VIZIO VO42L No picture, No Sound
  • pposey
    • Oct 2012
    • 60
    Re: VIZIO VO42L No picture, No Sound
    also the one behind it...U7...its showing an output of 23.5...input 2.05...tab 1.01
      It sounds bad, the output should be the rightmost pin (tab facing upwards) + 1.25V, so in your case at least 2.5V, but it is only 2.05V.
      I believe on these Vizios that U33 causes two others, U5 and U7, to also look bad - but it is only U33 at fault in this case.
      • pposey
        • Oct 2012
        • 60
        Ok i ordered the U33 regulator off of digikey. Thank you for all your help! i will post back to tell you if it worked!
        • yfriend
          • Nov 2015
          Hi. First of all, thank you for this topic. I have same problem and now I check power readings. My question is. What voltage reading should be on main board fuses? Thanks
            There are two fuses on the main board, one is for 5VSTBY, and another one is for SWITCHED 12V which will not be present until the main board sends out the PS-ON signal to the power supply board to turn on the rest of the power supply.
            Did you test the Voltages of the Voltage regulator ICs yet?
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • gavric
              Vizio M70-C3 Half picture is bad, main board on its last leg?
              by gavric
              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
              When tv powers on vizio V logo shows nice on whole screen. picture 1
              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
              When i click video to start playing picture goes black(like when you change...
              09-02-2021, 08:55 PM
            • fharris1977
              Vizio D50u-D1 Dead: PSU or Main Board?
              by fharris1977
              Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
              03-12-2024, 12:22 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
