Vizio M60-C3 powers on, perfect logo, turns off
  • ossroy
    • Feb 2019
    • 18
    Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
    My kids are getting antsy waiting for dad to fix it like I did last time! (different problem then)
    -Roy
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Vizio M60-C3 powers on, perfect logo, turns off
    It sounds like it could be a BGA issue under the main processor.
    • neilc6
      • Nov 2015
      • 1550
      https://www.ebay.com/itm/12487932795...mis&media=COPY
      • ossroy
        • Feb 2019
        • 18
        After a lot of research, I ended up reballing it with a qualiity heatgun and flux. To my surprise, it worked great! I already had the heat gun and the good flux cost me about 10 buck on Amazon. My kids are now back to playing Xbox on the 70 incher.
        • diif
          • Feb 2014
          • 6978
          • England
          Nice work, that's a reflow not a reball though.
          • Super360
            Vizio E701i-A3 Vizio logo flashing then turns off
            by Super360
            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
            07-25-2024, 07:06 PM
          • JaquesPratt
            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
            by JaquesPratt
            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
            07-16-2024, 01:04 AM
          • csmith
            Vizio D50u-D1 Powers up no picture
            by csmith
            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
            issue. Set will power up with remote but not power off....
            07-11-2025, 11:52 AM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • papillon
            Vizio D50u-D12 damaged mainboards?
            by papillon
            Hi, I am troubleshooting a damaged Vizio TV (D50u-D1). Here's an overview of the troubleshooting I did with the unit when it was presented to me:
            1. TV powers on and back lights turn on, with normal brightness. The large Vizio logo is displayed. After a few moments (presumably when the TV is looking for inputs), the backlight turns off and the TV goes dark. No further message is displayed on the TV. Since the logo was displayed, I concluded that the power board, LED driver board, screen, LEDs and T-con board were all working fine.
            2. Although parts of the main board were working fine, I'm assuming
            03-10-2023, 07:01 PM
