Diah Here is the measurements that I see.
Sony XR-77A80J OLED 5 Blink
this is not luck subject... OLED are RGB micro LED in simple language... some get bad, but from my way experiences SONY / LG they handle this via firmware register and if it meant or not after use over 10000 hours the firm ware will register fault.. however there could be no fault...... after courts and claiming Philips OLED TV released binary ( i posted here ) to remove this action from boot... but other company didn't till now... so you can keep it in save place till this wounder happen from SONYComment
Great information! I will more than likely put this against the wall and list the boards. Though I am interested in what will happen with this Sony case. Where can I follow it?
by iglitareHi,
Or is it always a bad/shorted... -
by jason123Hi there,
I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
I see 2 posts that are relevant:
https://www.badcaps.net/forum/troubl...j-oled-5-blink
https://www.badcaps.net/forum/troubl...g-hardware-dev... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by thelankanguyThe TV shows a black screen with no image.
TCON ribbon connectors were disconnected individually for image and there was no half image even.
Later both ribbons were disconnected and TCON voltages were tested.
12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
There is also a short to ground in this circled inductor.
Is this a TCON issue or something else ?... -
by bbrainHi,
I have this problem with my Sony 55' AG9.
It flashes 4x.
I have found the service manual, and seems it is the TCON.
Before I buy a TCON can someone check the vid?
Thanks in advance!... - Loading...
