EU55JS9000T black screen and sound good
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4539
    • Italy - Milan
    Re: EU55JS9000T black screen and sound good
    i don't like downloading big files.. can you report connector signals? how do you make the screen test? Standard RC or service RC? can you post a photo of the OCB cable? especially the connector.. are you sure the replacing ocb cable is good?
    • totof
      • Feb 2017
      • 172
      • france
      I make the tcon test with a service RC (it's a RC bought by my colleague, the tv is his).
      Some photos of the tv during the test.
      A photo of the one connect cable.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        you must show the tables of the main power board, the orange one..
        • totof
          • Feb 2017
          • 172
          • france
          The connector pin of power board
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            OCB has a short circuit that disables the screen (12v off> tcon off) that disables the dim signal to the led driver board (backlight off).. since you are not a technician you have to get a replacement ocb.. 12v on MB maybe remains on because of a protection circuit at valley of the screen switcher mosfet..
            • totof
              • Feb 2017
              • 172
              • france
              #26
              Thank you Davi.p
              Whether the OCB is connected or not I have 12V on the fuse at the input of the tcon.
              Before bringing me his TV, my colleague went to an approved Samsung repair center but the technician didn't really look because the TV was too old for him. He tried another cable and another box but same result. But the technician didn't really know if his cable and his box were really functional.
                • 12330
                • U.S.
                #27
                Check up on the fan in your ocb, make sure it's clean and functioning properly.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #28
                  This changes things..
                  that man is ridiculous..
                  so this does not change things..
                  Carefully if possibile, safe, test the connector for the ocb on the main board to find the 12v feed pins, then connect a protected 12v test psu to the ocb to see if it goes into protection..
                  • totof
                    • Feb 2017
                    • 172
                    • france
                    #29
                    The fan was a little dusty and I cleaned it, it still worked.
                    Whether the OCB is connected or not I measure 12V on pins 25 and 26 of CN201
                    • totof
                      • Feb 2017
                      • 172
                      • france
                      #30
                      Yesterday I had the opportunity to try another one connect cable and the result is the same, namely that the backlighting turns off immediately as soon as the OCB is connected. So it is not a cable issue.
                      I checked the B13V signal on CN201 (pin 25,26 on main board side) and I see 12,73V when OCB is not connected and 12,67V when OCB is connected.
                      It's a little below 13V but it might still be normal, I don't know.
                      I'm following up on any leads that could help me find the origin of the problem.
                      I have been looking for the OCB card diagram for several days but it is nowhere to be found.
                        • 12330
                        • U.S.
                        #31
                        The socket on the tv that you plug the cable into may be damaged, check it over.
                        • totof
                          • Feb 2017
                          • 172
                          • france
                          #32
                          I checked the connections on both sides, no problem detected
                          I measured the voltages on all the self on the OCB board.
                          L203 = 5.1V
                          L201=1.51V
                          L208,L209=12.3V
                          L901=1.16V
                          L304.305=0.92V
                          L302=0.89V
                          L802=0.05V !!!!!!!!!!!!
                          L401=1.09V
                          L402=0.97V
                          L202=3.3V
                          L404=0.90V
                          L403=1.8V
                          L307=0.99V
                          Maybe a problem on L802 but I don't know what it's for because I don't have the card schematic.
                            • 12330
                            • U.S.
                            #33
                            Guess the possibilities are, bad cable but you said you tried a good one, bad ocb, maybe the guy who tried a different ocb had a bad one or one that was incompatible, I would check as may components as I could on the ocb, bet one is bad.
                            • totof
                              • Feb 2017
                              • 172
                              • france
                              #34
                              I checked the capacitors for short circuits and found several with low resistance:
                              - C373, C377, C381, C382, C383: 36.6 ohm
                              - C3318: 0 ohm
                              - C1014: 36 ohm
                                • 12330
                                • U.S.
                                #35
                                Ok, that's part of the battle, now to just find someone with a properly functioning ocb to compare with, I have no idea what those voltages should be, have always stayed away from those ocb tvs.
                                • totof
                                  • Feb 2017
                                  • 172
                                  • france
                                  #36
                                  The problem is that this OCB model cannot be found, either new or used.
                                    • 12330
                                    • U.S.
                                    #37
                                    Looks like they run very hot with little ventilation if any, if I had to use one that worked, I would leave the cover off and also get some air blowing on it to try to keep it cool.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4539
                                      • Italy - Milan
                                      #38
                                      one inductor with no voltage is normal, is for the Sat input/output
                                      • totof
                                        • Feb 2017
                                        • 172
                                        • france
                                        #39
                                        Thanks, no need for me to focus on that side
                                        • totof
                                          • Feb 2017
                                          • 172
                                          • france
                                          #40
                                          I notice that the backlight cuts off a fraction of a second after plugging in the OCB cable, it's really instantaneous, while the sound from the TV comes several seconds after plugging it in.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • totof
                                            LG 43UF640V backlight good but black screen and no sound
                                            by totof
                                            Good morning.
                                            I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                            I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                            In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                            HVDD : 7,28...
                                            04-13-2024, 11:37 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
