that it is possible to see the entire board. That is important. It is big - 1600 x 900 pixels. That is very important because it allows me to identify 5 probable 1117 type voltage regulators, another that is possibly a 1084? type, and one more candidate that is possibly a 7800 type. I can also see two fuses and two probable buck regulators.
I've identified a number of components to be checked. There are two fuses in the lower left corner; I'm pretty sure both are good, but it wouldn't hurt to check.
Just above the fuses I've identified two, possibly three bucking regulators. The caps in that area are critical. I would expect voltages like 3.3 volts and 2.5 volts out of these. That is best checked across the caps.
Further up the board is the Class D audio amp (which I haven't labeled). Just to the right of that are what I suspect are two LDO regulators. These can be checked by measuring the voltages on all three pins (the tab is electrically connected to the center pin, and is the output). Use a mounting screw for ground.
Of course, the Broadcom chip is the main processor and handles most of the video functions, I believe. To the right of that are two more LDO regulators. Again, use a mounting screw for ground and check the voltages on all pins.
Lastly, there are three chips that I suspect might be regulators. Two are above the Broadcom chip, one is in the upper right corner. I've identified them with ??. If lettering can be distinguished, what are the part numbers?
Thanks Bill for your research. Here are locations and part numbers on components:
U708: M301-973-120
U710: M301-973-120
Q709: NiKos P2003EVG VNB5M0B06
U709: M323G5657A
U707: M323G5657A
U704: M327-1117-18
U706: LD33C941
U608: 17809
U103: M281G9084
U410: 69282
U705: 9141K
U408: 50K13
I hope this will help us all. I will check voltages, but I need to replace the heat sinks before I do so. And apply new heat sink compound onto the top of components needing it. I will be happy to take more pictures of the main board.Comment
U708: M301-973-120
U710: M301-973-120
U709: M323G5657A
U707: M323G5657A
U704: M327-1117-18
U706: LD33C941
U608: 17809
U103: M281G9084
U410: 69282
U705: 9141K
U408: 50K13
U710: M301-973-120 ???
Q709: NiKos P2003EVG VNB5M0B06 Power FET
U709: G5657A - 3A step down regulator
U707: G5657A - 3A step down regulator
U704: M327-1117-18 1.8V LDO regulator
U706: LD33C941 ???
U608: 17809 9V regulator
U103: M281G9084 5A LDO regulator
U410: 69282 ???
U705: 9141K ???
U408: 50K13 ???
i have the same prob on a 47" vizio, was there a solution to this? thanksComment
Take some pictures and include them in your first post of the new thread, it will save time because you will be asked for them anyway.
DKComment
Possible bad eeprom, check out this link.
http://www.ebay.com/itm/Vizio-E320VL...item20d0875c49Comment
by x_orange90_xI just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
by Super360Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
by paulxxxxThe TV stuck at logo and cannot be turned off unless the cord is unplugged.
I was given two main boards and exactly the the same thing happens to both of them.
I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
There are no signs of damage on any of the 3 boards.
Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
Thanks! -
by ossroyVizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
My kids are getting antsy waiting... -
by justice171Hi everyone,
I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
Thanks in advance!
... - Loading...
