EU55JS9000T black screen and sound good
  • totof
    • Feb 2017
    • 169
    • france
    Hello.
    I have this issue on my Samsung EU55JS9000T TV.
    Backlight is good when the one connect box in not connected to the TV and I can launch the TCON screen test with the remote control.
    But when I connect the one connect box the backlight immediatly turn off, the sound is OK (TNT source).
    I dont know if the problem is from the one connect box or from the internal motherboard of the TV.
    I open the one connect box (reference BN96-37087R) and all seems good, simply the Hawk-P CI is very hot after 5 minutes (~65 degres).
    Is someone have experience for same issue for this TV and can help me ?
    I see in the manual service the presence of a debug port but I don't know how to use it.
  • Diah
    • Feb 2013
    • 6558
    Re: EU55JS9000T black screen and sound good
    the way to know,,,, turn on TV with out connect box... it should turn on BL ON and the screen displaying warning . so what do u have?? are there any display on screen ???
    • totof
      • Feb 2017
      • 169
      • france
      I have not checked the BL_ON signal. When one connect box is not connected I have a message on screen that indicate box is not connected.
      • Diah
        • Feb 2013
        • 6558
        replace one connect box and its cable
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4536
          • Italy - Milan
          UE55JS9000....
          check power supply outputs when you connect OCB
          • totof
            • Feb 2017
            • 169
            • france
            Thank you, I will check that but a have to open the TV.
            To be continued ...
            • lotas
              • Jan 2016
              • 4850
              • Russia
              The problem may also be in the connecting cable (frequent breakdowns).
              • Diah
                • Feb 2013
                • 6558
                free of charge advice... if you are going to open the cover you will certainly killing the TV 100%
                JS aerie need always repair person should wear in his / her arm hand GND band before touching any parts
                • totof
                  • Feb 2017
                  • 169
                  • france
                  I have tested with another connecting cable, same issue.
                  • totof
                    • Feb 2017
                    • 169
                    • france
                    I have checked the BLU_ON_OFF signal and I have 4,7V when the One Connect box is connected. So it seems good.
                    • totof
                      • Feb 2017
                      • 169
                      • france
                      I have continued the test:
                      When motherboard is disconnected (backlight is on):
                      VDRV = 52,9V
                      LED_VCC=12,7V
                      FAIL=0V
                      When motherboard connected and one connect box not connected (backlight if on):
                      VDRV = 56,4V
                      LED_VCC=12,7V
                      FAIL=0V
                      P_DIM1..16 = 0,81V
                      BLU_ON_OFF = 4,7V
                      When motherboard connected and one connect box connected (backlight if off):
                      VDRV = 59,5V
                      LED_VCC=12,7V
                      FAIL=0V
                      P_DIM1..16 = 0,36V
                      BLU_ON_OFF = 4,7V
                      So when one connect box is connected, the P_DIMx signals falls.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4536
                        • Italy - Milan
                        those are not the right pins to measure, put some effort more...
                        • totof
                          • Feb 2017
                          • 169
                          • france
                          Thank you for your answer but I agree more details to put effort on the right pins :-)
                          I'm not an expert.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4536
                            • Italy - Milan
                            there are more pins on the connector that connects to the main board, test them all
                            • totof
                              • Feb 2017
                              • 169
                              • france
                              OK, I will do this.
                              All the signals P_DIM1..16 goes from TCON board and not from main board.
                              I'have tried to power one of the 16 LED strip with an external power (~30V) and it seems there is no picture, only sound is good.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4536
                                • Italy - Milan
                                to test B.L. leds must use a resistor in series
                                • totof
                                  • Feb 2017
                                  • 169
                                  • france
                                  New mesure on CN9003 signals :
                                  When one connect box not connected (backlight if on):
                                  OD_ON_OFF = 2,52V
                                  BLU_ON_OFF = 4,7V
                                  ANA_DIM = 3,45V
                                  OD_LEVEL = 3,25V
                                  P_DIM1..16 = 0,58V
                                  When one connect box connected (backlight if off):
                                  OD_ON_OFF = 3,28V
                                  BLU_ON_OFF = 4,7V
                                  ANA_DIM = 0,28V
                                  OD_LEVEL = 2,2V
                                  P_DIM1..16 = 0,04V
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4536
                                    • Italy - Milan
                                    can you photograph the table near the connector?
                                    • totof
                                      • Feb 2017
                                      • 169
                                      • france
                                      You can see photos on page 26 and 27 on pdf file on my initial post (samsung_unxxjs9000fxxx_uhd-tv_training.pdf)
                                      • totof
                                        • Feb 2017
                                        • 169
                                        • france
                                        I'am able to launch the tcon test screen but only when one connect box is not connected, it doesn't work if one connect box connected. For this test the screen goes from red, blue, green and white.
                                        During the test the P_DIM1..16 signals show 3,14V on CN9003 connector (from tcon to backlight board). These signals are arourd 0,4V when one connect box is conected.
                                        I try to find the default board : tcon, main board or one connect box.
                                        I don't think it is an issue on backlight board or power board but I'm not 100% sure.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • totof
                                          LG 43UF640V backlight good but black screen and no sound
                                          by totof
                                          Good morning.
                                          I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                          I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                          In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                          HVDD : 7,28...
                                          04-13-2024, 11:37 PM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
